| Prius Main Forum This is a discussion on 04 Prius with CVT Problem within the Prius Main Forum forums, part of the Toyota Prius Forums category; Have an 04 with 8500 miles on it with a weird CVT problem. In braking mode going down a long ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Have an 04 with 8500 miles on it with a weird CVT problem. In braking mode going down a long hill the engine RPM all of a sudden increases to red line (extremely high RPM). It has to be put into Neutral to settle it down. Mileage is down 25-30% as well. Dealer is calling Toyota Technical for assistance. The Prius Tech at the dealer told me not to put it into braking mode when going downhill. Problem is intermittant as well. Anyone heard of this before? I also have an 02 Prius with 48,000 and no problems whatsoever. |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | This is normal operation. Your battery is getting near full and the ICE must run to avoid over charging. Your tech should know that. You can continue to use B-mode going down hill. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | efusco, The engine RPM is almost redline and would blow the engine if I don't shift to Neutral. It can't be because the battery is almost fully charged. It also happens sometimes just with the foot on the brake pedal going downhill, and not in braking mode. |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | Quote:
They might be able to pull a peak RPM with the diagnostic tool or something, but I'm going to bet you they tell you that everything is normal. It is expected and actually supports my belief in a full battery and ICE peak rpm that it occurs in both B-mode and with manual braking. Check your energy screen next time it happens...I bet the SOC is in the green and either full or 1 bar short. This is a protective tool to prevent overcharge. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | How would you know you are redlining? There's no RPM display. The car can sound like its reving more than a conventional car would. I would agree, check your energy flow display for SOC and what is driving what. B mode will tend to spin the engine unfueled, this is by design. B is for engine Braking, though it will increase regenerative braking until it has no more place to store it. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Energy display shows all normal indications, and battery charge level is usually in the blue range. when it happens. Also stepping on the "gas pedal" settles down the rpm's as well. ECU shows no codes. Toyota told dealer to verify symptoms as they never heard of this problem. I know there is no tach in the vehicle but I have driven enough vehicles in my time to know when rpm's are very excessive. Also, my 02 Prius does not do the same thing on the same hills. I know the drive systems are different, but at this point the 02 Prius is getting better mileage than the 04. The 04 didn't exibit this behavior until recently. It is not temp or speed related either. |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Quote:
Also keep in mind that the Atkinson-Miller cycle sounds a little different than the traditional Otto and that the engine itself is closer to the firewall than usual (so it sounds louder). | |
| Possible problem with my '07 Prius | diamondlarry | Prius Main Forum | 10 | 07-27-2007 05:37 PM |
| Problem wit Prius | Liam | Prius Main Forum | 6 | 03-19-2006 07:59 PM |
| My first problem with my Prius | petunia | Prius Main Forum | 4 | 01-23-2006 10:38 AM |
| My FIRST problem with my '04 Prius | djasonw | Prius Main Forum | 4 | 08-15-2005 09:07 AM |
| Climate System Problem (Thought to be MFD Problem) | losaltosprius | Care, Maintenance and Troubleshooting | 2 | 03-17-2005 06:08 PM |
