Plug in Supply Questions
Old 11-15-2011, 08:50 PM   #31
cproaudio's Avatar
Model: V
Package: Adv. Technology
Default Re: Plug in Supply Questions
Kiet, I wanna setup a test drive with your system sometime in late December. I'm pretty fed up with the Enginer system. My system has been down for almost 3 months now due to faulty converter. They're sending me a new converter that supposedly cooler than the older one. If this converter fails gain, I'm jumping ship.
cproaudio is offline
Old 12-03-2011, 02:57 PM   #32
High Fiber Member
hill's Avatar
Friends: 24
I'm WAY happy to report that Kiet confirms they can now install their PHEV system in Toyotas(Lexus)' SUV hybrids. WHOO HOO! I'm anxiously looking forward to the "go for it" nod - from my better half. It's only logical - as the RX-400h is her main ride.
hill is offline
Old 01-02-2012, 10:32 AM   #33
Test guinea pig #9
lopezjm2001's Avatar
Friends: 11
I was reading through the plug-in website. It still states that you must stop to leave EV mode. I was under the impression that when using the ECM you would not need to stop to leave EV mode. Do you still need to stop to leave EV mode when you are using the new ECM? I am a bit confused.
lopezjm2001 is offline
Old 01-02-2012, 11:13 AM   #34
ericbecky's Avatar
My Car: Other Hybrid
Friends: 54
My understanding is that the older system had that limitation.
The new ones do not.
ericbecky is offline
Thanked by:
dave77 (01-03-2012)
Old 02-03-2012, 01:08 AM   #35
epa5epa's Avatar
Package: Executive
It's a good news that the DIY packages of PIS products is available online.
DIY - Plug-In Supply
The instruction is pending.
epa5epa is offline
Old 02-03-2012, 01:44 AM   #36
Test guinea pig #9
Friends: 11
A bit vague. Which cells are they selling? Maybe Headway. What exactly is included. Will be interested to see a price for ECM module. Do they have a forum to find the answer to all these questions? It is not a simple DIY installation like a Enginer kit. It is probably a lot more complicated.
Old 02-03-2012, 05:39 PM   #37
Flaninacupboard's Avatar
Package: T4
Sounds good. I am really interested to see the instructions, and it sounds as though the system is operating better now (the warnings about entering/exiting EV mode at high speed are gone, it acts more like the Toyota PHV). As the Ampera($58,000) and Volt($53,000) get released here in the UK later in the year, and with the Leaf still at $49,000, $8,500 to upgrade the gen3 prius is a bargain!!
Flaninacupboard is offline
Old 02-17-2012, 03:26 AM   #38
chenyj's Avatar
Model: II
Are there PIS customers to share their candid experience for installing, driving and maintaining their PIS systems?
chenyj is offline
Old 02-20-2012, 11:00 PM   #39
Model: Three
From my calculations it takes about 30 hp to move a 3000 lbs. weight up a 6% grade at 60 mph. Add resistance etc to this, hp may have to be double. I believe the hp for the MG motors is 67. Thus, from the math, Prius should be able to do hills at reasonable speed without ICE. Wonder why they did not make an all electric Prius?
Regardless, what type of springs do you ( experts suggest to prepare Prius for 10 kw battery pack? Thanks
Rsingh is offline
Old 02-21-2012, 12:33 AM   #40
Test guinea pig #9
Friends: 11
Try this topic
Should I Upgrade Suspension when going PHEV?
Thanked by:
Rsingh (03-03-2012)
plug, questions, supply
LinkBack to this Thread: http://priuschat.com/forums/prius-phev-plug-in-modifications/99572-plug-in-supply-questions.html
Thread Plug in Supply Questions | PriusChat Forums | BoardReader This thread Refback 05-03-2012 03:35 AM
Thread Gen III Plug-In Supply Experiences | PriusChat Forums | BoardReader This thread Refback 04-19-2012 10:20 AM
Thread Plug-in Supply kit - EV only mode | PriusChat Forums | Page 2 | BoardReader This thread Refback 04-01-2012 09:14 AM
plug-in supply conversion battery | BoardReader This thread Refback 01-01-2012 01:48 PM
Plug in Supply Questions - PriusChat Forums This thread Refback 12-09-2011 07:40 AM
Prius PHEV Plug-In Modifications on PriusChat Forums | BoardReader This thread Refback 11-22-2011 02:31 PM
plug-in supply VS plug in solutions ... scam? lesdit Prius PHEV Plug-In Modifications 15 02-21-2012 04:15 PM
Plug-in Supply kit - EV only mode orahm Prius PHEV Plug-In Modifications 11 05-11-2011 08:13 PM
New PHEV Install: Plug-in Supply Kit kiettyyyy Prius PHEV Plug-In Modifications 44 05-24-2009 10:53 AM
Any Experience with Plug-in Supply? AlanK Prius PHEV Plug-In Modifications 12 01-22-2009 06:44 PM
Plug-in Supply $6,095 plugin kit DIY Flying White Dutchman Prius, Hybrid, EV and Alt-Fuel News 35 10-28-2008 06:09 PM
