| This is a discussion on One Year With Hymotion Plug-In Prius. within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; Very nice Jay. You are one of the best PHEV drivers out there.... |
| | #11 |
| "Dream" Prius Join Date: Apr 2007 Location: Cincinnati, KY
My Car: 2007 Prius Model: Package: #2 Thanks: 3
Friends: 6 | Very nice Jay. You are one of the best PHEV drivers out there. |
| The Following User Says Thank You to bestmapman For This Useful Post: | dave77 (10-08-2009) |
| | #12 | |
| Senior Member Join Date: May 2008 Location: SF Bay Area
My Car: 2008 Prius Model: Package: #6 Thanks: 1
I like your suggested improvements - I would also add a way to charge the Hymotion pack via regen braking (although as most of us have seen, due to the spoofing software, there appears to almost always be some room for regen into the Prius pack). | |
| The Following User Says Thank You to zcat3 For This Useful Post: | dave77 (10-12-2009) |
| | #13 |
| Junior Member Join Date: Sep 2009 Location: Pittsburgh
My Car: 2009 Prius Model: N/A Package: #5 Touring Thanks: 2
Friends: 0 | BTW why do youguys want the stock battery charged? I would prefer the stock battery be kept at 50% SOC roughly so that it could actually accept Regen energy. With the hymotion pack there is huge quantities of wasted energy since regen is getting dumped as the stock battery is too full to accept it. I have been contemplating a method to try and regen again, but haven't quite figured it out yet. |
| The Following User Says Thank You to sxotty For This Useful Post: | dave77 (10-27-2009) |
| | #14 |
My Car: 2006 Prius Model: Package: #7 Thanks: 2
Friends: 22 | The Hymotion battery keeps the SOC at about 62% just like the Prius normally would and you can still get all the way up to 80% with regen. On my commute I never see anything higher than 65% so regen is almost useless to me. |
| The Following User Says Thank You to TheForce For This Useful Post: | dave77 (10-27-2009) |
| | #15 |
| Junior Member Join Date: Feb 2005
Friends: 0 | I own an 2008 Prius (love it) and am researching whether to buy a 2008 Prius with the Hymotion plug in upgrade. All the posts here are very positive. 2 major questions: `1) li-on battery life? - I read somewhere that estimated life is 5 - 6 years. 2) Is the Toyota warranty voided if non-dealer installed? Also what is the 52 MPH hack? On my 2004 I had a gizmo installed that allows me to stay in electric mode up to about 32 MPH. Martin jazzpsy@gmail.com |
| The Following User Says Thank You to jazzpsy For This Useful Post: | dave77 (11-02-2009) |
| | #16 | |
Friends: 22 | Quote:
2. No unless Toyota can prove the extra battery caused the damage. 3. I would not use the 52MPH hack with the Hymotion battery since the battery can only supply between 30-40 amps and you need close to or over 100A to get to 52MPH. You can easily drain the stock battery if you try this. There is at least 1 member here ( ibcs )that uses it with the Hymotion with some success but you have to keep an eye on the SOC. For my commute it would be a pain to use.
__________________ 2006 Prius Barcelona Red Package #7. Picked up 2006/01/02 Converted to Plug-In on 2008/08/12 with Hymotion L5 ***Hybridfest 2007 & 2008 Peoples Choice Award *** ***Hybridfest 2009 Peoples Choice Best of Show Award *** For a list of my mods visit http://www.jaygroh.com ![]() | |
| The Following User Says Thank You to TheForce For This Useful Post: | dave77 (11-02-2009) |
| | #17 |
Friends: 0 | "They have been tested for over 9000 charge/discharge cycles and still hold %80 charge." If I leave it plugged in when not in use, is it continually going through charge/discharge cycles? Or is the charge/discharge cycles calculated in a different way? If it is calculated once a day it would tkae 25 yrs. to die. Martin |
| | #18 |
Friends: 22 | 1 charge discharge is like going from 100% to 0% SOC. From what I was told the Hymotion battery goes from 100% to 3%. The 9000 cycles were lab tested and not real world. But if the lab tests are true then the Hymotion battery will out last the car. |
| hymotion, plugin, prius, year |
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/67057-one-year-hymotion-plug-in-prius.html | ||||
| dbg1066's Bookmarks on Delicious | This thread | Refback | 11-01-2009 08:03 PM | |
| One Year of Driving Our BMS+ Plug-In Prius | NWPriusPlus | Prius PHEV Plug-In Modifications | 7 | 09-13-2009 08:34 AM |
| REVIEW: Hymotion Battery Plug-In Prius | TheForce | Gen II Prius Modifications | 290 | 06-03-2009 07:17 PM |
| Toyota confirms plug in 3rd Gen Prius next year. | Wooski | Gen III 2010 Prius Main Forum | 42 | 03-26-2009 08:47 AM |
| A123/Hymotion taking order for Prius Plug in mods this week? | ualdriver | Gen II Prius Main Forum | 7 | 04-26-2008 01:47 PM |
| AfterMarket Plug-In company Hymotion bought | EricGo | Prius and Hybrid News | 3 | 05-20-2007 02:44 PM |
