Prius Modifications This is a discussion on LED brake lights? within the Prius Modifications forums, part of the Toyota Prius Forums category; Hi all, Has anyone fitted some LED brake and turn lights ? Be interested to here about it.. Edit: doh!...
led, lights
Old 07-23-2008, 09:54 PM   #1
Dozzer
Prius Noob
Dozzer's Avatar
Package: T4
Question LED brake lights? [Standard equipment]
Hi all,
Edit: doh!
Dozzer is offline
Old 07-23-2008, 10:45 PM   #2
narf
narf's Avatar
Default Re: LED brake lights?
The brake lights are LED already. LED turn and running lights are as easy as the local auto parts store.
narf is offline
Old 07-24-2008, 03:10 AM   #3
Dozzer
Prius Noob
Dozzer's Avatar
Package: T4
well.. I gotta take a look later on.
I've had a look and they are definately filament bulbs in there... not an LED in sight!
Mine is a UK spec Prius 2008 T4 model.. with filament bulbs in the brake lights.
Everywhere I look on google points to LED brakes.. hmm I'll take a very closer look after work today.
It looks that from this post that the UK spec only has LED's in the eye level brake light..
Just Ordered!
Anyone in the UK fitted LED's all round on the brakes?
Dozzer is offline
Old 07-24-2008, 03:52 AM   #4
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Nominated TOTM Awards: 1
Friends: 53
Cool Re: LED brake lights?
Welcome to PriusChat Dozzer!
The Toyota GB web site touts the LED brake lights: Stylish LED brake lights give Prius an extra air of sophistication. But typically for the ground-breaking hybrid, they also offer functional benefits of greater energy efficiency, quicker illumination and stronger visibility.
I got to that by choosing Prius and then Explore. Spin the car around to see the rear, then choose the hot-spot by the brake light. All the other lights are regular filament bulbs, but the brake lights, and center high-mounted stop light, are LED.
Bill Merchant is offline
Old 07-24-2008, 05:28 AM   #5
Dozzer
Prius Noob
Dozzer's Avatar
Package: T4
aha... turns out I was looking in the wrong place.. the brake lights are indeed LED.. and are mounted almost in-line with the high level brake light.
Dozzer is offline
Old 07-24-2008, 06:42 AM   #6
clooch
clooch's Avatar
Send a message via AIM to clooch
Bill, are those LED's only a package specific thing? my 08 pkg 2 sure does look an awful lot like a filament bulb in there. looking at a few lighting web sites, most refer to the same filament bulb. I know the third (high mount) brake light is led. I am also looking for LED's but haven't seen any that I like yet.
any insight would be appreciated
Last edited by clooch; 07-24-2008 at 06:49 AM. Reason: lack of coffee started off w/ wrong name
clooch is offline
Old 07-24-2008, 11:29 AM   #7
narf
narf's Avatar
The brake lights are at the very top of the tail light assembly. That chrome section with all the fins in it. There is an LED in each fin. They are in ALL US Prius', probably worldwide but I can't say that for sure. The rest of the sections are bulbs. If you want to replace the rest of the bulbs with LEDs many auto parts stores sell plug-in replacementsClick the image to open in full size..
narf is offline
Old 07-24-2008, 12:11 PM   #8
V8Cobrakid
some guy...
Send a message via AIM to V8Cobrakid Send a message via Yahoo to V8Cobrakid Send a message via Skype™ to V8Cobrakid
Friends: 5
yeah.. every prius comes with this design
there are 6 LED's per housing. 24 in all (12 LED's across the hatch)
if you stand just to the side of these units and look down, you'll see the LED bubbles arranged on a Horizontal pattern facing up into those brake reflectors.
V8Cobrakid is offline
Old 07-24-2008, 10:09 PM   #9
A strolling player
You're most likely looking at the tail lamps. The LED brake lights are above the indicators and reverse lamps, and the tail lamps are at the bottom and indeed filament-based.
A strolling player is offline
Old 07-25-2008, 12:40 AM   #10
yunebug
Saving the world!
yunebug's Avatar
Send a message via AIM to yunebug
If you want to replace the rest of the bulbs with LEDs many auto parts stores sell plug-in replacements.
But isn't there amperage draw issues involved with that? My previous experiences with switching LEDs into turn signals always stipulated that I purchase a resistor of some kind to keep the ECU to think that there is a filament bulb in there.
A normal filament turn signal bulb (single filament, in this case, apparently), is a 12v system of 12v and GRND. Each bulb draws a certain amount of amperage every time the filament is lit and the LED replacement bulbs draw significantly less power. In such case, the ECU will assume that the bulb is out and typically double the flash rate to alert the driver (rapid blinkers = bulb is out... according to the ECU anyway).
I would LOVE to have LED turn signals. Has this been done?
You can't scare me... I teach high school.
Scion TC Wheels on General Exclaim UHP • Fog-only mod • EV Button • Window Tint • Shark-Fin Antenna
yunebug is offline
Tail and license plate lights went out -- brake lights work dialwmd Care, Maintenance and Troubleshooting 13 08-25-2008 04:27 PM
ABS Brake warning lights boriqua9719 Care, Maintenance and Troubleshooting 1 02-26-2008 08:01 AM
ABS VSC Brake warning lights on lifestages Care, Maintenance and Troubleshooting 9 03-21-2007 06:23 PM
Red Brake, ABS, VSC warning lights mhcoates Care, Maintenance and Troubleshooting 2 09-06-2006 07:36 PM
ABS/VSC/Brake lights on wiluspyder Prius Technical Discussion 10 08-23-2006 12:14 AM
