| Prius Technical Discussion This is a discussion on Nav Reset for 2006 within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I was looking through the forums and found this post for resetting the Nav, but it looks like he has ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I was looking through the forums and found this post for resetting the Nav, but it looks like he has a 2004. As I understand it, the Nav may be different in the 2006. Does anyone know the reset procedure or know where this might be documented? |
| Senior Member Join Date: Oct 2004 Location: Dallas TX
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I can't imagine why you would NEED to "reset" the NAV system on a 2006 Prius. That entire procedure sounds real risky to me. But... that's your business. Hope you don't disable your NAV system.It might help if you'd clarify why you want to "reset" and what you're trying to accomplish. For example: Do you need to rid your system of old memory points established by a former owner? - or something like that? |
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I would imagine the process would be similar, but it is way beyond my comfort level. Also remember the person that wrote that is in a bad spot. He had hosed his Nav System playing around with the diagnostic screen. He was trying to find out what the screen did. He really had several bad choices but they all ended with replacing the NAV ECU. The risk justified the potential reward. Many lessons here. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(hdrygas @ Oct 3 2006, 12:38 PM) [snapback]327343[/snapback]</div> Quote:
| EV and MPG reset | grasshopper | Prius Technical Discussion | 8 | 02-25-2007 01:14 PM |
| Tire PRessure Reset Switch? Where is it?? (2006 Prius) | Gonzo | Care, Maintenance and Troubleshooting | 14 | 10-09-2006 03:57 PM |
| Car Seems to Reset Itself | Toonvox | Audio and Electronics | 7 | 03-22-2006 12:33 PM |
| Nav Reset? | Stilview | Prius Main Forum | 14 | 11-08-2005 11:25 PM |
| MFD Reset | Tideland Prius | Prius Main Forum | 4 | 12-01-2004 01:32 AM |
