| Prius Modifications This is a discussion on Body Kit / Aero-Dynamics / Peformance Parts within the Prius Modifications forums, part of the Toyota Prius Forums category; Does anyone know any places where they sell aerodynamic body kits for the 05 prius? I wanted to install some ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Does anyone know any places where they sell aerodynamic body kits for the 05 prius? I wanted to install some or maybe custom fabricate my own since I believe it'll improve not only my MPG but make my ride a lot more pleasant to look at. Also I was wondering if there are any performance parts out there that'll further improve my car to its fullest potential like Intake and Exhaust restrictions. And how much power should I expect if I were to have those modifications done. ![]() I'm looking to somehow gain 20-25 hp out of my car so those teenage street racers will think twice before revving at me after watching that new Tokyo Drift Movie. |
| Senior Member Join Date: Jun 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Althou I am no expert with the Prius, I would wager the traditional cold air in and free exhaust out would only have a very minimal impact on the performance of the Prius. A body kit would likely add weight to the car which would probably have a detrimental affect on miles per gallon as well as performance. I would suspect that being able to switch to electric only mode with a manual switch might provide some short term acceleration benefit at low miles per hour. Hopefully others will chime in with their thoughts as I am a fish out of water with this topic.
__________________ 2002 Champion New England Dragway 2001 GM High Tech Shootout Winner 1999 Champion Oxford Dragway http://www.tntdragracing.com |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(tnthub @ Jun 20 2006, 05:40 PM) [snapback]274338[/snapback]</div> Quote:
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(tnthub @ Jun 20 2006, 06:40 PM) [snapback]274338[/snapback]</div> Quote:
As for body kit and other performance add-ons, try here http://www.sigmaautomotive.com/jdm/prius/prius0405.php
__________________ 05 Millennium Silver Metallic, Package #3 (package with SKS and all airbags)
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Most aero-dynamic improving body kits aren't to reduce drag but rather to increase downforce. you'd lose some MPG. The Prius is a car that does'n tneed to harness much downforce due to it's weight and general lower speeds. I could see it helping you around a turn better at 50 mp/h if you'd need to to turn suddenly at that speed. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Maybe I can increase the output on the electrical motor with a switch when I really need it. As for the engine, do you think it'll benefit from the "Tornado" device that swirls the incoming air to increase efficiency and power. I'm also looking into an electric super charger that won't over boost more power out of the gasoline engine as well. |
| | #7 | ||
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(toyo proxes ra-1 rubber @ Jun 20 2006, 07:02 PM) [snapback]274353[/snapback]</div> Quote:
Edit: wow, the mods r fast on removing troll threads! <div class='quotetop'>QUOTE(toyo proxes ra-1 rubber @ Jun 20 2006, 07:02 PM) [snapback]274353[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(ScottY @ Jun 20 2006, 06:15 PM) [snapback]274373[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In traditional, (non-hybrid), vehicles, the tornado disrupts the air flow over the MAF sensor to allow more air than normal into the engine creating a lean condition over the typical stock programming. Since most non-hybrid vehicles are by default slightly rich in their air fuel mixtures to prevent detonation (and warranty claims as a result), sometimes the installation of a tornado can produce some benefit on an otherwise stock vehicle. However as airflow becomes more important at higher velocities the benefit of the tornado is reduced to the point where the disruptive air flow actually impedes proper detonation of the cylinders creating a loss of performance. the bottom line, from my perspective, is if the car is worth caring about I would avoid a tornado at all costs. Also, air in must be balanced with air out. I am sure that better airflow through a cold air filter will help as well as possibly porting the exhaust heads/gaskets, or installing true headers, but I really think the gains will be extremely minimal especially when considering the overall expense. Also, most vehicles benefit more from computer tuning changes after cold air and headers are installed. I have no idea if this is possible with the Prius or not. With the GM products that I am aware, aftermarket tuning software is required to take advantage of the modifications and the dealers often do not know about or admit to knowing about any aftermarket products. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | What if you had a Dry-carbonfiber Kit custom made for it? i know its not cheap. But if it would increase mpg and possible decrease the weight at the same time..it seems like a win win situation. |
| AERO PRIUS YURASTYLE | ken1784 | Prius Modifications | 53 | 09-15-2008 02:02 PM |
| Group Buy: KENSTYLE Aero Prius Body Kit | Danny | Prius Modifications | 26 | 09-04-2008 04:38 PM |
| Stability Control vs. Vehicle Dynamics Integrated Management | tcooper185 | Toyota Camry Hybrid | 2 | 09-27-2007 09:58 PM |
| Aero Modifications? | coonbutt | Fuel Economy | 6 | 04-05-2007 02:06 PM |
| Kenstyle Aero Kit for Prius | bpben | Prius Modifications | 14 | 05-12-2006 02:42 PM |
