| Prius Main Forum This is a discussion on Computer flash and MPG within the Prius Main Forum forums, part of the Toyota Prius Forums category; MIL and CEL are different lights. MIL is the triangle of doom. Check Engine Light usually indicates an emissions problem ... |
| | #11 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | MIL and CEL are different lights. MIL is the triangle of doom. Check Engine Light usually indicates an emissions problem but should not prohibit driving. |
| | #12 |
| Prius Master Tech Join Date: Feb 2005 Location: S.L.C. Utah
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | mil & cel are the same thing the triangle of doom is hv malf. toyota calls the check engine light the malfunction indicator light. GM calls it a check engine light. |
| | #13 |
| Member Join Date: Jan 2004
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | My car is an October 2003 build. I did get the 40D flash in 2004 but did not noticed any difference in MPG. The car has never had a lower tank average than 46, most tanks at 50-51. This spring with 45000 miles on the car I have noticed an incredible jump in MPG. The last 4 tanks have been 54-55 MPG. It could be the excellent warm dry weather we have had in the last 3 weeks, or is there a 45000 mile breakin period? Still using original tires. |
| | #14 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | thanks Liam, I was just wondering as the computer replacement has made a tremendous difference in the mileage. The origional HV (hybrid vehicle) computer wouldn't accept the flash and was replaced as a consequence. |
| | #15 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Frank I don't think that the 40D had any pos or neg effect on the gas milage unless unknow to the owner the engine ecu was reprogramed also. I never had any one say that thier gas milage went up after the 40D. The calibration that is reprogramed for the 40D is not the same calibration that is used on the new ecu's or in the new cars the program changed shortly after 40D came out. I have replaced the H.V. ECU and have no seen or heard of any inprovement in gas milage. |
| | #16 |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | thanks for the input Kyle, that was the only thing done to the car and like I initally said the MPG has risen by about 8 MPG. Also the car goes into S4 way sooner. I can only assume that the computer was the problem then. Thanks. |
| flash backs | barbaram | Fred's House of Pancakes | 1 | 06-10-2007 12:29 AM |
| Fun with flash animations | galaxee | Fred's House of Pancakes | 15 | 09-03-2006 08:31 PM |
| Prius Flash | john1701a | Prius Main Forum | 4 | 04-13-2006 08:55 AM |
| Headlight Flash EV Mod | kdmorse | Prius Modifications | 22 | 03-23-2006 05:21 PM |
| Car Shuttering and the TSB ECU flash | hdrygas | Care, Maintenance and Troubleshooting | 2 | 02-02-2006 09:06 AM |
