| Prius Technical Discussion This is a discussion on 2006 Factory EV Button (How to use?) within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi guys, I've been going over all the messages here and have learned a lot about the Prius. Just got ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi guys, I've been going over all the messages here and have learned a lot about the Prius. Just got my Black 06 a few weeks ago and installed the factory EV switch tonight. I'm not sure if it's a 06 thing, but when I turn on the IG and press the EV switch: 1) I don't get a single beep. 2) The MFD says "Cannot change to EV mode now" (SOC is 4 bar) But when driving < 34 MPH when the ICE is on, pressing the EV switch immediate kills the engine and I'm on stealth mode (but I still don't get the single beep) When EV does turn off (either hard acceleration or SOC < 3 bar), I do get the 3 beeps indicating that EV is off. So my questions are: 1) Why can't I be in EV mode as soon as I press the IG (I waited until after the Toyota logo has disappeared and before the ICE turns on)? 2) Why don't I get the single beep indicating EV is on? I've done the search and it looks like a lot of the results are for the Gen 1 cars. Thanks. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | When you power on your 2006 the Toyota logo comes up for a few seconds and goes away. You must activate the EV right then or if the ICE kicks on you have to wait until the ICE is hot. Second, I the battery is SOC is to high like you parked the car with green bars the EV mode won't work until you are back to purple bars. Third, it the outside air, inside air, or battery temp (I still don't know what controls this) the EV mode won't work. Finally, if the battery SOC is tow low, as in less then have the bars on the screen the EV mode won't work. You will get the hang of it. How much was your button?
__________________ * Classic Silver, Prius Plus Plug-in Hybrid Electric Vehicle Conversion *EV Button* Free Reverse Beep Mod, *Mirror Mod, * Aerodynamic hubcaps, * Almost Free Anytime Reverse Video, *Anytime Forward View Video, *Fumoto F103N Oil Drain Valve, *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch, *Dual Microphone Mod *In Dash DVD Theater, *V4 CAN-View </span> <span style="color:#FF0000">Mods wanted in the near future - Hydraulic Brake -Pressure Indicator -Hobbits Vacuum “Good vs. Bad” Driving Indicator |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Why won't EV mode work if the battery is on green bars? I would think the opposite where that's the optimum time for EV mode. I'm going to have to play with different scenarios and see. I'll post on here once I have a definitive answer. Got the switch from Sigma Automotive. It came with all the wiring (pre-crimped). All I had to do was plug the wires into the harness. The kit even has the wire/crimp for the ECU! It was $69 + S/H. A little expensive for a switch, but I wanted the factory look. |
| Senior Member Join Date: May 2006 Location: Cincinnati, OH
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Porsche403 @ Jul 22 2006, 10:16 AM) [snapback]290461[/snapback]</div> Quote:
My Car: 2005 Prius Package: B Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | You get the beep if you're in any other screen other than the Energy Monitor. It'll beep and switch to the Energy Monitor. You have to activate it when the logo shows (you'll get a beep then) |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(rudiger @ Jul 22 2006, 11:48 AM) [snapback]290510[/snapback]</div> Quote:
Pull the left vent, unplug the dimmer switch, tap into the wires, pull out the blank and replace with the EV switch. Most people ran the wire to the ECU behind the MFD. I just did it under the dash where the "Key" and "Tire reset" was. Then ran it under the middle divider that's on top of the carpet. Then back up through to the ECU. This part took me about 10 min and was a lot less painful than running it behind the MFD. No "fishing" required. The ECU plug was very easy to unplug. Afterwards, just slip in the included crimp. You will still need about 8' of 24 gauge wire to tap from the EV switch to the ECU wire/crimp. The kit only comes with about 4" of wire. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | OK. I verified that everything works according to spec except the single beep when EV is engaged. However, the MDF does in fact switch over to the Energy screen, but no beep. Can someone who has done the EV mod for a 2006 confirm whether or not they get a beep when EV is engaged? |
| Senior Member Join Date: Jan 2006 Location: Newark, Delaware, USA
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Porsche403 @ Jul 22 2006, 07:14 PM) [snapback]290664[/snapback]</div> Quote:
At least that is how it works on my 2006. - Tom | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | <div class='quotetop'>QUOTE(Porsche403 @ Jul 22 2006, 06:14 PM) [snapback]290664[/snapback]</div> Quote:
I have an 06 and I don't get a beep when it goes into EV. I do get three beeps when it comes out of EV because of low battery or if I go above 34 MPH. I did the free EV modification to the lights flash on the steering wheel. I may go to a button soon just because I think it is cool. | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I do not have the beep disabled. Otherwise I would not hear the 3 beeps when EV is disabled. Even if the MFD switches to Energy from say the radio screen, no beep. Thanks for verifying the results. |
| Factory EV Button DIY Guide | Tideland Prius | Knowledge Base Articles Discussion | 2 | 03-05-2008 10:05 PM |
| Need Factory 2005 EV Button and kit | Jim Biggs | Prius Modifications | 2 | 06-06-2007 10:45 AM |
| 2006 Prius Factory EV Button Installed | mr_zorg | Prius Modifications | 13 | 10-09-2006 08:58 AM |
| Factory EV button in 2006 - done! | darelldd | Prius Modifications | 8 | 09-06-2006 05:50 PM |
| [ KB ] How do I get that Factory EV button everyone's t | naterprius | Knowledge Base Articles Discussion | 0 | 10-01-2004 12:11 PM |
