Prius Modifications This is a discussion on going lower. . .inserts. . . within the Prius Modifications forums, part of the Toyota Prius Forums category; Originally Posted by cairo94507 Anytime you are switching out springs which raise/lower a car you need to have it realigned. ...
lower, suspension
LinkBack (4) Thread Tools
Old 05-29-2008, 08:59 PM   #31
prius70
Default Re: going lower. . .inserts. . .
Originally Posted by cairo94507 View Post
Anytime you are switching out springs which raise/lower a car you need to have it realigned. BTW the TRD suspension lowered my car about 3/4".
agree!!
i think the blitz springs alone were about an 1inch drop up front and a little less out back.
it would be nice to drive around in different cars with different lowering springs/struts. . .blitz, trd, montegi. . .to compare the ride and height, etc. . .
i posted some tape measurements pics with the blitz springs installed in a different thread. this should be close to what you'll get with springs alone. search under "blitz" as title of thread. . .
get some camber kits for the front in case you need them to correct camber alignment at the alignment shop. ebay item. . . around 15 dollars a set shipped.
good luck!
prius70 is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-modifications/46059-going-lower-inserts.html
Prius Modifications: Blogs, Photos, Videos and more on Technorati This thread Refback 05-03-2008 01:44 PM
Filling Tires with Snake Oil « Jim’s Garage This thread Refback 04-23-2008 10:01 AM
Mercedes 40-MPG Diesel Hybrid: Cleanest SUV on the Planet : Gas 2.0 This thread Refback 04-22-2008 07:46 PM
EBH--lower wattage and lower temp...? cold related? efusco Prius Modifications 3 02-03-2008 02:30 PM
New Tires = Lower MPG???? Help!! s.e.tx_parrothead Fuel Economy 4 06-12-2007 12:13 AM
New fton wiper inserts streak and skip - may have solved it? SebMike Care, Maintenance and Troubleshooting 0 02-14-2007 05:59 PM
Strange Inserts bogeybob513 Prius Main Forum 2 12-22-2006 02:00 PM
New Wipers or New Wiper inserts? Driver side wiper size? Eug Care, Maintenance and Troubleshooting 7 01-23-2005 12:45 PM
