Prius Main Forum This is a discussion on Deleting trouble codes from ECU memory within the Prius Main Forum forums, part of the Toyota Prius Forums category; Having just joined the "ran out of gas and limped into gas station on battery power alone" club, I really ...
Old 06-01-2005, 12:49 AM   #1
laserbill
Default Deleting trouble codes from ECU memory
Having just joined the "ran out of gas and limped into gas station on battery power alone" club, I really would rather not share my stupidity (placing too much confidence in an optimistic mpg computer and funky fuel level gauge) with Toyota. It all worked out ok, and I was just glad I was piloting a Prius and not an airplane.
My question is can I delete any stored trouble codes from the main ECU by just disconecting the aux battery? I know that if I do, I will have to reprogram the radio, clock back up beep and possibly normalize the windows. Will this work and are there any tricks or things I should look out for?
laserbill is offline
Old 06-01-2005, 09:16 AM   #2
Nominated 1 Time in 1 Post
Friends: 24
They'll eventually self delete with enough restarts...I'm not sure how many. Also, if you go into the diagnostic screen I think you can delete the codes.
Really, this isn't something to worry about. Also, I'm not sure disconnecting the 12v would do the trick...I'm pretty sure the codes are stored in flash memory. There's not really any reason they'd need to check the codes.
efusco is online now
Old 06-01-2005, 09:50 AM   #3
laserbill
Default Re: Deleting trouble codes from ECU memory
Thanks Evan,
I will search the site to learn more about the diagnostic screen and how to enter it. My thought is to read existing codes, and then monitor them if they are still there in flash prior to needing factory service. If so, I will consider deleting them through the screen or by disconnecting the aux. batt. I just don't want to be arguing with Toyota over some code if I ever have a hybrid/ battery problem in the future because I ran out of fuel.
Old 06-01-2005, 10:40 AM   #4
DanMan32
The diagnostic screen will let you delete the AVC trouble codes, but not the ODBII codes.
Removing 12v power may or may not cause the ECUs to lose their codes, though it is a good bet they will. Any CAN compatable scantool should be able to clear the codes, especially ECM codes.
DanMan32 is offline
Old 06-01-2005, 08:42 PM   #5
laserbill
Thanks Dan Man,
It is a honor to get a reply from one of the most knowledgeable and active contributors at PC. Do you think having a flameout code residing in the ECU is worth worrying about? The SOC went down to one pink bar during my unwanted excursion in EV mode, power steeering was always working and the ICE started as though nothing happened once I put 11 gals in the tank. The car is acting completely normal after driving some 600 miles since.
Old 06-02-2005, 03:31 PM   #6
DanMan32
I probably wouldn't worry about it. Many have run it dry without ill effects. Some codes do erase after so many eventless trips, not sure if Out Of Gas and Engine Failed to Start are among those. Going down to 1 bar is definitely not a problem. HV would shut down the car before you got irreversably low in HV power, and would be able to re-engage READY at least 2 more times.
DanMan32 is offline
Old 06-03-2005, 04:44 PM   #7
Frank Hudon
40 sucessful start cycles will erase all OBD11 codes from memory. Disconnecting the battery will not erase OBD11 but will on OBD1
Frank Hudon is offline
Old 06-03-2005, 05:27 PM   #8
laserbill
This site is amazing thanks to its members.
Deleting trace route on Navigation flydeep Audio and Electronics 7 11-26-2007 07:49 PM
Best diagnostic tool for reading trouble codes? svallandigham Prius Technical Discussion 7 11-26-2007 04:42 PM
Deleting Points in Nav Sys - HELP OwenKealy Care, Maintenance and Troubleshooting 4 05-20-2007 09:16 PM
Trouble Codes you never want to see Tempus Care, Maintenance and Troubleshooting 21 03-02-2006 06:50 PM
Deleting messages IsrAmeriPrius PriusChat Website Questions 4 11-07-2004 02:47 PM
