Planing CanView and BMS+ conversion with lithium
Old 02-04-2012, 02:28 AM   #371
Friends: 15
can you see if you can go below 500 mAmps? I need 200 for my bleeding boards.
Old 02-04-2012, 02:31 AM   #372
Friends: 15
Mr plugin you have 72 cells setup? I read you asked your charger to be set to 72 cells?
Old 02-04-2012, 02:52 AM   #373
Test guinea pig #9
lopezjm2001's Avatar
Friends: 11
Default Re: Planing CanView and BMS+ conversion with lithium
It goes to 0.1 amps. My EV display meter will not measure any lower as it can only measure to one decimal point.
lopezjm2001 is offline
Old 02-04-2012, 03:17 AM   #374
Friends: 15
great...
what's the use for 2 cells more its only to charge the last 10% ? in cv mode..
is it not better to charge to 90% for battery life?
Old 02-04-2012, 03:44 AM   #375
Test guinea pig #9
Friends: 11
Like Flan said. If the BMS fails to do the HVC event the charger will overcharge the whole battery pack and you would probably need to replace all the cells. But if it goes into CV mode first it will not overcharge the pack. It is all about protecting the battery pack from overcharging and over discharging.
Old 02-04-2012, 04:30 AM   #376
Plug in 4,5 kWh
planetaire's Avatar
Model: II
Package: Sol
...edit
found a link to adjust the end voltage
Elcon charger voltage adjust - DIY Electric Car Forums
cant get the pdf am not a member!!...
This is an analogic modification. You have to open the charger. The waranty is lost then.
It is really better sending 2 to 5v between pin 1 and 2. A bms can do this and then control end-voltage charging. It can too reduce amperage when one cell have a shunt on when balancing begin.
Thank you FlyingWhite and LopezJm. The abliilty to control amperage is exactly what I needed in order to charge during 8 hours during night or the quickest possible during day (4h). And controling amperage allows voltage control too, both are linked
Adjusting the charging curve number is decribed here. But how can this number been changed ?
planetaire is offline
Thanked by 2 Users:
dave77 (02-04-2012), NortTexSalv04Prius (03-18-2012)
Old 02-04-2012, 05:10 AM   #377
Friends: 15
iamps also controlles voltage?
you mean at 0,200amps the voltage wil not go up to the end voltage?
its only a current control?
edit
i got the cell logs today ( wel 4 of them, 1 more to arive today and 4 from the UK this week )
i did some reading and found some disturbing stuff about the sleep mode ( its useless )
the alarm in sleep mode does not work.
I had my CellLog8 watching over the pack. But what I found on both my CellLogs was that in the "sleep" mode they truely went to sleep because when I woke them up the alarm sounded. To my shock 2 cells were at 4.4v.
--http://www.ebikeforum.com/electric-bike-scooter/143606-great-deal-thunder-sky-lifepo4-20ah-4.html
edit
ok did a test and the beep go's out but the alarm output relay keeps working
edit
the music and log logging message at startup can be removed in the menu
and i see that i dont need those JCT-XH cable that is hard to find but just use computer ( have to look up the name ) mainboard plugs.
edit
mine are version 2.0.7 and i hope thats the latets because these are not upgradeable ( well not with the usb port )
Member off the SuperWhite Prius club, seat belt beeper remedy = buckle up ,Environment/Health/Safety first... Say NO to DLRlights, Hybrid Interfaces BMS+, ELCON charger MODS asocialsime = capitalisme = selfishme((copyright)(me))
Old 02-04-2012, 05:33 AM   #378
Plug in 4,5 kWh
planetaire's Avatar
Model: II
Package: Sol
its only a current control? ...
Yes, when amperage equal zero, charger voltage equal cells total voltage.
At the opposite, when charger send the maximum amperage there is a delta V in wires, connectors... charger voltage is a little over cells voltage.
You need a bms or an external electronic device (or manuel action) that manage the voltage between pin 1 and 2.
Edit.
4,4v ? Do you control with a voltmeter ?
Old 02-04-2012, 06:01 AM   #379
Friends: 15
(its not my post .. link is below the copy out of that topic ;-) )
mmm well that still wil not work because as you say if a cellogs fails it wil keep on going....
dammit now i have to wait for 3 weeks at least to get one adjusted to my needs..
Old 02-04-2012, 06:50 AM   #380
Test guinea pig #9
Friends: 11
It looks like my Elcon charger is setup for a BMS with a HVC of 3.8v. My mniBMS has a HVC of 3.6v. It looks like it may be a simple matter of changing the charge curve selection for a HVC of 3.6v. The charge curve selection instructions are a bit vague and I do not know which set of charge curve choices have been programmed onto the charger. Apparently it has a choice of 10 charge curves but there are 7 sets which could have been programmed into the charger. I will email Mochael.
bms, canview, conversion, lithium, planing
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/99420-planing-canview-bms-conversion-lithium.html
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 04-19-2012 12:12 PM
2010 Prius OEM-quality Fog Light Kit Now Available! | PriusChat This thread Refback 04-10-2012 03:42 PM
enginer forum - Page 4 | BoardReader This thread Refback 03-30-2012 06:09 PM
Recent Posts This thread Refback 03-28-2012 03:31 PM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 03-16-2012 02:25 PM
enginer forum | BoardReader This thread Refback 03-14-2012 03:22 PM
Forum Prius Touring Club - Afficher un message - P2 Plug-in avec accus lithium et bms+ This thread Refback 03-12-2012 04:56 AM
P2 Plug-in avec accus lithium et bms+ - Page 9 - Forum Prius Touring Club This thread Refback 03-11-2012 05:50 PM
plug-in supply conversion battery | BoardReader This thread Refback 03-03-2012 08:25 AM
Planing CanView and BMS+ conversion with lithium - PriusChat Forums This thread Refback 01-04-2012 04:29 PM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 01-02-2012 09:56 AM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 12-17-2011 01:26 PM
Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader This thread Refback 12-14-2011 09:45 PM
Planing CanView and BMS+ conversion with lithium - PriusChat Forums This thread Refback 12-09-2011 04:43 AM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 12-06-2011 04:43 AM
DIY Electric Car Forums - A123 20ah cells, testing the connection method This thread Refback 11-24-2011 09:59 PM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 11-24-2011 10:43 AM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 11-24-2011 01:21 AM
A123 20ah cells, testing the connection method - Page 2 - DIY Electric Car Forums This thread Refback 11-24-2011 01:02 AM
Anyone heard of ReGo and this $5000 Lithium ion conversion? ualdriver Prius, Hybrid, EV and Alt-Fuel News 9 05-12-2012 06:40 PM
CanView with BMS+ Mr-plugin Prius PHEV Plug-In Modifications 2 10-04-2011 09:45 AM
Parallel setup with Lithium LIPo or other Lithium battery ? LexusCT200h Prius PHEV Plug-In Modifications 7 06-02-2011 12:18 AM
CANview WizBandit Gen II Prius Technical Discussion 1 11-13-2007 07:20 AM
CANVIEW eflier Gen II Prius Audio and Electronics 8 11-19-2005 05:31 PM
