Prius Main Forum This is a discussion on Coasting or Braking? within the Prius Main Forum forums, part of the Toyota Prius Forums category; Does anyone know if there is a difference in recharge power between coasting and braking? I'm wondering when I come ...
Old 07-25-2005, 11:16 AM   #1
Kablooie
Kablooie's Avatar
Default Coasting or Braking?
I'm wondering when I come up to a light, should I keep steady pressure on the brake and slow to a stop or should I coast up and then brake at the end with more pressure? Which would be more advantageous mpg-wise?
Kablooie is offline
Old 07-25-2005, 11:22 AM   #2
Nominated 1 Time in 1 Post
Friends: 21
moderate braking will regenerate much more than coasting--which does very little. But it's all a trade-off depending upon driving conditions.
efusco is offline
Old 07-25-2005, 11:58 AM   #3
jamarimutt
Default Re: Coasting or Braking?
I don't brake to recharge the batteries; I brake to stop the car adequately, and allow the system to regenerate whatever it can according to the way I brake. If you think too much about all the details of driving the Prius to maximize fuel economy, it stops being fun.
jamarimutt is offline
Old 07-25-2005, 12:12 PM   #4
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
<div class='quotetop'>QUOTE(jamarimutt\";p=\"110088)</div>
i never thought a lack of options was more fun than making my own choices
DaveinOlyWA is offline
Old 07-25-2005, 12:57 PM   #5
Friends: 21
To each his own. I find it more fun to continue to explore the limits of maximizing the fuel economy.
That said, I agree that goal #1 with the brakes is to stop the car. To that end I avoid using the brakes as much as possible.
But once it is clear that the brakes will need to be used I try to maximize the regeneration, minimize the use of friction brakes, and maximize the fuel economy via anticipatory driving.
efusco is offline
Old 07-25-2005, 04:41 PM   #6
Tempus
The Ideal would, of course, be to only coast and never brake.
If the choice is between slight braking all the way to the light, versus coasting then 'hard' braking, then the slight braking wins.
Remember, all braking below about 8 MPH is mechanical. Regeneration cuts out at that point.
Above 8 MPH, slight braking regenerates, but 'hard' braking can also engage the mechanical brakes, which is wasteful.
Also, remember that below 20 MPH you can use the "B" mode to get maximum regenerative braking without touching the pedal.
That's one of the tricks the Japanese hyper-milers use in city traffic. Since it's very hard to tell exactly how hard you can push the pedal without crossing over to mechanical braking, if you use B to brake initially coming to a light you are guaranteed maximum regeneration.
However, above 20 MPH B mode will spin the ICE for resistance, which is just as wasteful as burning brake pads
Tempus is offline
Old 07-25-2005, 09:27 PM   #7
SDiego
Thats always been my question. There is some steep hills that I have to go through alot everyday. If I just barely touch the brakes, it helps slow down the car alot, but I wonder If I am barely using the pads also? How much is to much, before the pads kick in at say 50-60 mph?
SDiego is offline
Old 07-25-2005, 09:56 PM   #8
DaveinOlyWA
if you start to brake slowly and gradually, it will be nearly all regen. the key is that if on a very steep hill to start braking early. now you might not want to brake if you will be going back up a hill soon. on rolling hills, not braking at all will be the best way to go if your speed doesnt get too fast.
regen is a great way to recapture some of the energy you expend, but its still woefully inefficient. so not braking is better. but if its a long downhill, then braking will be necessary. i would do as little as possible even if it meant going 10-15 mph over the speed limit. of course there will be exceptions and you need to decide what your maximum safe speed will be. i wouldnt ever go that fast anywhere but the freeway.
all this discussion is moot if there is traffic signals at the bottom or something along those lines.
My 2006: Last tank 476.8 miles @51.0 pump (50.9 computer) 7.63 cpm
winter mpg 50.78 summer mpg 54.93
lifetime: 30,628.2 miles 53.03 mpg pump (54.32 mpg computer) 5.73 cpm
My 2007 Zenn Driven 4580 miles, 2.09 cpm/ 178 mpg (at $3.71/gal), 3.76 miles/ Kwh
Savings over my Prius $249.16 The Corolla...457.83
The REAL SAVINGS from not driving Corolla 560.07 +Prius=809.23 (excludes maintenance costs...would be unfair to ICE vehicles)
Old 07-25-2005, 10:26 PM   #9
SDiego
So even just slightly pushing on the brake pedal, you could still be dragging your brakes? I try and just push just enough to feel a resistance and thats all. Maybe just slightly more at times. I quess the only way to test it, is try it and at the bottom of the hill, pull over and check the temperature of the front rotors and see how warm or hot they are.
SDiego is offline
Old 07-26-2005, 02:05 AM   #10
Frank Hudon
<div class='quotetop'>QUOTE(SDiego\";p=\"110263)</div>
if your really curious you could do the braking you normally do and when you get to 10 miles per hour if safe use the emergency brake to bring the car to a full stop then check the front rotors and see how warm they are. Disk brake systems use more front brake before the rears start so if you think your on the front rotors this would tell you. Just remember that front brakes can get very hot so don't put your fingers on the actual rotor or you just might need the good Dr. Fusco.
Frank Hudon is offline
loud noise while braking and or coasting statultra Prius Technical Discussion 0 02-27-2007 09:37 PM
Coasting VS Braking efrench515 Prius Main Forum 5 03-25-2006 04:21 PM
Coasting and braking Pappy Fuel Economy 7 02-17-2006 12:36 AM
Not getting 99.9 when coasting under 15 mph stevenalice Fuel Economy 6 10-22-2005 03:11 PM
Prius Coasting terkar Prius Main Forum 19 01-08-2004 12:04 PM
