Prius Technical Discussion This is a discussion on Does Adding A Front Mask Hurt The Gas Mileage within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi Everyone, I'm a New Prius Owner And Was Wondering If Anyone Knew If Adding A Front Mask Will Cut ...
Old 10-10-2006, 09:57 AM   #1
Winter
Will Cut Down On The Mileage Any? Thanks!!
Winter is offline
Old 10-10-2006, 10:15 AM   #2
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 5
minimal effect if any at all. hdrygas modified his with a zipper added to the slots that cover that radiator opening. in the winter he closes the zipper thus eliminating air flow and keeping the Prius warmer and helping to boost his gas mileage
DaveinOlyWA is offline
Old 10-10-2006, 12:10 PM   #3
David Beale
David Beale's Avatar
As Dave posted, doubt you could measure the difference. There would be slightly higher drag because air flow would be perturbed. If you closed off the vent openings there would be slightly lower drag, offsetting the drag caused by airflow perturbance of the material on the body.
If you normally cruised at 100 MPH you would notice the changes, but at speeds "normal people" travel at, probably not.
David Beale is offline
Old 10-10-2006, 01:55 PM   #4
Winter
Thanks Guys! I think I'll go with the 3-M mask. I can't seem to be able to get the other from the dealer guess they are not out from toyota yet or they are having supply problems..
Winter is offline
Old 10-10-2006, 11:37 PM   #5
hdrygas
If you mean one or another bra for the front the answer is no it does not appeal to effect the milage as far as I can tell. If you are speaking about a radiator blocker, yes it will improve the milage in winter. There are several levels of blockers. I personally think that Franks "lips" ( i.e. Cut halves of foam pipe insulation with notches cut into them for the supports are the best cheapest solution and my Prius bra blocker the best looking but at a considerable cost.
hdrygas is offline
Does Adding A Front Mask Hurt The Gas Mileage Winter Prius Technical Discussion 4 11-05-2006 11:10 PM
Does this help or hurt fuel mileage? mike_m Fuel Economy 1 05-16-2006 01:51 PM
How much do roof racks hurt Prius gas mileage? tedbramble Fuel Economy 12 05-15-2006 09:23 AM
Did the EV Button Hurt My Mileage? TonyPSchaefer Fuel Economy 12 04-04-2006 10:51 AM
Front End Mask mortdana Care, Maintenance and Troubleshooting 1 04-22-2004 06:57 PM
