Enginer PHEV
| Member Join Date: Aug 2010 Location: New Berlin WI
My Car: 2006 Prius Model: N/A Package: No Package Thanks: 6
Friends: 0 | Hey, Just bought an Enginer PHEV 2kw kit. I installed it and am having a few problems. I am working with thier support (very helpful) but wanted to run this at both ends. After installing, I ran the car around the block. Starting the car, it started as a normal Prius. The engine came on shortly after starting. Didn't think it was supposed to. The Prius pack then started draining to nothing! I had error codes for low Prius pack, check engine, the triangle warning. As I rounded the block, the engine started revving at high RPM's. The pack went to fully charged in seconds, then started going back down again, motor runniung high rpm's till I got home and shut her off. Also, when I plugged the Prius in, the charger showed red. I then turned off the PHEV C/B on the side of the box, and the charger showed green right away. Turned the C/B back on and the charger goes to red again. Is this normal? |
| Battery Curmudgeon Join Date: Mar 2010 Location: Santa Fe, NM
My Car: 2005 Prius Model: N/A Package: #4 Thanks: 237
Friends: 10 | If Eric Powers charges by the hour to look at your system, it is well worth it. He is in Madison and has the most experience with the system. http://priuschat.com/forums/private-.../send-to/1015/ Was your error code P0A80? That can happen if the current output from the converter is too high. |
| Thanked by: | dave77 (10-15-2011) |
| Senior Member Join Date: Jul 2009 Location: SE Michigan
My Car: 2004 Prius Model: N/A Package: Base Thanks: 119
I have a 2kwh system as well (however, it's >2 YO and probably doesn't look much like yours). Depending on whether you hooked up the EV mode connectors or not will determine if the ICE starts at power-up or not. Mine will start after the initial delay unless I press my EV button. Last edited by MJFrog; 10-14-2011 at 10:48 AM. | |
| Senior Member Join Date: Mar 2004 Location: Madison, Wisconsin
My Car: Other Hybrid Model: Package: N/A Thanks: 19
Friends: 54 | Quote:
If you have to install new parts that come from Enginer I suggest that you always bench test the individual components prior to installing them in the car. That means every switch, circuit breaker, converter and charger. You'll want to use your handheld multimeter to check the voltage and amperage output of that converter. As far as the engine coming on, it will normally come on shortly after starting. That is normal. Not sure why you think it would not? I would suggest that you purchase a ScanGauge (let me know if you need one) so that you can clear any codes. Any idea what the code was that was thrown or what your Prius Battery's State of Charge was at the time? I've been seeing some things happening when SOC gets too low.
__________________ Eric Powers Green Drive Expo Organizer * Madison, Wisconsin - July 21-22, 2012 * SF Bay Area - September 15, 2012 www.GreenDriveExpo.com | |
It showed up at the house yesterday misssing the long bolts that hold the 5000W converter down in the PHEV box, so it broke both the cooling fans in shipping, no HV wiring, no wires to connect the switch to the ECM connectors, and after watching the video and online manual, they dont show where to connect the 5000W converter to the pack, though the video does show them pointing at the lugs and asking where to connect it, but they never answered or came back to that. Did get support (really quick) they sent a picture showing where the HV wires go, as I have it now by looking at another site, on the side of the relays not on the battery side. They are also sending parts that I was missing. Last edited by f16bmathis; 10-14-2011 at 07:39 PM. Reason: proof read | |
As far as the engine coming on, I "assumed" I would be able to drive the 1.5 miles to my daughters school and home as I have been in EV mode without using any gas. Shame on me for not reading an operators manual! I may have to modify this once I get it working so I can still use the EV button, if possible.I do have a ScanGauge, cleared the codes, P3023 & P3024. The state of charge had run down to nothing, and then up to full, then back down again, engine running wildly till I got around the block and shut her off. The engine eventually stopped spinning thereafter. | |
| Senior Member Join Date: Apr 2010 Location: Midlands - UK
My Car: 2010 Prius Model: N/A Package: T4 Thanks: 18
Friends: 4 | Did you disconnect the 12V battery during installation? this will force the battery ECU to recalculate it's SOC, which can be difficult for it to do, especially if you are adding current it's not expecting! |
Friends: 10 | |
Friends: 0 | It was suggested by an electronics tech that was helping me, but I couldn't see any reason to, so we didn't. |
| code, enginer, install, phev, problem |
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/98923-enginer-plug-in-hybrid-electric-vehicle.html | ||||
| enginer forum | BoardReader | This thread | Refback | 01-11-2012 11:04 AM | |
| Thread Enginer PHEV | PriusChat Forums | BoardReader | This thread | Refback | 01-04-2012 12:13 AM | |
| Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader | This thread | Refback | 10-17-2011 09:12 AM | |
| Enginer PHEV - PriusChat Forums | This thread | Refback | 10-14-2011 11:37 AM | |
| Has anyone installed the enginer PHEV? | alevinemi | Prius PHEV Plug-In Modifications | 757 | 07-25-2011 10:20 PM |
| Question regarding Enginer PHEV | Huibin | Prius PHEV Plug-In Modifications | 5 | 03-09-2010 08:00 AM |
| enginer phev | donalmilligan089 | Private Sales | 0 | 02-03-2010 01:33 PM |
| ENGINER PHEV-KIT available at discount | mrbigh | Local Prius Club Main Forum | 0 | 10-15-2009 11:11 PM |
