| Prius Modifications This is a discussion on 2007 non-JBL tweeter upgrade within the Prius Modifications forums, part of the Toyota Prius Forums category; I'm no expert at installing this stuff, and I couldn't see as much detail as I would have liked on ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I'm no expert at installing this stuff, and I couldn't see as much detail as I would have liked on upgrading tweeters in my non-JBL 07. The stock component is 1.5" dia. x .25" deep, and I wanted to use the stock door pillar housing without taking the door panel off. The Polk's worked perfectly as described in the pictures below. I found them at Circuit City for $49, perfect for my budget and I've had good luck with other Polk products. [attachmentid=8762] First I had to remove the stock tweeter. The door pillar housing is held on in two places, a standard nylon door panel fastener at the bottom and a special metal clip at the top, which is very easy to loose in the process of taking the housing off. [attachmentid=8763] Start at the bottom and pull the housing away from the door. The top will now be free enough to see the metal clip, just above the shiny nut exposed when you pull the housing away from the door pillar. If you have a small flathead screwdriver, you can use it to push the window side of the clip and may get it free intack. If not, have a tweezer AND needle noze handy to fish the clip out for reuse. Next challenge was to get the tweeter element out of the Polk housing. It is held in with high temp, non-hardening glue. Using a modeling knife, I cut around the inside edge of the plastic and slowly, gently, pried the metal tweeter element out. Be VERY careful not to put any pressure on the face of the tweeter, as it is very fragile once removed. Also, keep any metal objects away from the tweeter element, as the very strong magnet will try to paste the nearest screwdriver to the delicate speaker dome. [attachmentid=8764] To make the Polk tweeter fit required a few layers of electrical tap so it fit snugly in the tweeter housing. The crossover is small enough it also tucked very nicely into the unused space in the same housing. The molex takes care of connecting the door speaker in parallel, and the polarity can be discerned from the stock tweeter - lead to the capacitor is positive (+). Some solder and heat shrink and my upgrades went back in pretty as a picture. [attachmentid=8765] [attachmentid=8766] Next, subs behind the rear seats. A couple of 10" ought to do nicely. Cheers! |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Looks great... again, how do they sound? I'd love to do some minor upgrades to my non-JBL system. Frankly, i'm pretty happy with it, but I could use some clearer highs and some more prominent low-mids. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(mmoncur @ Jun 12 2007, 05:59 AM) [snapback]460024[/snapback]</div> Quote:
| Picture of the base non jbl tweeter and pillar in a 2007 | Elephanthead | Audio and Electronics | 0 | 06-23-2007 06:40 PM |
| JBL System Upgrade on 2007 Touring | Cox | Audio and Electronics | 11 | 06-13-2007 07:13 PM |
| 2007 package #4 navi upgrade | shl7c | Prius Technical Discussion | 3 | 06-04-2007 12:46 AM |
| Upgrade from 2005 Prius to 2007? | dvandelay | Prius Main Forum | 18 | 03-12-2007 10:17 PM |
| My Rear Tweeter is going out. | TimeFor | Audio and Electronics | 0 | 03-27-2005 06:06 AM |
