| Prius Main Forum This is a discussion on Weird MPG within the Prius Main Forum forums, part of the Toyota Prius Forums category; Tony, running the engine to operate the A/C compressor? The compressor is electric on the THSII. The engine would only ... |
| | #11 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Tony, running the engine to operate the A/C compressor? The compressor is electric on the THSII. The engine would only operate to charge the HV battery. Now running the engine to get heat for the cabin, THAT I could understand. |
| | #12 |
| Ruler of Omicron Persei 8 Join Date: May 2004 Location: Far-North Chicagoland
My Car: 2004 Prius Package: #9 Nominated 4 Times in 2 Posts TOTM Awards: 0 Friends: 16 | Half right, half wrong. Six of one, half dozen of the other. Thanks for keeping me straight, Dan. If only to make sure that I'm not randomly confusing people. |
| | #14 |
| Prius Master Tech Join Date: Feb 2005 Location: S.L.C. Utah
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Evan We are at 6000 feet Sorry I forgot that most everyone else is not. The gas pumps here are mostly 88. some cust that live in Park City have to run 91 or they will ping if it is not pinging don't go up. I could get better gas mileage in summer if I used 91 than if I used 88. In the winter it will not make a difference at all. I have never had a bit of trouble. |
| | #15 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Tire Pressure is 35 psi on front & 33 on the rear some people set them higher to improve gas mileage but you will sacrifice some handling. |
| | #17 | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | just a quick question about Dan's response to Tony's response... Quote:
I would posit that is what exces6 is seeing/experiencing - not low tire pressure. Once again, it's cold out there folks. You're operating an engine. Performance does have something to do with ambient temperature. | |
| | #18 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, that would be to produce HEAT, not to run the AC compressor. If you are sitting there in park, the engine will not run to maintain its temperature (other than during initial turn on), but rather only to maintain HV charge. I had this experience when I first got the car in August, running the AC while playing with the NAV. Engine ran only to keep SOC at 2 bars. Now once you get going, MPG is low to warm the engine/catalytic, and to bring SOC to 6 bars. I guess Toyota doesn't figure running the engine for 30 seconds to maintain SOC is long enough to cause an emissions issue, especially since this will not be a frequent occurance. Even while driving, when I ran into stop and very slow traffic, the battery ran down. ICE started only for about 30 seconds, and usually only started if I moved. When I stopped, it stopped, but seemed reluctant. |
| A Weird Suggestion? | Mystery Squid | PriusChat Website Questions | 28 | 05-04-2007 12:42 PM |
| so this is weird | Conine | Prius Technical Discussion | 7 | 03-27-2007 12:33 AM |
| Weird Al | Tadashi | Fred's House of Pancakes | 17 | 03-21-2007 05:36 PM |
| Well, that's weird | onerpm | Care, Maintenance and Troubleshooting | 12 | 01-03-2007 05:00 PM |
| This seems weird | 4chi | Prius Main Forum | 14 | 10-23-2006 05:24 PM |
