Prius Technical Discussion This is a discussion on Is the A/C really on when it's pumping heat within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Today is the first day since getting my Prius 3 weeks ago that the outside temp has been low enough ...
Old 08-27-2006, 10:15 AM   #1
mtsarpilot
Today is the first day since getting my Prius 3 weeks ago that the outside temp has been low enough that the A/C Auto has needed to put out a little heat instead of air conditioning. Heat definately coming out of the vents, yet on the Climate screen, both Auto and A/C have their yellow bar illuminated. I manually turned off the A/C button on the screen and of course no change in the heat coming out.
Is the car really running the A/C compressor when it's putting out heat? Or is this indicator really just an "A/C is enabled" indicator and not an indicator that it's truly using the A/C?
I notice that if you turn off the A/C button, the "A/C Auto" indicator up on the panel stays on. But if you leave the A/C button on and turn of the "Auto" button, that indicator goes off. That to is therefore a misnomer. It's really just an "Auto" indicator not an "A/C" indicator. Why'd they do that?
Seaside '06 Package #6
Leather added
Full Clear Bra package
Mud Flaps, Side moldings, and Coastal receiver hitch
Purple Wire switch and Sirius Here2Anywhere Receiver installed behind smoked window door
mtsarpilot is offline
Old 08-27-2006, 10:46 AM   #2
tumbleweed
tumbleweed's Avatar
If you have it in AUTO AC the system will heat or cool as needed to keep the temprature where you have set it. The AC does not run all the time and due to the variable speed compressor motor it is quite efficient when it is cooling. The problem is there is very little hystereses, it needs to have a cool setting and a heat setting like the ones in most houses. I try to get around it by setting the temp to 78 or 80 when I want AC, when I want heat I set it to 70 and turn the AC off with the MDF.
former Prius owner, waiting for a G III
present car BMW 3 series
tumbleweed is offline
Old 08-27-2006, 11:38 AM   #3
richard schumacher
nacreous lacquer
A/C means air conditioner, not air cooler. The A/C does what is needed to maintain the desired cabin condition. The compressor runs only when needed for cooling or dehumidifying.
richard schumacher is offline
Old 08-27-2006, 11:41 AM   #4
8AA
8AA's Avatar
To the Japanese (and maybe other parts of the world) "air conditioning" means that the air is being heated, cooled, or dehumidified. On the Prius, "A/C Auto" indicates that the climate control will try to maintain the adjustable temperature and the non-adjustable relative humidity. The "A/C" button on the "Climate" screen is an override for the cooling compressor. If the button is illuminated, it means that the climate control has permission to use the compressor when it sees fit.
8AA is offline
Old 08-27-2006, 06:17 PM   #5
seasalsa
seasalsa's Avatar
Send a message via AIM to seasalsa
<div class='quotetop'>QUOTE(mtsarpilot @ Aug 27 2006, 07:15 AM) [snapback]310097[/snapback]</div>
The A/C compressor has nothing to do with providing heat to the cabin. Heat comes from either electrical resistance or hot water.
seasalsa is offline
Problems pumping gas AOV Care, Maintenance and Troubleshooting 63 03-03-2008 04:06 PM
pumping gas itsme Prius Main Forum 16 05-06-2007 02:19 PM
pumping? barbaram Fuel Economy 14 09-21-2006 12:51 AM
Solutions for gas pumping issue? jlbeerhour Care, Maintenance and Troubleshooting 31 07-26-2006 02:06 PM
Gas pumping problem burritos Prius Main Forum 12 07-13-2006 10:45 PM
