| Prius Modifications This is a discussion on Costs of a PHEV system. within the Prius Modifications forums, part of the Toyota Prius Forums category; Originally Posted by Cheap! Dmckinstry, Yes I have been using Clean Domestic Wind Energy and I would like to get ... |
| costs, phev, system. |
| | #11 | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Quote:
I originally thought I'd to the PHEV conversion myself. Unfortunately, my wife and I are down to one car now. At the rate I do things, a conversion would leave me without a car for months. I decided to go with Hymotion, even though it would be more expensive and Hymotion's L5 doesn't incorporate regenerative braking. After a trip to the Denver area and back by way of Reno and Sacramento, I noted that the NiMH traction battery didn't get that overfilled, even after a trip down the eastern side of the continental divide. So, regenerative braking through the L5 might not make that much difference anyway. OTOH, discharging and recharging on the lithium ion should have been more efficient, so I still wish they had designed in regenerative braking. Oh well. Dave M. | |
| | #12 | |||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Quote:
I am starting an open source group for an open source charger, an open source BMS, and an open source CAN spoofing board. I'm not sure where to begin but I know it needs to be done! This would be all not for profit. Quote:
Thank you aminorjourney! You get my point. Yes Plug-ins work but the cost is still to high to bring them mainstream. There are ways to bring the cost down. 1. A good charger for less than $1,000.00 U.S. Lets build one for about $200 in parts at home. 2. A good BMS for Li-ion/LiFo batteries. One that checks every cell for a minimum of parts that can be built at home. for $200.00 U.S. total. 3. The box problem has been solved as you can get one built at any metal shop for about $100.00. You'll have to add about $25 in when you get it home. 4. Can-view cost has to come down and the auto industry makes a CAN reader/tester = Spoofer for about $200.00. We could open source that and bring it down to around $50.00 I don't see any reason more open source work on PHEVs could not bring the cost down to $1,000.00 for everything except batteries. With group buys that could come down too. Quote:
Dave a PHEV conversion can be done now without the car being down. You can do it in a few weekends and still drive it. Many of the parts can be made by yourself so you can keep the cost down. Please contact me if you think you can contribute to an open source project for the Charger, BMS, or the CAN Board. There is a lot of data on this on the web already but I just don't have the time to track it all down. The goal would be to keep all the costs for the converter down to a minimum so we can put more on the road. Lead-Acid is out so now we need to look to other alternatives. Yes a second Prius battery is a cheap way to go but we would need Mrbigh’s input on how far you can go with just one or two extra packs.
__________________ * Classic Silver, Prius Plus Plug-in Hybrid Electric Vehicle Conversion *EV Button* Free Reverse Beep Mod, *Mirror Mod, * Aerodynamic hubcaps, * Almost Free Anytime Reverse Video, *Anytime Forward View Video, *Fumoto F103N Oil Drain Valve, *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch, *Dual Microphone Mod *In Dash DVD Theater, *V4 CAN-View </span> <span style="color:#FF0000">Mods wanted in the near future - Hydraulic Brake -Pressure Indicator -Hobbits Vacuum “Good vs. Bad” Driving Indicator | |||
| | #13 |
| Mum to two prius! Join Date: Jan 2007 Location: Bristol, UK
My Car: 2007 Prius Package: T Spirit Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Cheap, I think I've found a cheap source of OEM batteries from Prius converted to use completely new PHEV packs. I think the cost of two extra OEM batteries will be cheap enough for me to be able to afford the conversion. A 10 mile range would be what I'd hope for as a minimum for EV only operation. Ideally 15-20 miles would be great. I'll document if I do it As for costs, I know where you're going with the charger costs. Although I'm not sure I'd want to build a cheap charger at home. I've had bad experiences in the past and prefer to buy in those. The CanView I thought was rather good value for money, although that may have something to do with the general high cost of everything in the UK and the fact that the CanView worked out at just over 150% of the cost of the SLi Interface I got at the same time! Regards, Nikki.
__________________ Twice the trouble. "Velma" 2004 T4, awaiting PHEV conversion "Daphne" 2007 TSpirit ------------------------------------------------- http://www.aminorjourney.com |
| | #14 | |
OTOH, apparently the batteries in Hymotion's L5 kit account for about $6k. If their pack uses the A123's developer kits, it would require 100 kits at $110 each (or a total of $11k) for the batteries alone. Of course, I would hope the 600 batteries (each with ~7.6 W-hr) ordered all at once would be less expensive. I didn't contact A123 about fleet sales, however I did order one $129 kit. I want to do some of my own testing. Again thanks for the info. Dave M. | |
| | #15 | |
| Geocacher Join Date: Jul 2008 Location: Spokane, WA
I do agree with WA needing the incintives that CA does. How can we go about getting this type of money on This side of the state. The Steaks (Spokane, WA) | |
| I always wondered why gas costs so much elsewhere | tasker109 | Prius Main Forum | 4 | 05-30-2008 06:39 PM |
| Car insurance costs? | busyrosy | Prius Main Forum | 9 | 04-27-2006 05:15 AM |
| Maintenance costs | Considering | Care, Maintenance and Troubleshooting | 7 | 06-03-2005 12:37 AM |
| maintenance costs | etack | Prius Main Forum | 17 | 03-19-2005 12:02 AM |
| Repainting costs | jasond | Care, Maintenance and Troubleshooting | 6 | 04-12-2004 06:45 PM |
