| Prius Modifications This is a discussion on Turn Signal Mirror wiring issue - help? within the Prius Modifications forums, part of the Toyota Prius Forums category; Ok, I received a set of the turn signal mirror casings from Tommy to "test" and "ensure that they are ... |
| issue, mirror, signal, turn, wiring |
| Admin/Founder Join Date: Nov 2003 Location: Columbia, SC
My Car: 2006 Prius Package: #8 Nominated 26 Times in 8 Posts TOTM Awards: 1Friends: 25 | Ok, I received a set of the turn signal mirror casings from Tommy to "test" and "ensure that they are up to PriusChat standards" (that's how I sold it to Nichole, at least). I've got the physical installation of the mirror housing done, but now I have no idea what to do with the wiring. I looked back through previous threads (and read almost the whole huuuuge thread), but cvouldn't find exactly what i was looking for. The set I received only has 2 wires coming from the mirror - a red and a black. No wiring harness or anything like that that others had reported (it seemed like the harnesses were on both the JDM ones and the ones from our friend in HK, Tommy). So now I'm sitting with 2 bare wires and have no idea what to do with them. Should I add more wire to them and run them back to the rear turn signal wires? Ideas? And, just a bit of news, but the PriusChat Shop will soon be carrying them and we'll kick off selling them with a big Group Buy so that those who have waited can get a good price.
__________________ PriusChat Offers Discounts on: Extended Warranty - $990 : Pre-Paid Maintenance - $875 : HeatShield SunShades : BT Tech Stiffening Plate : All other Prius Accessories |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Danny @ Jul 13 2007, 04:33 PM) [snapback]478356[/snapback]</div> Quote:
| Senior Member Join Date: Mar 2004 Location: Burbank, California
My Car: 2004 Prius Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Danny, Congrats on getting the new signal mirror covers. I bought a set about 6 months ago and they work great. I've attached the 2 documents that helped me when I did the install. You might have already seen these files but they helped me out alot. Basically you need to run the wire through the door, and into the rubber tube between the door and the frame (no easy task, at least the first time). Then you can patch the wire into the wiring block as shown in the documents. Obviously you need to be careful not to cut or pull any other wires or you might have problems. I'm sure some others can chime in with other tips as I know there was quite a few people who did the install. -Peter B |
| Senior Member Join Date: Apr 2006 Location: WC Florida
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Danny, you should ask Tommy about including the wiring harness he supplied in his first kits. I tried to suggest back on Oct 30th that the instructions seemed to indicate plugging the turn signal relay into the harness and then plug the harness where the relay had been, but got no response from all the others so let it die. It actually worked very good in as far as I had to do no splices or taps into the OEM wiring. And the turn signal relay will mount to the side of the panel where it was removed from so its not loose nor has to be tied down. By using the supplied harness, to revert back to original just re-install the relay where it was and the mirror signal leds are out of the picture. The bad part of the harness Tommy supplied is that, for me anyway, the cable to the pass side is too short, the connectors wouldn't connect (male to male) and maybe the wiring to the drivers mirror was short too. What I did was shorten the cable intended for the pass side and use it for the drivers door mirror. Then I made up a new cable to run to the pass side. I replaced the mismatched connectors with ones from Radio Shack, about $6 for 3 sets. BTW, the red wire is +, you can touch the wires to a 9v battery to confirm and verify the leds work. Anyway, the short story is that the installer doesn't have to alter any Toyota wiring, just the signal mirror wiring, so less worry about messing it up. I'm on a trip now and won't be home until around August 1st, so can't add too much more now. If you want some help writing up install instuctions, and could get Tommy's harness, I would be glad to assist. I'd even like to buy another harness just to get the relay connectors in case I want to do this to another Prius in the future.
