| Prius Modifications This is a discussion on Adios Wimpy Horn within the Prius Modifications forums, part of the Toyota Prius Forums category; Just finished installing the PIAA horns in replacement of the stock wimp-omatic horns. I searched the forums and found using ... |
| adios, horn, wimpy |
| Junior Member Join Date: Mar 2008
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Just finished installing the PIAA horns in replacement of the stock wimp-omatic horns. I searched the forums and found using the Radio Shack crimp on quick disconnects the easiest and cleanest way to swap the new horns for the old ones. (Radio Shack part numbers 64-4040 and 64-3133) Total time for install was less than an hour and I took my time. I purchased the PIAA horns from Amazon for $45 and another $4 at Radio Shack. I'm very happy with the sound of these horns, however am still considering air horns for these crazy NYC streets! Thanks to the Prius Forums for the idea. |
| _ . _ . / _ _ . _ Join Date: Mar 2008 Location: Los Angeles
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Hi there, Yep I have a pair myself, don't they sound sweet!!! They defiantly make a difference!! And your right, so simple to install!! 73 de Pat KK6PD |
My Car: 2004 Prius Package: Pioneer #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | Sorry, but isn't the point of a horn to blast an annoying noise? An appealing sound is counter-productive for a warning device. . |
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 13 | NYC and KK: How did you guys access the two horns' wires/connections? Did you have to remove the grille? |
| | #5 | ||
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Quote:
I was able to access both horns this way, however the drivers side was easier!!! Quote:
Not at all, You can have a horn that is loud, with 2 frequencies beating 100hz apart from each other and still grab the attention of the folk around you. If I wanted annoying I would have opted for a horn off of a GP-5 Diesel Electric Locomotive!!! Just think, you could be heard 5 miles away!!!! 73 de Pat KK6PD | ||
My Car: 2007 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 13 | Quote:
When I adjusted the volume/tone screws on my OEM horns, I knew I couldn't reach the wires/connectors from above. If I ever do change horns, I guess I could also lubricate the grille and/or the palm areas of my hands or latex gloves if I wear them. Last edited by Boo; 08-23-2008 at 05:18 PM. | |
My Car: 2008 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 1 | Its not really that tight, I pulled it apart, and then wedged a rag in to keep it spread apart!! I unbolted first, lifted up and then unplugged! Makes it easy that way, of course assemble in reverse order!! 10 minutes have fun de Pat KK6PD |
My Car: 2008 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | For the first horn, the one right underneath the hood latch, I didn't even have to loosen the grill. I put a ratchet down there, loosened the bolt and disconnected the wire. I used the Radio Shack crimp connectors I mentioned to make the extensions. You only need about 3" of extension and the horns come with the wire. I loosened the grill for the second horn near the passenger side headlight. Just remove the 2 Phillips screws with the rubber grommets and use a small flathead screwdriver to pop the top of the pins and pull the grille back as far as you need. It won't break or even crack the paint. |
| Wimpy API Oils | FL_Prius_Driver | Care, Maintenance and Troubleshooting | 5 | 02-07-2008 04:54 PM |
| What's up with the horn?? | PriuStorm | Prius Main Forum | 18 | 09-30-2007 02:02 AM |
| Where's that horn? | tessar | Prius Main Forum | 54 | 09-08-2007 07:44 PM |
| Upgrade Wimpy Dashlights on a Classic? | kenmce | Prius Modifications | 0 | 08-14-2007 09:43 PM |
| Hatch lifts wimpy in cold weather | genalex | Prius Main Forum | 12 | 02-25-2007 05:51 AM |
