| This is a discussion on Custom Enginer PHEV (8kWh) within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; Originally Posted by cabledave Was that really necessary? I don't recall the post where everyone selected you to be the ... |
| | LinkBack (8) | Thread Tools |
| | #121 |
| Member Join Date: Feb 2007 Location: 03841
My Car: 2010 Prius Model: II Package: No Package Thanks: 163
Friends: 0 | |
| The Following User Says Thank You to atfsi For This Useful Post: | dave77 (10-12-2009) |
| | #122 |
| Senior Member Join Date: Jul 2009 Location: Salt Lake City, UT
My Car: 2008 Prius Model: N/A Package: Pioneer #1 Thanks: 76
Friends: 1 | Where is Krousb? I want to hear more about his 8KW kit. Is it working? JOANNA |
| The Following User Says Thank You to plugmein2 For This Useful Post: | dave77 (10-13-2009) |
| | #123 |
| Senior Member Join Date: Jul 2005 Location: Raleigh, NC
My Car: 2004 Prius Model: I Package: #7 Thanks: 9
Friends: 10 | Everything is working fine. I have just been too busy to post lately. Mileage is down to about 80MPG due to colder, wet weather and a higher percentage of highway mileage. Still struggling with balancing, but hopefully tis weekend I will solve that problem. |
| | #124 |
Friends: 10 | Averaging 77 MPG now due to cooler weather and more % highway miles. Normally I would get 62 MPG. As it turns out, I will not be able to plug in at work as I had been promised so running one converter with 8kWh gets me to work and back, about 135 miles. Actually I normally run out at about 125 miles but that is good enough for me. Ive been very busy lately so I havent been able to check in very often. If you have any questions, just send me a PM. Dan |
| | #125 |
| Member Join Date: Aug 2009 Location: El Monte, CA USA
My Car: 2010 Prius Model: II Package: No Package Thanks: 29
Friends: 0 | Dan, I wanted to thank you for the wealth of information here. I am waiting for all the parts for my 2010 version of the 8KWH 2 converter system. I am planing to put 4KWH of batteries in the spare tire well. I do have one question though. I was wondering how long did it take charge the 8KWH pack with only one charger? Thanks, Chan |
| The Following User Says Thank You to banshee08 For This Useful Post: | dave77 (11-09-2009) |
| | #126 | |
Friends: 10 | Quote:
| | #127 |
Friends: 0 | Thanks Dan. Just went on my first run and the RED LED started flashing in about 11 miles. I check the battery and the voltage read 53.3V. I changed out the converter to my second converter and all was working again. The second converter was charging the OEM much much faster. Do you think my first converter is bad?? |
| The Following User Says Thank You to banshee08 For This Useful Post: | dave77 (11-15-2009) |
| | #128 | |
| Youngest PHEV Driver? Join Date: Sep 2008 Location: West Covina, CA
My Car: 2009 Prius Model: N/A Package: #5 Touring Thanks: 3
Friends: 6 | Quote:
If so, that just won't work. Even though the spec sheet says that these batteries are rated for <=3.0C, it's really <=2.5C. What's 2.5C? 97.5 amps. If you use 2 DC/DC converters, you'll be pulling roughly <= 110 amps. This explains the blinking red LEDs. I had the same problem. I remedied the problem by paralleling in an additional 2kWh using Thundersky batteries. These batteries have a better tolerence on the instantaneous and continuous current usage.. | |
| The Following User Says Thank You to kiettyyyy For This Useful Post: | dave77 (11-16-2009) |
| | #129 |
Friends: 0 | No I was just trying to use one converter. I received the wrong converter in my kit. It is for 320V system and boy did it get hot. I ran it for just 5 miles and it melted the rubber terminal covers on the Mottcells. I mounted teh 240V converter back and will be testing again after a full charge and balance tonight. As soon as the system test out fine I will mount the the system in the proper place and will be putting another 4KWH of batteries in the tire well along with adding a second converter to the case.
__________________ --- 2010 Prius II Blizzard Pearl/Dark Gray 2008 Altima Hybrid Winter Frost/Charcoal Leather |
| The Following User Says Thank You to banshee08 For This Useful Post: | dave77 (11-16-2009) |
| 8kwh, custom, enginer, phev |
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/68139-custom-enginer-plug-in-hybrid-electric-vehicle-8kwh.html | ||||
| Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader | This thread | Refback | 10-13-2009 08:33 PM | |
| http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums | This thread | Refback | 09-25-2009 09:45 AM | |
| http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums | This thread | Refback | 09-13-2009 03:22 PM | |
| TheEEStory.com: | This thread | Refback | 09-04-2009 10:47 PM | |
| TheEEStory.com: Doubts emerge over GM Volt | This thread | Refback | 09-04-2009 06:40 PM | |
| http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums | This thread | Refback | 09-01-2009 01:22 PM | |
| http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums | This thread | Refback | 08-30-2009 07:10 PM | |
| http://enginer.us Prius PHEV conversion - Page 5 - CleanMPG Forums | This thread | Refback | 08-30-2009 06:06 PM | |
| Enginer PHEV Technical Information | krousdb | Prius PHEV Plug-In Modifications | 159 | Yesterday 01:24 AM |
| Has anyone installed the enginer PHEV? | alevinemi | Prius PHEV Plug-In Modifications | 669 | 11-18-2009 07:29 PM |
| People Who Have Purchased the Enginer PHEV conversion kit!! | plugmein2 | Prius PHEV Plug-In Modifications | 77 | 11-14-2009 06:03 PM |
| Enginer PHEV DC/DC Overheating issues | kiettyyyy | Prius PHEV Plug-In Modifications | 58 | 09-17-2009 08:23 AM |
| Enginer PHEV Test Pilot # 1 | kammssss | Gen II Prius Modifications | 6 | 08-02-2009 10:43 PM |
to the discussion, most of us have picked up some manners during our life so far.
