Prius Technical Discussion This is a discussion on 2006 MFD interface GVIF? within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi, I was looking over the wiring diagrams for the 2006 MFD and I noticed that there is a connection ...
LinkBack (6) Thread Tools
Old 10-27-2006, 12:00 AM   6 links from elsewhere to this Post. Click to view. #1
momanz
Hi,
I was looking over the wiring diagrams for the 2006 MFD and I noticed that there is a connection between the NAV ECU and MFD labeled GVIF. Does anyone know if this is the same as the Gigabit Video Interface GVIF? If so I've located a SVGA to GVIF adapter... who wants to be the first to give this a go... it costs a paltry $1500. <_<
If anyone has their dash in pieces and wants to look, it should be a single wire(black) on a connector that is sky-blue (at the MFD). Guess my carputer is going to be connected through the backup cam...
-momanz
momanz is offline
Old 10-27-2006, 10:05 AM   #2
TheForce
I Plug-In My Prius
TheForce's Avatar
Nominated 7 Times in 2 Posts
Friends: 18
I've been looking into this for a few weeks now and this looks like our ticket to get high res video to the MFD. The link you provide is the only known source for an SVGA to GVIF converter that I can find. I'm very temped to buy it but I haven't looked into the stores return policy just in case it does not work. I'll try to do that today. I'm also looking into if some regular PC LCD monitors have this converter and if so I'm going to try to find a semi working LCD and try to use its SVGA to GVIF converter board as an experiment.
TheForce is offline
Old 10-27-2006, 10:16 AM   #3
Cheap!
Cheap!'s Avatar
Nice! I've been looking at that too from the DVD under the Seat as an easer access point as I was going to put the computer in the center consol between the two front seats, or under one of the seats if I can move the amp or nav unit. It just doesn’t mater where we hack in as long as we can convert to the right signal. I am opting for a car computer with a pop up screen from the center glass bin under the radio; however access to the MFD would still be great.
Let me know what I can do to help although I don’t have $1,500.00 lying around just to make the MFD work. I do have an extra monitor, and computer that I can take apart if the board you speak of is in there. Can you tell me more about what GVIF is?
* Classic Silver,
Prius Plus Plug-in Hybrid Electric Vehicle Conversion
*EV Button* Free Reverse Beep Mod, *Mirror Mod, * Aerodynamic hubcaps, * Almost Free Anytime Reverse Video, *Anytime Forward View Video, *Fumoto F103N Oil Drain Valve, *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch, *Dual Microphone Mod *In Dash DVD Theater, *V4 CAN-View </span>
<span style="color:#FF0000">Mods wanted in the near future - Hydraulic Brake -Pressure Indicator -Hobbits Vacuum “Good vs. Bad” Driving Indicator
Cheap! is offline
Old 10-27-2006, 10:19 AM   #4
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 18
If this is a true GVIF then all we need to do is find or make a cheap RGB/Composit/S-Video/SVGA to GVIF converter. Then us 2006+ Prius owners can have the regular CAN View or a PC hooked into the MFD. How wonderful that would be!
Do a google search for GVIF and you will find lots of data sheets on GVIF.
TheForce is offline
Old 10-27-2006, 10:33 AM   #5
Cheap!
Cheap!'s Avatar
Awesome, I'm on it.
Ok it seems the converter should be in a flat panel display. I have a mom and pop near my house that has been open for ten years and all they sell is monitors, CRTs and Flat panels. He repairs them too. So I'm off to tap his expertise on this subject and to see if he would not mind helping me do a test hack. It may take me up to a week to get there, but I will call him now.
EDIT:
I just got off the phone with him and he said there is a board in the flat panels that coverts the VGA signal back to digital and that it is part of the unit. (Unit being the whole flat panel) He said he really had no interest in assisting me with tiring to figure out what type of signal is in the Prius. He will however sell me a used panel for about $99.00. I have a used CRT that I could use as a trade in to help offset the cost.
I wish someone out there was crazy enough like me to try and take the Sky blue wire off of the MFD and tap it directly into another flat panel display. Before I do that I know there must be someone out there that could give us all the in's and out's of what is going on with this signal. If we can use the GVIF directly to another flat panel we may just be able to find a graphics card off the shelf that will do this conversion for us.
I just want a little more information from someone that works on repairing Flat Panel displays. The fact is we are not even sure what type of signal we are looking at.
