This is a discussion on CAUTION: Hymotion and all PHEV owners! Tire Treadwear! within the Prius PHEV Plug-In Modifications forums, part of the Gen II Prius Modifications category; As Fred says, if you're seeing excessive wear on the outside edge of the rear tires, you very likely have ...
Old 10-14-2009, 01:58 PM   #11
drees
Default Re: CAUTION: Hymotion and all PHEV owners! Tire Treadwear!
As Fred says, if you're seeing excessive wear on the outside edge of the rear tires, you very likely have too much toe-in. You should see slightly more wear on the inside of the rears due to the slight amount of negative camber.
On the fronts, the outside shoulders will tend to wear a bit faster due to cornering forces.
Moral of the story - get the alignment checked, front and rear!
drees is offline
The Following User Says Thank You to drees For This Useful Post:
dave77 (10-14-2009)
Old 10-17-2009, 12:16 PM   #12
zcat3
O.K. - here is a picture of my rear driver's tire. The tire was put on after the Hymotion install (could not stand the OE tires - these are Michelin Radial Xs) and has about 12,000 miles on it. As you can see, tread wear is very even.
CAUTION: Hymotion and all PHEV owners! Tire Treadwear!-priustirewear.jpg
zcat3 is offline
The Following User Says Thank You to zcat3 For This Useful Post:
dave77 (10-18-2009)
Old 10-17-2009, 01:36 PM   #13
hill
High Fiber Member
hill's Avatar
I don't see anywhere you mentioning if the balding tires are stockers. Many here simply found that the Goodyear Integrity wore poorly ... rotated or not ... and of course if you DO take too much time to rotate, than that just amplifies the condition. Are they Integrities?
hill is offline
The Following User Says Thank You to hill For This Useful Post:
dave77 (10-18-2009)
caution, hymotion, owners, phev, tire, treadwear
Hymotion/Other Phev Mods - Who's taken the plunge? SVPriusFan Gen II Prius Modifications 61 12-14-2008 10:57 PM
Another Hymotion PHEV in consumer's hands boxer93 Gen II Prius Modifications 46 09-18-2008 10:09 AM
Hymotion PHEV to have EPA and NTHSA approval NoMoShocks Gen II Prius Modifications 17 02-19-2008 08:23 AM
AZ Owners, caution Ghoti Gen II Prius Care, Maintenance and Troubleshooting 2 07-20-2006 12:30 PM
Yet another tire pressure item/caution Bob Allen Gen II Prius Care, Maintenance and Troubleshooting 27 09-26-2004 09:07 PM
