This is a discussion on Enginer PHEV Technical Information within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; Hello, I am new to the board and am installing a 2kwh system in my 06. I can not get ...
LinkBack (5) Thread Tools
Old 10-29-2009, 09:41 PM   #141
lex28
Model: II
Default Re: Enginer PHEV Technical Information
Hello, I am new to the board and am installing a 2kwh system in my 06. I can not get the enginer system to turn on. The LED's will not light up. I checked t the connections at the computer, everything is fine. Any help would be greatly apprecieated. By the way I have a small round fuse that came in the kit. Anyone know where it goes.
lex28 is offline
The Following User Says Thank You to lex28 For This Useful Post:
dave77 (10-30-2009)
Old 10-29-2009, 10:48 PM   #142
Fibb222
Fibb222's Avatar
Did you turn on the circuit breaker near the charger? The fuse should be an extra one.
Fibb222 is offline
The Following User Says Thank You to Fibb222 For This Useful Post:
dave77 (10-30-2009)
Old 10-29-2009, 11:35 PM   #143
lex28
Model: II
Yes the circuit breaker is on.
lex28 is offline
dave77 (10-30-2009)
Old 10-30-2009, 11:24 AM   #144
atfsi
Model: II
Are these the LEDs on the converter or the ones at the switch ?
atfsi is offline
The Following User Says Thank You to atfsi For This Useful Post:
dave77 (10-30-2009)
Old 10-30-2009, 12:49 PM   #145
lex28
Model: II
After speaking with Jack it appears that the converter might be bad. He helped me trouble shoot the PHEV plug and narrowed it down to the converter. The lights on the switch will not light up, but the converter will have the green light on. I have 50 .5 volts coming into the converter and nothing coming out.?
lex28 is offline
dave77 (10-30-2009)
Old 10-30-2009, 05:16 PM   #146
atfsi
Model: II
On mine, the green LED up front at the switch rarely lights, if at all, but if the green LED on the converter is lit the converter is working...
The red LED at the switch does light when the unit shuts off but it isn't as bright as it could be either....
The switch assembly needs to be replaced w/ brighter LEDs...
Jack B
atfsi is offline
The Following 2 Users Say Thank You to atfsi For This Useful Post:
dave77 (10-31-2009), lex28 (10-30-2009)
Old 11-02-2009, 01:29 AM   #147
kiettyyyy
Youngest PHEV Driver?
kiettyyyy's Avatar
Package: #5 Touring
Friends: 6
Jack B
That means you have a defective switch panel PCB(most likely). It's supposed to light. It's not the brightest in the world, but when installed properly, it's visible during the day.
kiettyyyy is offline
The Following User Says Thank You to kiettyyyy For This Useful Post:
dave77 (11-02-2009)
Old 11-02-2009, 08:57 PM   #148
lex28
Model: II
This is good info to know. Thank you to all. One more question, after connecting my battery bank, all I can get on a charge is 50.6 volts. I am going to use four Hawker SBS 38ah batteries. Could this be the problem on why the converter will not put out power. It might be to low on juice. I read that the batteries I will be using will charge to 1.8 volts per cell? Anyone know what this means? When I spoke to Jack he seamed to think that the converter might be bad. Back to the batteries don't know why I can't get more charge into them? Any ideas? Thank you once again.
lex28 is offline
dave77 (11-04-2009)
Old 11-03-2009, 01:04 AM   #149
coulomb
Could be, but I'm doubtful. Is this 50.6 while on charge, standing idle, or on load?
I'm not completely convinced that small lead acid batteries will work here. 38 Ah lead would be rather marginal, I think.
That makes no sense. However, discharging to 1.8 VPC (per 2V cell, i.e. a sixth of a "12 V" battery) isn't uncommon. That would be a total of 43.2 V at the end of a cycle, which would be like 2.7 VPC for Lithium. That could work.
50.6 V is 12.65 per "12 V" battery, which is about all you'll get from lead acid once the charger is switched off. (With the charger on, you'll get between 13.6 and 14.7 V or even more, depending on the charger). That should be enough to get the converter working, unless the batteries sag to under about 11 V under the ~80 A load.
coulomb is offline
The Following User Says Thank You to coulomb For This Useful Post:
dave77 (11-04-2009)
Old 11-03-2009, 07:17 PM   #150
lex28
Model: II
Well I came home early today and diconnected my batteries. I charged each one of them indivisually and they took a 13.5 volt charge. I am hoping that my charger is not bad, as it will only charge up to 50.6.
lex28 is offline
dave77 (11-04-2009)
enginer, information, phev, technical
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/67182-enginer-plug-in-hybrid-electric-vehicle-technical-information.html
Enginer PHEV Plug-In Unit - Toronto Hybrid Group (Thornhill, ON) - Meetup.com This thread Refback 11-10-2009 08:05 AM
Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader This thread Refback 10-13-2009 08:37 PM
http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums This thread Refback 10-02-2009 10:17 PM
http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums This thread Refback 08-28-2009 06:46 AM
http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums This thread Refback 08-20-2009 06:41 PM
Has anyone installed the enginer PHEV? alevinemi Prius PHEV Plug-In Modifications 669 11-18-2009 07:29 PM
People Who Have Purchased the Enginer PHEV conversion kit!! plugmein2 Prius PHEV Plug-In Modifications 77 11-14-2009 06:03 PM
Enginer PHEV Test Pilot # 1 kammssss Gen II Prius Modifications 6 08-02-2009 10:43 PM
Technical Information Service (TIS) Question airliner53 Gen II Prius Care, Maintenance and Troubleshooting 2 01-01-2008 10:19 AM