Cheap! is offline
Old 10-27-2006, 10:43 AM   #6
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 18
<div class='quotetop'>QUOTE(Cheap! @ Oct 27 2006, 10:33 AM) [snapback]339247[/snapback]</div>
Awesome, I'm on it.
I'm not to sure on this but I think most LCDs may have the TMDS or some other kind of protocol. I have an LCD that has a burned out CC light at home but I haven't taken it apart yet. I wish you luck on finding a GVIF and I hope I have some luck to.
If I knew %100 that the $1500 converter would work or I could get %100 refund without restocking fees I would buy the converter.
TheForce is offline
Old 10-27-2006, 11:04 AM   #7
usbseawolf2000
HSD PhD
usbseawolf2000's Avatar
Friends: 47
It looks like Sony SDM N50PS and SDM-80N has GVIF technology.
Dennis
usbseawolf2000 is offline
Old 10-27-2006, 11:20 AM   #8
eagle33199
Platinum Member
<div class='quotetop'>QUOTE(Cheap! @ Oct 27 2006, 09:33 AM) [snapback]339247[/snapback]</div>
Awesome, I'm on it.
EDIT:
I've got two old flat panels at home that i got off Craigs List for 50 bucks (for both) a few months ago - I'll open one of them up this weekend and see what i can find out. I would LOVE to get this working.
eagle33199 is offline
Old 10-27-2006, 11:45 AM   #9
Cheap!
Cheap!'s Avatar
I think what we need is called an Analog to Digital Converter "A to D converter" A.K.A. "A/D converter." From what I am reading it should be 100% compatible too. It would make sense that the MFD would work using standard technologies and not some off the wall only in the Prius screen.
I am guessing the MFD has a converter in it for RGA to digital that forces the warning on the bottom of the screen. Also I'm guessing the MFD has a digital input like most new flat panel screens. However if we do use an a/d converter we should have no problem access the entire display area. I am also thinking that what has changed in the 2006 Prius is more the Nav unit and not so much the MFD. The new nav unit must now be able to transmit directly in digital format. From my reading some computer video cards can now transmit in both Analog and digital formats. If someone out there has one of those computers then should be ready to go less the tapping in. If it were me I would want to find the same connector that taps in the under the seat for a test. The wire is easy to get too, all you have to do is slide the seat all the way back, hook the wire and turn on the car to see what comes up.
An alternative to this would be to hook a flat panel with a digital input directly to the nav unit output. That might be the better solution as a new small flat panel monitor would be 100% refundable at most computer stores if this does not work.
I really do think we have the answer here and I would be very surprised if it did not work. As I said it just makes sense for Toyota to use a standard technology.
Cheap! is offline
Old 10-27-2006, 12:02 PM   #10
TheForce
I Plug-In My Prius
TheForce's Avatar
Friends: 18
Dont get the MFD/Rear Camera/NAV video connections confused.
The MFD accepts two types of video input.
1. GVIF for high res NAV video
2. Low res Composit with the check surrounding overlay at the bottom
Computers do have digital out but its in a different format called DVI. This is not compatible with GVIF. GVIF uses 1 cable to transmit a digital serialized RGB signal. DVI uses many cables to transmit different components of the video signal.
TheForce is offline
LinkBack to this Thread: http://priuschat.com/forums/prius-technical-discussion/25066-2006-mfd-interface-gvif.html
parmigio's prius Bookmarks on Delicious This thread Refback 08-13-2008 04:45 AM
Konverter - Prius Wiki This thread Refback 08-12-2008 04:50 PM
parmigio's bookmarks tagged with "prius" on del.icio.us This thread Refback 07-30-2008 01:22 AM
Konverter - Prius Wiki This thread Refback 06-19-2008 10:40 AM
parmigio's bookmarks tagged with "prius" on del.icio.us This thread Refback 05-16-2008 11:19 AM
Konverter - Prius Wiki This thread Refback 02-21-2008 11:18 AM
2006 Prius MFD GVIF Video Input TheForce Prius Modifications 73 01-16-2008 01:38 AM
'04 Audio Interface molain Audio and Electronics 0 10-01-2007 11:27 PM
2006 LCD Interface killian Audio and Electronics 0 05-03-2006 02:40 AM
Nav Video Interface AMARCUS Audio and Electronics 0 02-21-2006 07:22 PM
ODB-II Interface and software hclyatt Prius Main Forum 11 09-05-2004 10:45 AM
