Prius Modifications This is a discussion on Has anyone mounted anything below the radio and map pocket? within the Prius Modifications forums, part of the Toyota Prius Forums category; Am thinking of mounting a pop-up touch-screen lcd monitor like this: ...to the angled plastic surface just under the map ...
Old 10-05-2006, 11:10 PM   #1
seakykr
Ugly Betty is her name.
Send a message via Yahoo to seakykr
...to the angled plastic surface just under the map pocket (the pocket with the with the flip-open door) that is under the radio, which you can see here:
I want to mount it hanging from directly under the radio/map pocket section, not to the plastic "hump" that rises from the floor.
When the touch screen flips up it will be in front of the radio, coming up to somewhre below the CD slot. I will use the touch-screen to control my laptop that will be under either my seat, in the center console or glove compartment.
Has anyone mounted anything in this location? Is there anything I should be concerned about? Any ideas on how to do it so it looks nice?
Thanks.
seakykr is offline
Old 10-05-2006, 11:21 PM   #2
Cheap!
Cheap!'s Avatar
It has been done, but I cant find a picture now. I know I have seen it before and it should work very well.
Maybe someone else can find it?
Cheap! is offline
Old 10-06-2006, 09:05 AM   #3
eagle33199
Platinum Member
i haven't seen ones under that pocket like you describe, but i have seen people pull the map pocket to install stuff (an additional screen like you want to do, a MAC mini, etc). The benifit of that, of course, is that you then have the flip up door to hide your improvement from snooping (and stealing) eyes. Also, whats the model info on that device you want to use? i'm getting curious now :P
eagle33199 is offline
Old 10-06-2006, 01:06 PM   #4
Presto
Has his homepage set to PC
Heya,
I completely removed the map pocket and placed a screen in there. I was using a Xenarc IDT-700, but further down the line, I scored a good local deal on a motorized E-Bay screen, which, in my opinon, is better than the Xenarc screen in many ways.
Initially, I had to cut the top part of the frame that was in front of the map pocket due to fitment issues of the screen and how it was opened. Since getting this new screen, I don't believe cutting the frame would be necessary based on the way it deploys. Unlike the Xenarc, I can also mount the screen deeper in the pocket, but still not enough to leave the door attached. It is flush with the rest of the components, so it makes it less eye catching. It also looks like a cheap-ass stereo when it's closed.
My only concern is the durability of the motorized screen. It still works as well as the day I acquired it. One of my reasons for initially going with Xenarc was that it wasn't motorized. The less features it has, the less things to go wrong, but we'll see what happens. I'm confident it should, at least, last a year or 2.
New Screen Closed:
New Screen Opened:
Old Screen Opened:
Daniel 2k5 Prius 'B' Package
PriusPuter(nav/wifi/entertainment)
E-Bay Motorized VGA Touchscreen
Deluo USB GPS
DLS A7 Ultimate 5-Channel Amp (4 x 60 W + 1 x 300W)
Focal 165KP Component Speakers
JL Audio 10W6v2 Subwoofer
B-Quiet Sound Deadening (front doors, hatch, spare tire well)
EV Button
CAN-View V2
TRD Sportivo Shocks and Springs
Tom's Strut Tower Brace
Tom's Lower Suspension Brace
Tom's Rear Brace
Presto is offline
Old 10-06-2006, 01:33 PM   #5
Pinto Girl
Pinto Girl's Avatar
Gee, this looks really nice! The data display on the MFD is neat, too.
Pinto Girl is offline
Old 10-06-2006, 03:08 PM   #6
Trevor
Why did I have to look at this thread? My mind is racing with possibilities. Now I'm off to check out ebay.
Trevor is offline
Old 10-06-2006, 03:28 PM   #7
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 7
There's also the Mac Prius project http://www.kusnetz.net/prius/ with a Mac Mini in the dash, and the MFD being used for car, CAN-View and Mac screen.
Ichabod is offline
Old 10-06-2006, 06:13 PM   #8
Cheap!
Cheap!'s Avatar
<div class='quotetop'>QUOTE(Presto @ Oct 6 2006, 12:06 PM) [snapback]328998[/snapback]</div>
New Screen Opened:
[/img][/url]
I knew I saw it somewhere before! Thanks
Cheap! is offline
Old 10-07-2006, 11:50 AM   #9
seakykr
Hey Presto, that's awesome you found a screen thzt would fit in the Prius map pocket with no cutting. What is the make and model number of the Ebay screen you got? Also if you tell me it's diumensions I am going to look for a non-motorized flip up screen of the same dimensions, since that will have less to break on it. Thanks.
<div class='quotetop'>QUOTE(Presto @ Oct 6 2006, 10:06 AM) [snapback]328998[/snapback]</div>
Heya,
New Screen Closed:
New Screen Opened:
Old Screen Opened:
seakykr is offline
Old 10-07-2006, 01:20 PM   #10
Presto
Seakykr,
Here is a link to an ebay auction that has the exact screen I purchased:
http://cgi.ebay.ca/TFT-LCD-Touchscreen-7-I...1QQcmdZViewItem
It amazes me that the screens cost so little compared to 5 years ago when I bought my first touchscreen for $1000. Anyways, that is that one that I'm using. One important thing to remember if getting a different screen is to make sure that the input/output connectors are seperated as much as possible. You'll notice this one has a seperate connector for VGA, video, USB, and power. The thing that bugged me most about the Xenarc was a unified connector that handled everything except the power.
Presto is offline
Can I install a headunit in map pocket? aolm Audio and Electronics 5 01-24-2007 08:16 PM
Where I Mounted My XM MyFi Mystery Squid Audio and Electronics 23 05-04-2006 03:42 PM
Pocket PC Trackin Program dadsbeads Prius Main Forum 8 05-18-2005 08:47 AM
Problem viewing PC with a pocket pc SyZyGy PriusChat Website Questions 9 12-30-2004 04:51 PM
Fob in pocket or 'ignition'? slmcdonald7 Audio and Electronics 18 09-28-2004 02:49 PM
