First Enginer PHEV install in the Portland Or area, Gen2
| | #161 | |
My Car: 2005 Prius Model: Package: Thanks: 153
Friends: 15 | Quote:
wow the thuderskys are not and those yellow thunderskys where in those kits in the past those motcell must have lower cap. | |
| | #162 | |
| 2 CARS Join Date: Nov 2009 Location: Vancouver Wasington
My Car: 2010 Prius Model: IV Package: Navigation Thanks: 62
Yes, the Thundersky at rated 40ah. The Mottcells are rated 39ah. They use 3 each 13ah cylindrical cells. I had measured the capacity on 34 of the gray packs and got 36ah to 41ah. The Thundersky cells are just a little bigger and 4kwhr of them do not fit in the box with the converter and charger and BMS. The Thundersky were used in the 2kwhr systems. Thanks, Dan | |
| | #163 |
Friends: 0 | By the way, This car and its Enginer system are still running great. I did 33miles today at 68.7mpg. A little low because I am rusty on my technique. I drive my wifes Gen 3 more often and the optimum driving techniques are different on the 2 cars. Also this 4kwhr pack of cells is still balanced well with no balancer for more than 10 months. Thanks, Dan Last edited by dan2l; 02-05-2011 at 09:52 PM. |
| | #164 |
Friends: 0 | Hi Everyone, I drove 29 miles each of the last 2 days. My driving technique is comming back. I got 74mpg yesterday and 79mpg today. The system is working well. I think I could turn up the voltage on the converter a little but it is harder to do on the 3k converter so I have not had the energy to do that. Thanks, Dan |
| | #165 |
Friends: 0 | Hello Everyone, Wow it has been a long time since updating this thread. The system is still running well but I do not drive this car too much. I had an issue in my 2010 and moved that 4kwhr system into this car for a while. So then I had 8Kwhr of cells and 2 3kw converters and 2 chargers. it worked great for mpg. I was getting 130mpg most of the time. But I also got codes on occasion. I never got a good correlation of codes to what was happing in the Prius so I could not figure them out enough to eliminate them. So then I put the system back the way it was, 4kwhr with only one 3kw converter. After that I did do a 7 mile trip at 90.6mpg. so the system is still back at the level that it was at. The important think is that it is still running well after almost 2 years. Thanks, Dan
__________________ Thanks, Dan2l 2010 Gen3 IV Sandy Beach with 6kwhr Enginer PHEV 2005 Gen 2 Spectra Blue Mica with 6kwhr Enginer PHEV |
| | #166 |
Friends: 0 | Hello Everyone, I had an opportunity to get another old 2kwhr system with a Pacific EV balancer. So now I have 6kwrh of batteries and two 3k converters in parallel again. Also this system had no balancing at all before. I had balanced it at the bottom but it was loosing that balance due to the different self discharge rates of the various cells. So now both strings of cells are tied into the Pacific EV balancer. That is working well. I can get the 115-130 mpg and safely discharge and charge both systems. Thanks, Dan Lander |
| Thanked by 2 Users: | dave77 (01-23-2012), DaveinOlyWA (01-22-2012) |
| | #167 |
Friends: 0 | Hello everyone, I got 120mpg for 35 miles today. This system had an upper cutoff of 4v/cell and a charger cutoff at 58v. It was leaving one cell low so I dropped the cell cutoff to 3.8v and then it would never stop the balancing process. Then at 3.85v/cell it seemed to do better. I changed to a 58.2v charger this morning so we will see if that will do a better job of bringing up the low cells. I have found that the balance at the top process requires getting the interaction between the cell cutoff and the charger cutoff working correctly. Thanks, Dan |
| Thanked by: | dave77 (02-01-2012) |
| | #168 |
Friends: 0 | Hi Everyone, Wow, I have done 475 miles since my last post. All Except a 225 mile trip where I could not charge were above 100mpg. The system is now working good. Just plug it in and walk away. The Pacific EV Balancer is working well. My last 2 trips were 118mpg for 27 miles and 112mpg also for 27miles. Thanks, Dan Lander |
| Thanked by 3 Users: |
| | #169 | |
| Senior Member Join Date: Nov 2009 Location: Texas
My Car: 2004 Prius Model: N/A Package: Navigation Thanks: 456
Friends: 11 | Quote:
On your Gen2 what exactly (details) Enginer kit with "mods" do you have and are you using a SG2 with Xgauge???Currently | |
| | #170 |
| Test guinea pig #9 Join Date: Apr 2009 Location: Sydney Australia
My Car: 2005 Prius Model: N/A Package: Base Thanks: 34
Friends: 11 | I also found this to be the case. I am also using a Elcon charger with a pot to adjust the constant current. By lowering the constant current setting of my pot I decrease the chance of getting a HVC and actually go through the complete charge program CV - CC and also extend top balancing time. By using a AC plug-in timer on the Elcon charger input I can also cycle the charger on and off each time doing a top balance, similarly to how the Pacific BMS does. I also made a modification to my Elcon charger so I could change the maximum voltage setting to match my BMS HVC setting. This also gives me control as to how long it does the top balance for.
__________________ Test guinea pig #9 Canview V4 ![]() Enginer 8kwh Kit with 10kW (2x5kW) DC Converter MiniBMS + EV display Gauge 4.6kWH A123 Lifepo4 pack with BMSplus HV Fan Mod EV@85kph max only - 90km Last edited by lopezjm2001; 03-30-2012 at 03:28 AM. |
| Thanked by: | mrbigh (03-30-2012) |
| area, enginer, gen2, install, phev, portland |
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/74331-first-enginer-plug-in-hybrid-electric-vehicle-install-in-portland-area-gen2.html | ||||
| Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader | This thread | Refback | 02-04-2011 12:36 PM | |
| First Enginer PHEV Installation in Portland Or Area | dan2l | Gen III 2010+ Prius Technical Discussion | 136 | 05-20-2012 04:16 PM |
| Has anyone installed the enginer PHEV? | alevinemi | Prius PHEV Plug-In Modifications | 757 | 07-25-2011 10:20 PM |
| Daox's Enginer PHEV 4kWh install | Daox | Prius PHEV Plug-In Modifications | 124 | 10-07-2010 09:01 AM |
| Prius gen1 and gen2 conversion to PHEV | dart | Gen II Prius Technical Discussion | 6 | 05-22-2009 07:21 AM |
