| Prius Technical Discussion This is a discussion on Making a phone call within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; OK, the answer is probaly here somewhee but I couldnt' find it. I have successfuly added the voice tags to ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | OK, the answer is probaly here somewhee but I couldnt' find it. I have successfuly added the voice tags to the address book. Here's the question, how do I get to the phone book voice command page to actually make a call using voice commands instead of doing to manually? Thansk |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(powrfuel @ Jun 10 2006, 09:59 PM) [snapback]269360[/snapback]</div> Quote:
wait for the beep then say either "dial by name" or "dial by number" It will tell you when to talk again. wait for the beep then say the name (which you recorded earlier) It will tell you what it thought you said if it is correct press the voice button again and say "dial". If it is not correct you can repeat the name you previously said (after pushing the talk button) or you can say "next candidate". If you say dial by number then after the first beep say each one of the area code digits and pause. It will verify what you have said and tell you to push the talk button to continue adding numbers or to dial. Push the talk button again, wait for the beep, then say the remaining seven numbers. It will repeat the numbers back to you then you push the off hook button or say "dial." It may take a couple of tries but it really works well for me and should for you too.
__________________ Marie Girls in Gold Prius Club 46 mpg first tank 2006 Gold Prius | |
| Prius owner Join Date: Jun 2004 Location: Washington DC area
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(powrfuel @ Jun 10 2006, 09:59 PM) [snapback]269360[/snapback]</div> Quote:
1) Press the off-hook phone button on the steering wheel (Speed dial screen will appear). 2) Press the 'back arrow' button on the screen. 3) Press the voice command button on the steering wheel. It will now just ask you for the phone number to dial. If you speak clearly, distinctly, and without any pauses all 10 digits (area code and number) can be spoken at one time. It can help to speak to the rearview mirror since the microphone is just above that in the ceiling. I found the Nav lady voice annoying after the first phone call with her lengthy instructions over and over again each phone call. So, this combination of buttons and voice is both faster and less annoying. I wish they would allow us to press the off-hook button on the steering wheel to initiate the call immediately after we say the phone number instead of having to wait until she finishes telling us that we can press the off hook button. As if we do not know that! If you interrupt her while she is speaking this by pressing the off hook button - then the call is lost! Separately, on the 2006 model I have used the voice command 'dial by name' and 'dial by number' voice commands successfully without being on the telephone screen. Best regards, Eric | |
| Senior Member Join Date: Mar 2006 Location: Trenton, NJ
My Car: 2006 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Eric Nothman @ Jun 11 2006, 01:22 AM) [snapback]269419[/snapback]</div> Quote:
- Doug | |
| Senior Member Join Date: Sep 2005 Location: Oxfordshire, UK
My Car: 2005 Prius Package: T Spirit Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Marie @ Jun 10 2006, 11:18 PM) [snapback]269408[/snapback]</div> Quote:
"(which you recorded earlier)" What does this mean? Is there some way of recording by sound the names in the address book? | |
| Senior Member Join Date: Jan 2006 Location: Amsterdam, Netherlands
My Car: 2006 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(KMO @ Jun 14 2006, 01:09 PM) [snapback]271029[/snapback]</div> Quote:
| Bluetooth Delay when making a call | dwils4 | Audio and Electronics | 0 | 11-11-2006 04:59 PM |
| Question about making a bluetooth call | yarzy | Audio and Electronics | 4 | 09-13-2006 12:54 PM |
| Making or Taking a "Private" Call with Bluetooth P | dhendler | Audio and Electronics | 5 | 08-09-2005 10:38 PM |
| donotcall.gov Car Phone Do Not Call | GSpozars | Fred's House of Pancakes | 3 | 06-02-2005 12:00 PM |
| Bluetooth Delay when making a call | dwils4 | Prius Main Forum | 0 | 12-31-1969 07:00 PM |
