Enginer kit proper break-in charging cycles
Old 06-16-2010, 09:57 PM   #121
2 CARS
dan2l's Avatar
Package: Navigation
Default Re: Enginer kit proper break-in charging cycles
Originally Posted by pbui View Post
early adopter has the old 3000w converter, which the new BMS doesn't shut off with low cell voltage, according to Jack. Can any body confirm that the charge shuffling/balancing is working in the new BMS ? may be we need a new thread for EnginerBMS ?
Pb
Hi Pb,
Yes, you are correct. I am running the BMS16C with a February system. With these older systems the BMS16C does not shut off the converter. However my converter does shut itself down with a red light at a total pack voltage of 45.2v
The BMS16C does much better than the DB8s at balancing. I still see a high group of cells and a low group of cells. After balancing over night there is only about 12mv/cell difference between the high group of cells and the low group of cells.
I still run the CellLogs with loud alarms. the CellLog alarms and the converter red light happen at about the same time.
Hope this is the information that you are looking for.
Thanks,
Dan
Thanks,
Dan2l
2010 Gen3 IV Sandy Beach with 6kwhr Enginer PHEV
2005 Gen 2 Spectra Blue Mica with 6kwhr Enginer PHEV
dan2l is offline
Old 06-17-2010, 12:31 AM   #122
Fibb222's Avatar
Originally Posted by dan2l View Post
Hi Pb,
Thanks,
Dan
Ok, this is fine. I don't need the new BMS to shut down the converter. If my cells are balanced the converter will do that safely on its own. I will really want the plug in and walk away to happen though - that's what really matters to me.
Fibb222 is offline
Old 06-17-2010, 09:41 AM   #123
pbui's Avatar
Hi Pb,
Thanks,
Dan
Thankx Dan - it's a good idea to have the CellLog+Siren as a safety net. I have been running w/o any balancing and the deltaV over night is as low as 6mv in the morning. But underload, the deltaV between buddy pairs are much greater. Let's see if the BMS16C would improve the delta underload.
Pb
pbui is offline
Old 06-18-2010, 04:06 PM   #124
pbui's Avatar
I would worry about discharge a cell too low without the BMS shutdown, or at least some sort of alarm/siren warning of a low cell. It is true that if the cells are balanced, then the converter will shutdown properly. But imagine the pack being at 46v, but a cell being at 1.5v. That single cell is getting killed.
There are two pins, next to the RJ45 plug on the BMS16C, I wander if these are in fact the alarm trigger. If they are, it should be pretty straight forward to rig up a relay to "switch" off since the user switch is just shorting to chassis ground.
For those with the 5000 converter, are these two pins connected to the converter ?
Thx, Pb
pbui is offline
Old 06-18-2010, 07:08 PM   #125
JeffreyDV's Avatar
Thx, Pb
The BMS16C has a 2 wire connection and CAT5 type connection from the converter.
JeffreyDV is offline
Old 06-18-2010, 11:10 PM   #126
Fibb222's Avatar
If the BMS is doing it's job, the cells will be balanced so I won't need to worry about that.
Fibb222 is offline
breakin, charging, cycles, enginer, kit, proper
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/67554-enginer-kit-proper-break-in-charging-cycles.html
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 14 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 12-18-2011 06:53 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 13 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-30-2011 04:38 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 11 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 10-22-2011 10:48 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 28 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 10-01-2011 04:33 PM
外部のサイトへ移動します - 価格.com This thread Refback 07-27-2011 01:22 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 27 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 06-20-2011 11:18 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 26 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 05-28-2011 09:44 PM
価格.com - 外部のサイトへ移動いたします This thread Refback 04-28-2011 02:44 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 21 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 04-19-2011 05:35 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 25 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 04-18-2011 02:52 PM
価格.com - 自動車(本体) 日 - トヨタ のクチコミ掲示板 This thread Refback 04-02-2011 09:30 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 6 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 02-20-2011 05:50 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 24 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 12-08-2010 08:09 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 23 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 12-06-2010 02:15 PM
Project: Zombie Insight (2000 Honda) - Page 6 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 12-04-2010 11:55 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 22 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-29-2010 10:00 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 5 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-21-2010 08:37 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 16 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-19-2010 10:39 AM
価格.com - 『プラグイン化キットの使い勝手』 トヨタ プリウス のクチコミ掲示板 This thread Refback 11-18-2010 07:35 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 11-10-2010 10:58 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 12 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-08-2010 12:36 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 7 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 11-06-2010 01:02 PM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 09-17-2010 03:44 AM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 20 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 09-06-2010 03:18 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 19 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 08-20-2010 11:17 PM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 08-11-2010 11:30 AM
http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums This thread Refback 07-29-2010 10:02 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-23-2010 11:12 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 18 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 07-23-2010 11:38 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-15-2010 10:07 PM
価格.com - 『プラグイン化キットの使い勝手』 トヨタ プリウス のクチコミ掲示板 This thread Refback 07-11-2010 07:51 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-10-2010 09:45 PM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-05-2010 04:55 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-04-2010 09:18 PM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-04-2010 06:48 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-03-2010 11:13 PM
価格.com - 『プラグイン化キットの使い勝手』 トヨタ プリウス のクチコミ掲示板 This thread Refback 07-02-2010 05:27 AM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 07-01-2010 11:09 AM
価格.com - 自動車のクチコミ掲示板 This thread Refback 07-01-2010 07:24 AM
価格.com - 『プラグイン化キットの使い勝手』 クチコミ掲示板 This thread Refback 06-30-2010 10:09 PM
価格.com - トヨタ プリウス のクチコミ掲示板 This thread Refback 06-30-2010 09:26 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 4 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 06-20-2010 08:20 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 17 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 06-15-2010 05:50 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 06-04-2010 03:01 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 05-28-2010 04:39 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 15 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 05-16-2010 08:53 PM
2nd Gen Prius PHEV Conversion (Enginer plug-in lithium ion battery kit) - Page 3 - Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com This thread Refback 05-12-2010 10:46 PM
Long Overdue - SMOG check on motor cycles bedrock8x Environmental Discussion 11 05-08-2009 10:23 PM
Engine tries to stop, but won't, and cycles swiftyprius Gen II Prius Technical Discussion 10 11-28-2007 07:01 PM
Synchonized Cycles as a Driver of Climate Change TimBikes Environmental Discussion 10 10-31-2007 02:13 AM
Lithium-ion batteries: 15,000 deep cycles, 40 years life clett Prius, Hybrid, EV and Alt-Fuel News 15 10-28-2006 09:29 PM
