| Prius Technical Discussion This is a discussion on Motorola Q bluetooth within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I just got the Motorola Q with bluetooth from Verizon. I can connect to the Prius and make and receive ... |
| | #1 | |
| Junior Member Join Date: Feb 2004 Location: Isle, MN
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I just got the Motorola Q with bluetooth from Verizon. I can connect to the Prius and make and receive calls. I can transfer contacts to the Prius and it says a successful transfer. Now my problem. 1. Even when I am just sitting still, I see my phone book contacts, but they are greyed out. So I can NOT choose them or add them to the One Touch screen. 2. If I assign a previous call number to the One Touch screen, then when I start moving the number disappears and I am left with remembering what number I assign to what one touch. Anybody have any ideas what is wrong. Thanks <div class='quotetop'>QUOTE(longshortofit @ Jul 28 2006, 02:40 PM) [snapback]293939[/snapback]</div> Quote:
Forgot to say the Prius is a April 2005. | |
| Senior Member Join Date: Jun 2006 Location: Boone, North Carolina
My Car: 2006 Prius Package: #5 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 11 | Actually, sorry, I don't have a suggestion, I'm just very interested in any response as I too am currently upgrading my Verizon phone to a smart phone with bluetooth. good luck, and thanks for posting.... |
| Senior Member Join Date: Aug 2005 Location: Marlborough, Mass
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(longshortofit @ Jul 28 2006, 03:42 PM) [snapback]293939[/snapback]</div> Quote:
2. This is normal - it's just toyota's way of "protecting" us from reading while driving. I've got a question for you - Have you been able to charge the Q in your Prius? Mine will hold a charge, but it will not charge it at all.
__________________ __________________________________________________ 2005 Salsa Red Pkg #6. Acquired Sept 1st 2005. 31404 miles as of 9-13-06 | |
| | #4 | ||
| Member Join Date: Mar 2005 Location: Sedona, AZ
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Longshortofit - I own a Q also and I'm interested in how you got the contacts to upload to the Prius. I have an '04 Prius but I hope that is not the prob. I have never been able to upload my V710 to my Prius. Now that I have a Q I am looking to upload my contacts. Did you just follow the instructions? As far as your concern about the subdued list of contact that won't let you access them, My Guess is, it is because you are moving. You can hack the Prius to allow you to use the system while moving by disabling the motion detector. I found the way to do it on PriusChat. <div class='quotetop'>QUOTE(longshortofit @ Jul 28 2006, 12:42 PM) [snapback]293939[/snapback]</div> Quote:
Sorry man, I just read your question again and I see that you state that you are not moving. My suggestion does not help you. I would still like to know how you got as far as you did with the transfer of the data base in your Q. <div class='quotetop'>QUOTE(longshortofit @ Jul 28 2006, 12:42 PM) [snapback]293939[/snapback]</div> Quote:
__________________ Everyone is entitled to their own opinion, but not their own facts." - Sen. Daniel Patrick Moynihan "Too often we enjoy the comfort of opinion without the discomfort of thought." - John F. Kennedy | ||
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Can you actually see the phone list on your one touch screen? I am not a "fan" of Verizon as you may tell form past posts. I got hosed on the 710. If you hit the phone button on the steering do you go to the one touch or the key pad? If you can do pictures that will help? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I was out of touch for the weekend. The question about transferring contacts. I just go to the contact I want to be on the Prius. (I have not tried a whole phone book) Then I go to "MENU-Send via Bluetooth" the Prius then asks Replace of Add and I choose Add and then the Prius says successful. Please let me know if you get a contact on the Prius and if yours does the same thing of being grayed out. Thanks Again they are grayed out while I am sitting in my yard NOT moving. Repeating. I can see the phone list but it is always grayed out, I figured once I got the number to the Prius that the phone was out of the picture for displaying the info. I will try and take some pictures and post them later. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | [attachmentid=4298]Here is a picture of the grayed out entries in my phone book on the Prius while I am setting in the parking lot. You can see that the alphabet tags are available, but the entries are grayed and can not be selected. The other pictures of successful transfers, I could not use my camera phone and transfer at the same time. Have to wait until I get home to use a standard camera. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I know this sounds dumb but I was thinking the same thing while charging my V710 in the Prius and what I finally figured out was the Vehicle Charger needed to be rotated a bit till the green light was lit. I know that is a lame answer and a duhhh. But that's what I figured after not charging my phone successfully a few times. <div class='quotetop'>QUOTE(Maytrix @ Jul 29 2006, 10:08 AM) [snapback]294311[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(longshortofit @ Jul 31 2006, 09:28 AM) [snapback]295136[/snapback]</div> Quote:
It could be that the "no signal" is because the phone doesn't support that option, but the antenna-like symbol should have bars next to it indicating signal strength. Again, just a guess. Maybe someone can confirm that behavior... | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | In my '06, I can not dial from my contacts, but I can dial from speed dial while moving. I can ONLY see NAMES in speed dial. The corresponding numbers are missing. It seems to me that if you put names to your speed dial, it might solve one problem. My phone, for reference is a Motorola V3c Razor from Verizon. |
| Help How do I to set up Verizon Motorola V3M to Bluetooth | beeblebrox | Audio and Electronics | 10 | 05-01-2007 01:07 AM |
| Bluetooth - Motorola Dash | jmann | Audio and Electronics | 2 | 03-19-2007 08:38 AM |
| Motorola V262 + Bluetooth Adaptor? | TonyPSchaefer | Audio and Electronics | 1 | 03-12-2006 10:51 PM |
| Motorola i605 Bluetooth??? | RadMarv | Prius Main Forum | 0 | 08-06-2005 10:08 PM |
| Bluetooth and my V600 from Motorola | Prophet | Prius Main Forum | 4 | 08-02-2004 10:49 PM |
