Prius Main Forum This is a discussion on gas engine on-off-on-off-on-off within the Prius Main Forum forums, part of the Toyota Prius Forums category; Just wondering if anyone else has experienced this: At a certain stoplight on my commute home (I just exited the ...
Old 03-10-2004, 04:18 PM   #1
jsorger
Default gas engine on-off-on-off-on-off
At a certain stoplight on my commute home (I just exited the freeway and am on a 5% of so grade) the gas engine almost always cycles on and off until I move. If I sit there for a minute, for example, it will turn on for 5 seconds, then off for 5. It repeats this until the light changes.
It only happens in this specific situation, at this one stoplight. But it's fairly repeatable.
Has anyone else had this happen?
jsorger is offline
Old 03-10-2004, 04:39 PM   #2
Jerry P
I've noticed that having the A/C on automatic in cold weather will cause the engine to do this sometimes, I suppose to provide heat to the cabin. If I switch it to manual, the engine will not act the same way.
Jerry P is offline
Old 03-10-2004, 04:47 PM   #3
jsorger
Good suggestion - I have noticed that before as well.
But my AC is not on in this case...
jsorger is offline
Old 03-10-2004, 04:52 PM   #4
cybele
Former Moderator
Have you happened to notice how full the battery is?
Sometimes when I'm completely warmed up the car will cycle on when I'm just sitting there and I've found it's when I have only two bars left.
cybele is offline
Old 03-10-2004, 04:56 PM   #5
Nominated 1 Time in 1 Post
Friends: 24
Originally posted by cybele+--><div class='quotetop'>QUOTE(cybele)</div>
<!--QuoteBegin-jsorger
Sometimes when I'm completely warmed up the car will cycle on when I'm just sitting there and I've found it's when I have only two bars left.[/b]
cybele's answer may be correct, or it could be just the opposite, that the battery is nearly full, the cycling will deplete the battery charge to avoid it getting too full should you have a long period of charging come up.
efusco is offline
Old 03-10-2004, 05:14 PM   #6
DaveG
DaveG's Avatar
Package: C
I've had it happen a couple times. I usually just turn on the front defroster for a minute or so and it stops the cycling.
I also occasionally get a strange "surging" feeling while the engine is in park. Had it last night on a cold night as I was waiting for the car to defog the windows - almost as if the gas engine was idling a bit rough and the electric engine was having to try and pace it to run the power split device so as to keep the car stationary.
Dave.
DaveG is offline
Old 03-10-2004, 05:43 PM   #7
boa8
boa8 is offline
Old 03-10-2004, 08:04 PM   #8
jsorger
Thanks, Boa8!
That must be it. I must be at the angle where it turns on. Barely.
jsorger is offline
Old 03-11-2004, 12:26 AM   #9
htmlspinnr
htmlspinnr's Avatar
Package: Pioneer #3
Send a message via ICQ to htmlspinnr Send a message via AIM to htmlspinnr Send a message via MSN to htmlspinnr Send a message via Yahoo to htmlspinnr
Not neccesarily. I've had this too. Temp was just cool enough where the heater was on. I suspected it was either the heat at some threshold, or that my battery was full (it was) and it was dumping some charge.
Hill hold does not use the ICE.
htmlspinnr is offline
Old 03-11-2004, 02:54 AM   #10
charlieh
I have found that my ICE in both the '03 and the '04 will come on if I am using the fan (with the A/C off, mind you). I guess the draw on the 12 volt causes the ICE to come on at a stop to charge the 12 volt. As soon as I shut the fan off the ICE goes back to sleep. The engine is so quiet that sometimes you don't even realize it is on. I added the Engine Run Light kit on my '03 sold by Coastal E Tech and am awaiting something like that from them for the '04. It serves as a visual reminder that the ICE is, in fact, running.
"Sooner or later we sit down to a banquet of consequences." Robert Louis Stevenson, 1885
Aqua '03
Seaside Pearl '04
charlieh is offline
Engine OFF andyprius Prius Main Forum 9 05-30-2008 06:34 PM
Engine On 'n Off Stev0 Prius Main Forum 11 06-09-2007 08:17 AM
DOES ENGINE RUN WHEN AC IS ON?? jiw395 Prius Technical Discussion 22 08-14-2006 02:27 PM
Does Gas engine run too much ?? HAMMER55 Prius Main Forum 3 10-13-2005 05:12 AM
What engine oil to use? webguy Care, Maintenance and Troubleshooting 14 10-12-2005 07:46 PM
