Prius Modifications This is a discussion on Rear Bumper Applique within the Prius Modifications forums, part of the Toyota Prius Forums category; Hi! I'm a newbie to this board. I bought my 2005 Prius (with a lot of help from my cousin ...
Old 08-30-2007, 09:03 PM   #1
pink70
pink70's Avatar
Hi! I'm a newbie to this board. I bought my 2005 Prius (with a lot of help from my cousin in FL!) one month ago. I absolutely love this car, and consider myself quite lucky since pre-owned Priuses seem to be a rare breed of car here in central OH.
Anyway I've been "lurking" here since I got my Prius and have learned a lot from the posts I've read. I have bought the rear bumper applique and was planning on installing it this weekend. The instructions are a little more involved than I anticipated, and I was wondering if anyone had any tips on installation from previous experience.
Thanks!
pink70 is offline
Old 08-30-2007, 09:53 PM   #2
Bear68
Nominated 3 Times in 1 Post
Friends: 5
Piece of cake!
Clean the area well with alcohol.... Not the type that come in a can.... :P Rubbing alcohol works very well... Then simply center up the applique and carefully peel back a very small section of the backing paper and press it down gently. If you need to lift and reposition it you will be able to do so. Then carefully peel the backing off and spread it down gently working from the center out. watch for airbubbles as you go and take you time. A clean dry surface is important!! Also, if you lay the applique out in the sun for a while, it will be a little more pliable and easier to install.
Toyota Ceritified Master Diagnostic Tech, Prius Certified
"The only foolish question is the one left unasked."
Bear68 is offline
Old 08-31-2007, 12:43 AM   #3
dogfriend
Human - Animal Hybrid
dogfriend's Avatar
Friends: 7
I installed one on my car. We discussed the installation in this thread:
http://priuschat.com/index.php?showtopic=1...hl=Marine+Clean
dogfriend is offline
Old 08-31-2007, 08:34 AM   #4
pink70
pink70's Avatar
Thank you both! I figured there was a thread on this somewhere but it did not pop up on any of my searches.....
I couldn't find the 3M cleaner either. And the instructions I have say to spray with a very dilute dish detergent solution and squeegee out.
I'll give it a whirl! Fingers are crossed that I don't screw it up!
pink70 is offline
Old 08-31-2007, 10:19 AM   #5
dogfriend
dogfriend's Avatar
Friends: 7
<div class='quotetop'>QUOTE(iggypup1 @ Aug 31 2007, 05:34 AM) [snapback]504820[/snapback]</div>
Yes, just a couple of drops of dishwashing detergent in a regular size spray bottle (32 oz.) It is very similar to installing tint film in a window, if you have ever done that. Spray the area throughly so that you can "float" the decal over the surface and position it where you want, then start to squeegee the water out starting at the center and working out to the sides.
Old 08-31-2007, 10:49 AM   #6
seasalsa
seasalsa's Avatar
Send a message via AIM to seasalsa
If you want more than a decal and something that will give you some real protection try:
http://www.brandsport.com/toy-pt278-02050.html
seasalsa is offline
Old 09-02-2007, 08:35 PM   #7
pink70
pink70's Avatar
[attachmentid=11069]
Done today! I'll rate it as a success - I have one teeny bubble that I can't seem to work to the edge, but everything else looks good! Thank you all for your help! Here it is:
pink70 is offline
Old 09-02-2007, 08:57 PM   #8
dogfriend
dogfriend's Avatar
Friends: 7
<div class='quotetop'>QUOTE(iggypup1 @ Sep 2 2007, 05:35 PM) [snapback]506082[/snapback]</div>
The teeny bubble may disappear on its own after whatever soapy water is trapped in there eventually evaporates away. Resist the temptation to pop the bubble with a sharp point - this will let dirt in - I tried it on the first decal. On the second decal (that the body shop installed after my bumper was repainted) I left the bubbles alone and now they are not noticeable.
Old 09-04-2007, 05:20 PM   #9
prius2go
that looks good - where from?
I was going for one of those black mat things
prius2go is offline
Old 09-04-2007, 06:42 PM   #10
dogfriend
dogfriend's Avatar
Friends: 7
<div class='quotetop'>QUOTE(prius2go @ Sep 4 2007, 02:20 PM) [snapback]506928[/snapback]</div>
The decal is available as an accessory from US Toyota dealers. I don't know if it is also available in the UK, but I would inquire at the Toyota dealer.
Rear Bumper Applique slowpoke Prius Modifications 12 06-04-2008 08:51 AM
Has anyone gotten the rear bumper applique Bill Compton Prius Modifications 65 02-18-2006 07:18 PM
New Rear bumper Applique/Protector johnnieliu Prius Main Forum 4 01-22-2006 09:01 PM
Rear Bumper Applique Claudia Prius Main Forum 4 05-08-2005 07:35 PM
Rear bumper applique after-market? cyclone Prius Main Forum 7 01-16-2004 10:14 AM
