Prius Modifications This is a discussion on 2006 JDM OEM EV switch installation within the Prius Modifications forums, part of the Toyota Prius Forums category; I have a couple of questions regarding the installation of the 2006 JDM OEM EV switch. Pin 1 is grounded ...
Old 01-20-2007, 06:57 PM   #1
Peter Senich
Package: #1
I have a couple of questions regarding the installation of the 2006 JDM OEM EV switch. Pin 1 is grounded to a screw - but can it be tapped into the white/black stripe wire of the dimmer switch instead? Pins 2 and 3 are tapped into the red and gray wires of the dimmer switch - does it matter which is which? - I've found conflicting instructions. Thank you.
Peter Senich is offline
Factory EV switch installation judibob Prius Modifications 23 03-27-2008 02:19 AM
HELP: EV switch installation broke key sensor! drbradfo Prius Modifications 6 05-13-2007 07:11 PM
EV switch installation- Check engine light parrot_lady Prius Modifications 10 05-09-2007 06:52 PM
2006 EV Button Installation TheForce Prius Modifications 3 06-06-2006 12:41 PM
VAIS installation in a 2006 is done. DocVijay Audio and Electronics 17 01-22-2006 10:01 PM
