| Prius Modifications This is a discussion on 2006 Prius Factory EV Button Installed within the Prius Modifications forums, part of the Toyota Prius Forums category; After searching high and low, I could not find any documentation on how to install a factory ev switch in ... |
| Senior Member Join Date: Sep 2006 Location: NorCal
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | After searching high and low, I could not find any documentation on how to install a factory ev switch in an '06. However, I decided to undertake the effort anyway using these instruction as the main document, and this one for the factory button info. I ordered my switch from Sigma Automotive (be sure to specify your year in the comments). It arrived yesterday, and I gave it a whack today. I learned a few things, which I'd like to share, and then end with a question or two.
OK, so now my questions. 1) Why didn't illumination work? Did I get the pins wrong?** Did I tap the wrong wires off the illumination controls? 2) In my experimentation, did I fry the illumination control? Why is the brightness off whack now, and why do the radio and the MFD not illuminate properly? I hope this helps somebody, and I also hope somebody can help me. ** EDIT: Corrected the pin labels above in case anyone is searching for this, I don't want them to get it wrong. Also, note that there are links in a follow up post to another writeup on the subject.
__________________ 2006 Prius - Silver Pine Mica - Pkg. #6 - 17000 miles - 41.5 mpg average Current Mods: EV Mode, DICE iPod, Anytime Reverse Camera, BT Motion Override Pending Mods: MFD Video Input |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hmm. It's worse than I thought. The MFD and radio actually flicker in brightness pretty much any time the rheostat is set to anything less than full bright... Can anyone help? |
| Senior Member Join Date: Aug 2006 Location: San Diego, CA
My Car: 2006 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I haven't installed the EV button myself, but this seems to be the right thread for the 06: http://priuschat.com/index.php?showt...3842&hl=button And here is darelldd's page on the EV install: http://www.darelldd.com/ev/prius_ev_mode.htm Good luck with debugging the problem! |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Ari @ Oct 2 2006, 07:16 AM) [snapback]326825[/snapback]</div> Quote:
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | OK, I flipped the pins around as described in the links you gave. Nothing like doing a little Prius modding in the parking lot at work, eh? EV still works, but I can't tell if the illumination works or not 'cuz it's too bright out there. BUT, the MFD and radio still flash when adjusting the rheostat. Anyone out there know enough to tell me if I've hosed the rheostat or something worse? Thanks! |
| Senior Member Join Date: Aug 2006 Location: San Francisco, CA
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Mr. Zorg @ Oct 2 2006, 11:54 AM) [snapback]326921[/snapback]</div> Quote:
But in a very, very cool way. | |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Pinto Girl @ Oct 2 2006, 12:02 PM) [snapback]327000[/snapback]</div> Quote:
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | OK, I've got it fixed!!! A friend of mine who is a bit more knowledgeable about automobiles and electronics suggested I check my fuses. Sure enough, the 7.5A "panel" fuse was blown. Pick up a replacement, and between that flipping the wires everything is perfect now. Phew. |
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Ari @ Oct 3 2006, 03:53 PM) [snapback]327569[/snapback]</div> Quote:
| Factory EV button in 2006 - done! | darelldd | Prius Modifications | 8 | 09-06-2006 05:50 PM |
| factory installed xm for 06 prius?? | buckspaul | Audio and Electronics | 20 | 08-30-2006 02:44 PM |
| 2006 Factory EV Button (How to use?) | porschett | Prius Technical Discussion | 11 | 07-23-2006 01:02 AM |
| Installed factory sirius in my prius. | prion | Audio and Electronics | 4 | 07-11-2005 01:06 PM |
| Factory EV Button installed - details | htmlspinnr | Audio and Electronics | 34 | 04-20-2004 04:30 PM |
