| Prius Modifications This is a discussion on 12V power outlet in cargo area? within the Prius Modifications forums, part of the Toyota Prius Forums category; Sorry if I missed this in my search of previous threads, but has anyone added an "always on" 12V power ... |
| Junior Member Join Date: Jun 2006 Location: Santa Fe, NM
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Sorry if I missed this in my search of previous threads, but has anyone added an "always on" 12V power outlet to the rear cargo area? I've seen darelldd's additions to the console area, but surely there's a wire in the back that could be tapped as well. Anyone? |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 10 | <div class='quotetop'>QUOTE(climateguy @ Jul 1 2006, 08:27 PM) [snapback]279916[/snapback]</div> Quote:
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well now I feel stupid. I didn't even realize the 12V battery was in the back! Guess that makes it easy to add an outlet back there. So here's a hopefully slightly more intelligent question: is there a simple way to make the outlet in the center console (under the armrest) always on, similar to the mod for the one under the dash? Thanks! |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 10 | <div class='quotetop'>QUOTE(climateguy @ Jul 2 2006, 10:04 AM) [snapback]280126[/snapback]</div> Quote:
My Car: 2006 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hmmm...no always hot wire in the center console, eh? Bummer. Okay, I'll throw a new one at you, since you're obviously very knowledgable about the Prius' wiring: is there a way to make the cargo area outlet shut on/off with the car? I'm actually thinking I'd like a switch back there to have the option of always hot or not. Thanks for all your help! |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I wired a small Anderson connector onto the battery, to interface my assorted inverters and other gack in a way that can handle *real* amounts of current. It either hangs out past the battery-cover floorboard, or gets tucked away on top of the battery when not in use. . _H* |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I added two outlets to the center console, and I used a "fuse tap" and selected a circuit that was always on. The nice thing about the "tap" is that the original circuit stays seperate from the added circuit, and they are fused seperately (I chose 10A for the 2 outlets). It's simple to install, cheap ($3) and it doesn't affect the warranty (not overloading one circuit). EDIT: Here are the pics: [attachmentid=4117] [attachmentid=4118] |
| Center Console Power Outlet and Front (Cigarette outlet) How to mod Always hot?? | Prius07Pkg4 | Audio and Electronics | 14 | 07-04-2008 12:21 PM |
| 12v Power outlet | Pat Down Under | Prius Modifications | 7 | 04-08-2007 09:04 AM |
| Dual Power Outlet | actuary32174 | Prius Main Forum | 3 | 02-26-2007 09:56 AM |
| Power Outlet Fuses | bene04 | Care, Maintenance and Troubleshooting | 1 | 07-07-2006 05:57 PM |
| power outlet mod | ernda | Audio and Electronics | 4 | 02-26-2006 08:25 PM |