__________________ '06 Barcelona Red Prius '00 Chevy S10 ExtCab |
| AmeriKan Citizen Join Date: Apr 2005 Location: San Diego, CA
My Car: 2005 Prius Package: #1 Nominated 3 Times in 2 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(prberg @ Jul 13 2007, 05:34 PM) [snapback]478387[/snapback]</div> Quote:
Would anyone want to take on the task of step by step directions (with pictures) from taking the door panels and mirrors off to putting them back on again? Something like I did with the buzzer install? I want side signal mirrors but am going to have to do this myself and I need both pictures and step by step from very beginning to very end. Thanks. And thank you Danny, for the possible opportunity of a group buy on this. Question: do they come in our Prius colors or would I have to get them painted before installing? | |
My Car: 2004 Prius Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Godiva, there is a pretty good step by step if you take a look at the attached word document in my first post. From my experience the mirror covers are already painted to match your car, so you just have to give them your paint code (or color name). -Peter B |
My Car: 2005 Prius Package: #1 Nominated 3 Times in 2 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(prberg @ Jul 13 2007, 07:18 PM) [snapback]478415[/snapback]</div> Quote:
You doc show the panels under the steering wheel and on the driver's door already removed. So I have to hunt around somewhere for directions on how to do that because they're not included in this doc, but they're necessary to do this install. Your last picture still shows the housings on the ground not attached to the car. Is that because the mirrors come with directions on how to attach them to the car but NOT how to attach the wires? So...I'm looking at three different places to find three different sets of directions. Get it? I'm looking for a one-stop-doc. That's why I included how to disable the Prius reverse beep in my buzzer install directions, because you need to do it as part of the install. | |
| Electrical Engineer Join Date: Jan 2007 Location: Camas, WA
My Car: 2007 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Danny, you are going to love those new LED mirror signals. Call me crazy, but I enjoy changing lanes whenever I am near another Prius so they can see my Mirror Signals and know they are special. I am alway hoping one of the will flag me down and ask about them, but without the mirrow signals, they cannot flag me down. Ironic, isn't it. I better not add a sunroof, or I might be sticking my head up through the roof whenever I pas another Prius. P.S. I love ALL Prii! <div class='quotetop'>QUOTE(prberg @ Jul 13 2007, 03:34 PM) [snapback]478387[/snapback]</div> Quote:
__________________ Lightning Green McQueen, and owner Larry 2007 Pkg 5, Jan 2007 with modifications: Toyota Mudguards Feb 2007 LED Signal mirrors March 2007 Wheelskins Leather Steering Wheel March 2007 ScanGuage II, March 2007 BT Tech Stiffening Plate, March 2007 Nokian WR 195-60R-15 tires, Nov 2007 Solar Gaurd window tint, Feb 2008 Fog Lights on idependant of headlamps, Feb 2008 BT Tech Strut Tower Brace, April, 2008 | |
My Car: 2004 Prius Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | It's true that the info is scattered over a few different documents, I guess I was surprised that the info even existed and it was enough for me to get them installed pretty easily. As FL Buckeye says, it would be great if they had wiring harnesses that just plugged in somewhere. Would make it alot easier. I included another document (it's probably somewhere on the board already) that shows a full teardown of the dashboard. I was able to see how to get the panels off with those 2 documents. But I agree that it would be easier if all the info was included in one easy document. It would be great if the covers actually came with instructions that were as detailed. The info that came with mine was very vague and did not help me much. oh and I can't take credit for creating these documents... I just found them here on Priuschat. The good breakdown of the wiring for the signal mirrors was thanks to Horacio. good luck, -Peter B |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I did my wiring by running the red/back wire pairs all the way to the rear backup lights. Of course, they are NOT visible in plain sight. If you got a signal tracer, you may be able to tap into wires near the front doors. |
| Turn Signal DRL Installation Instructions | CinciPrius | Knowledge Base Articles Discussion | 14 | 09-08-2008 07:51 AM |
| turn signal short? | 98clru | Care, Maintenance and Troubleshooting | 7 | 09-19-2007 11:21 AM |
| E-Bay Turn Signal Mirrors-HELP | cairo94507 | Prius Modifications | 6 | 10-22-2006 02:00 PM |
| Side turn signal cut out pattern | TheForce | Prius Modifications | 11 | 04-26-2006 05:50 PM |
| How do we turn off the turn signal flash? | jillsidious | Prius Main Forum | 9 | 01-10-2005 02:37 PM |
