| Prius Modifications This is a discussion on 2002 Prius wanting to buy HID conversion kit within the Prius Modifications forums, part of the Toyota Prius Forums category; i'm looking to purchase an H4 HID conversion kit for my 2002 prius. has anyone done this before? is it ... |
| Junior Member Join Date: Sep 2006 Location: Pasadena, CA
My Car: 2002 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | i'm looking to purchase an H4 HID conversion kit for my 2002 prius. has anyone done this before? is it going to affect the battery in any way? mods: wasnt sure if this was the right forum, please move if necessary. thanks myfootsmells |
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | Not that I know of. It shouldn't affect the battery since it uses less power. Just note that with these kits, your whole headlight compound will light up (like those RSXs with HID kits) so instead of a nice cut off look like you see on the current gen, you'll have a nice bluish shape of your headlight. Anyway, just make sure you have space for the ballast and what not. |
| Prius Absolutum Dominium Join Date: Sep 2005 Location: Long Island, NY
My Car: 2004 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | [quote=myfootsmells @ Oct 9 2006, 12:28 AM) [snapback]329941[/snapback]</div> Quote:
| Senior Member Join Date: Jul 2005 Location: Los Angeles, CA
My Car: Other Non-Hybrid Package: N/A Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I've done this on my '05. Keep in mind that it is illegal because your (halogen) headlight housing will emit a pattern not too clean with some glare even after adjustments. I do believe it consumes less electricity once running (35watts) compared to the standard (55w). I have a dual beam meaning that there's an HID bulb and halogen bulb next to each other... the halogen does nothing in terms of extra illumination so its only function is to cause attention via high beam. Is this clear? Anyway, I bought mine on ebay. Out of the "cheap" but decent kits are McCulloch and Bohmen. Phillips is by far the best, but expect them in the $400+ range for single beam. By retrofit, did you really put a projector housing into your Prius housing? All I did was install the HID kit and pointed my headlights a bit downwards, but this isn't really retrofitting.
__________________ Out: Prius In: BMW 330ci convertible Yes, I miss the reliability and gas mileage! |
| Prius Conversion to E85 Ethanol? | adamorzol | Prius Main Forum | 24 | 04-22-2008 01:47 PM |
| Does this count as a majority of Iraqis wanting us out? | burritos | Fred's House of Pancakes | 7 | 05-15-2007 02:22 AM |
| Am I a whole lot of nuts for wanting to sell this thing? v.dealerwantstogivemenexttonothingforit | Deevan | Prius Main Forum | 39 | 03-03-2007 02:30 PM |
| For those wanting to install their own mudguards | goodsam | Prius Main Forum | 2 | 03-11-2006 06:25 PM |
| For those wanting to call around the country to find a Prius | Tigkoly | Prius Main Forum | 3 | 07-01-2004 09:37 PM |
