| Prius Technical Discussion This is a discussion on Synergy Drive Problem within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; PLEASE HELP! I have a 04, Prius. 140K. Very recently, my car's left axle seal started to leak fluid. (very ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | PLEASE HELP! I have a 04, Prius. 140K. Very recently, my car's left axle seal started to leak fluid. (very minor) I took it to a garage and work was done. During the repair, some of the fluid in the Synergy Drive leaked out.. the mechenic used a little pump and pump about a quart of Dextron III/IV fluid into the drain plug. After the repair, I started to notice while at crusing speed, if I let go the gas padel, I can feel what can only be described as a "torque convertor" problem.. I can feel a slight jolt that feels like the something would happend with a transmission and a torque convertor.. since, Synergy Drive dose not "shift", I really do know where to look. I had the dealer drained and fill the fluid (ws) twice. (back to back) and I was charged almost $300.. which is a rip off I guess.. because it is really like changing engine oil or differential fluid.. drain and fill.. Any how, problem still exist. Any idea?? Maybe a clogged fuel filter?? (which is in the tank i believe).. bad spark plugs?? ( 140k on it alreay |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | I don't think we're going to be much help from here. What procedures has the Prius tech gone through to try to diagnose the problem. Why was the transaxle fluid changed twice (and no, it's not as simple as engine oil or differential fluid). How did the fluid look? Did he take apart the transaxle to see if there were any issues. I know of one case of a broken transaxle on an '02 Prius and it had metal shavings in the case upon inspection. Are you throwing any codes? Are you noticing an impact on FE? I think there are a ton of things to check (like the plugs and fuel filter you mentioned). Have you had all required maintainence (100k mile PSD fluid changed and Super long life fluid changed?). Any chance this is something with the wheel bearings if you had the fluid leak from the axle to start with...a bad bearing could give you a jerky or draggy feeling as you slow or coast. This really needs a thorough evaluation by an experienced mechanic. You have to be one of only a very few people with a 2G Prius with that many miles (if not the only one) and it seems to me that Toyota would be very eager to look into this carefully in an effort to head off similar problems before they start to crop up in other folks' cars as they accumulate high mileage. To that end be sure to call the Toyota Customer Care folks and get a case number so this can be referenced in the future, if needed, until the problem is resolved. |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | uhhhh... who put the dexron in there? they better break out the checkbook. that stuff destroys ws designed transmissions. full transmission replacement required in pretty much all cases. |
| | #4 | ||||
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | <div class='quotetop'>QUOTE(efusco @ Sep 24 2006, 01:43 PM) [snapback]324319[/snapback]</div> Quote:
plugs are a thing to check though, for sure. Quote:
__________________ black 2005 prius, tweaked just the way i like it my diagnostic guy on electronics: "lack of troubleshooting ability is due to a high common sense rejection ratio." | ||||
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(galaxee @ Sep 24 2006, 02:05 PM) [snapback]324385[/snapback]</div> Quote:
__________________ You can quote me on this, People who drive vehicles that idle at a traffic light, are idiots. mine 2k3 avg. 5.36 for 46,915Km Best tank 4.4L per 100K 64.2 Imperial 53.4 U.S. gallon, MiniScanner, SilverStars, block heater, winter lips, in as of Oct 15, out on April 25. In again on Sept. 21st. her's 2k4 "B" avg. 6.01 for 42,317 Km Best tank 4.02L per 100K, CAN-view with OBD11 module and flashloader, SilverStars, 06 Chrome grill bar, Michelin HydroEdge, upper and lower grill blocker,upper out as of April 7, lower out on April 28. In again on Sept 21st. | |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | <div class='quotetop'>QUOTE(Frank Hudon @ Sep 24 2006, 06:01 PM) [snapback]324412[/snapback]</div> Quote:
isn't that the truth! | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | What shop was it, and what qualifications for working on hybrid drivelines did they claim to have? Name names, please. . Can someone provide more details or a pointer on exactly *why* Dexron is bad for the prius transaxle? Symptoms/results? . _H* |
| Senior Member Join Date: Feb 2004 Location: Washington DC
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Rick Auricchio @ Sep 25 2006, 05:17 PM) [snapback]324918[/snapback]</div> Quote:
| Weight penalty of the Hybrid Synergy Drive | justlurkin | Prius Technical Discussion | 22 | 10-02-2007 11:15 AM |
| Hybrid Synergy Drive emblem FS? | sal | Private Sales | 7 | 08-28-2007 06:04 PM |
| Hybrid Synergy Drive Community | efusco | Prius Main Forum | 3 | 10-10-2006 02:32 AM |
| hybrid synergy drive commercial | galaxee | Prius Main Forum | 10 | 10-10-2006 12:47 AM |
| Hybrid Synergy Drive Advertisement | Liam | Prius and Hybrid News | 3 | 10-15-2005 01:03 AM |
