| This is a discussion on Has anyone installed the enginer PHEV? within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; Originally Posted by toddwking Both trips the BMS alarm went off (ie. started beeping after 60-70 miles - also good) ... |
| | LinkBack (41) | Thread Tools |
| | #111 | |
| Senior Member Join Date: Jul 2009 Location: Michigan
My Car: 2004 Prius Model: N/A Package: Base Thanks: 32
Are you referring to the BMS for the Prius or the add-on system? When you say the alarm didn't shut off until the system was charged, do you mean the OEM pack or the add-on pack? I would hate to get to work with that thing beeping and have it continue all day long until I got back home (no place to charge at work presently) to recharge. Or for that matter, going on a cross-country trip w/no place to recharge either. | |
| | #112 |
| Senior Member Join Date: Jul 2005 Location: Raleigh, NC
My Car: 2004 Prius Model: I Package: #7 Thanks: 9
Friends: 10 | Ordered my 4kw kit with an extra converter. Should arrive in 15-20 days and I will install it myself shortly thereafter. I have a 136 mile r/t commute so this will provide highway assist mostly. If the results are satisfactory I will upgrade to 6 or 8kw. Updates to follow. |
| | #113 | |
My Car: 2005 Prius Model: Package: Thanks: 24
Friends: 11 | Quote:
| | #114 |
Friends: 10 | 4kw in the box, 2kw in place of the spare (possibly). |
| | #115 |
Friends: 11 | depends on how the voltage is setup if you have a 16 cell 2kwh pack = 16 cells in series ( i think is the input not 48 volts? dc-dc? ) and so that make's up for 52 volts ( 16 x 3,2v cells ) so with a 32 it not in series but in parallel ( lets hope someone can confirms this ) then you simple parallel a new pack.. but when its all in series.....then its a diferent story |
| | #116 |
Friends: 10 | Multiple 16 cell 2kwh packs can be connected in parallel. |
| | #117 |
| Youngest PHEV Driver? Join Date: Sep 2008 Location: West Covina, CA
My Car: 2009 Prius Model: N/A Package: #5 Touring Thanks: 3
Friends: 7 | Finally! I've actually ordered the kit! So, It's arriving at my house on Saturday!!! I'll be removing my Plug-in Supply kit in the morning and possibly installing the new kit a few hours after that.. depending on when the thing arrives. Sad part was, Jack wasn't able to send me the second string of batteries because they come from overseas. I purchased the 4kwh kit. The extra 2kwh batteries will be coming in sometime in 15-24 days. Anyone want to buy a used(it's basically new :P) Plug-in supply kit? If this works out well... I will definately be putting in another 2 or 4kwh into the system. |
| | #118 | |
| Senior Member Join Date: Mar 2009 Location: new york
My Car: 2006 Prius Model: Package: #2 Thanks: 5
Friends: 3 | Quote:
| | #119 | |
| Member Join Date: May 2009 Location: Troy, Michigan
My Car: 2002 Prius Model: II Package: No Package Thanks: 24
Don't need group buy. We are offering $500 discount for limited number of pilot testers who provide 30 day trip log for product improvement and marketing purpose in first come first serve basis. We need your help to push the PHEV movement forward. We hope the automakers can put this kit in the new hybrids so that it would be qualified for $2500 federal tax credit. Then it becomes free for all of you. | |
| enginer, installed, phev |
| Has anyone in Canada gotten a PHEV plugin kit installed? | timriley | Local Prius Club Main Forum | 4 | 04-14-2009 04:20 PM |
| Phev: Why Not Now? | rpatterman | Prius and Hybrid News | 23 | 06-26-2008 12:36 PM |
| PHEV | mrbigh | Gen II Prius Modifications | 3 | 06-21-2008 12:33 PM |
| EBH and PHEV | miscrms | Gen II Prius Modifications | 8 | 09-29-2007 11:44 PM |
| Dealer-installed vs. port-installed options | RClarkofNC | Gen II Prius Main Forum | 9 | 05-24-2005 09:13 PM |
