| Prius Modifications This is a discussion on Scangauge II users guide within the Prius Modifications forums, part of the Toyota Prius Forums category; Now that a bunch of us are going to get a new Scanguage II soon (Danny says mine's on it's ... |
| Senior Member Join Date: Feb 2007 Location: Modesto, California
My Car: 2007 Prius Package: #5 Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Now that a bunch of us are going to get a new Scanguage II soon (Danny says mine's on it's way!), what do you folks who are using the Scanguage like to monitor and why? Several readings can happen at once, so what is your favorite feature to use? O masters of the guage, shine forth your beams of understanding to us lowly wantabees! |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | I've done a search, but also a link to someone's install instructions or pictures would be nice as well. I've heard the install is relatively simple, but I've never done one.... |
| What's the catch? Join Date: Apr 2006 Location: Richmond, VA
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Depending on what my lunch plans are, I might be able to take some pictures of how I have mine set up. Both what I monitor and how I have it installed. But right now, I can't promise anything for this afternoon. ![]() |
| | #4 | ||
My Car: 2005 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(Rangerdavid @ Mar 14 2007, 08:34 AM) [snapback]405271[/snapback]</div> Quote:
I wanted the SG where I didn't have to shift my line of sight far from the road to see it. It was not a conscious decision to enable rapid visual shifting between the SG, speedometer, and MFD, but it turns out this location makes that ideal, while again, minimizing how far I take my eyes off the road. And that ability helps me monitor some of the rapid-fire changes occurring in the ICE and hybrid system, notably RPM on the SG and energy consumption on the MFD. Which leads to... <div class='quotetop'>QUOTE(Gadgetdad @ Mar 14 2007, 02:37 AM) [snapback]405225[/snapback]</div> Quote:
http://techno-fandom.org/~hobbit/cars/sweet/ http://techno-fandom.org/~hobbit/cars/heat...results-03.html These are a bit technical, so if you suffer from "delayed intelligence" like me, you might have to read them a few times to absorb it all. I've been monitoring coolant temperature for two reasons. First, I have my front grill blocked to accelerate and maintain engine warmups. During some of this winter's more moderate temperatures I've been concerned about overheating. I can pull out one piece of the foam I use to block the grill if ICE temps start creeping too high. Second, I've used it to gauge when to run the heat. It's been a relevation to see how quickly the ICE cools in cold weather while running the heat and either sitting still or doing ICE-off glides. (You can lose 10 degrees or more sitting at a stoplight.) Of course the more it cools, the more it wants to run to stay warm when it doesn't have to for propulsion. So I try to avoid the heat unless coolant temps are at 170F or above (or my fiancee insists!). When spring arrives for good, the grill block will come off and I may switch the SG to something else. TPS has a relationship to RPM, and I've been watching it to determine exactly what it is at various speeds. RPM changes constantly, whereas TPS is a little steadier. My hope is that I can find a range for TPS that will be easier to monitor than the always-fluctuating RPM. As for LOD, Hobbit describes a low-RPM, low-load -- and low efficiency -- "loafing" state for the ICE that I'd like to get a better handle on, and avoid when possible. I've been watching that to determine its relationship to RPM, TPS, and vehicle speed. Admittedly I haven't monitored it closely. I'm not sure how much more it can help me beyond RPM and TPS, and it's one more quickly changing value to try to see. Occasionally I'll spot check tank MPG to compare to the car's display; they're usually within a MPG or two. And I always check my trip and daily MPG values at the end of a trip and the end of the day. Have fun with it. I have!
__________________ Jim Lifetime fuel mileage: ![]() After learning how to hypermile: ![]() Click here for car details. | ||
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Here we go. For how I "installed" my Scan Gauge, look here. Currently, I observe: - engine load (LOD) or throttle position (TPS), depending on the day - RPM - coolant temperature (ºFWT) - MPG I like to have MPG up there because when I'm in stealth, it shows 9999 MPG, which I think is wonderful! Like JimboK, I also check my trip and daily info. It's nice to say, "I got 62.9 MPG on my way in to work this morning." |
| Member Join Date: Feb 2006
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Skwyre7 @ Mar 14 2007, 11:07 AM) [snapback]405500[/snapback]</div> Quote:
__________________ Gary SoCalif | |
| Senior Member Join Date: Jan 2006 Location: Washington State
My Car: 2006 Prius Package: #8 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Gadgetdad @ Mar 13 2007, 10:37 PM) [snapback]405225[/snapback]</div> Quote:
I found that the speed was more accurate than the car's speedometer. I still have stock tires. This is the way I mounted it. Now I have a CAN-VIEW V4 | |
My Car: 2005 Prius Package: #4 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | <div class='quotetop'>QUOTE(MPG > HP @ Mar 15 2007, 01:52 AM) [snapback]405911[/snapback]</div> Quote:
My Car: 2006 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | <div class='quotetop'>QUOTE(Allannde @ Mar 15 2007, 02:33 AM) [snapback]405924[/snapback]</div> Quote:
| tip from zaino for new users | SSimon | Care, Maintenance and Troubleshooting | 0 | 09-08-2006 03:02 PM |
| Apple Mac Users: I need your help | TonyPSchaefer | Fred's House of Pancakes | 8 | 06-12-2006 10:29 PM |
| Most users ever online | aka007ii | Prius Main Forum | 6 | 12-03-2005 12:19 AM |
| 500+ Users now at Priuschat!!! | Danny | Prius Main Forum | 2 | 01-21-2004 07:04 PM |
| 200 Users! | Danny | Fred's House of Pancakes | 3 | 12-17-2003 07:50 PM |
