| Prius Technical Discussion This is a discussion on 05 prius first drive questions within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; so i finally got registration for my 05 salvage prius, comments on how it drives. a lot more power than ... |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | so i finally got registration for my 05 salvage prius, comments on how it drives. a lot more power than the 01, much much quieter, suspension feels really nice and soft, very powerful on highway, navigation rocks, and last but not least the constant 50 mpg all the way to florida. anyway, is the new prius steering center position determined by computer, or physical means ( wheel alignment ) if i let go of my steering wheel its a bit turned to the right, doesnt sit in the center, it feels like wheel alignment but then again im not too sure my tires didnt wear unevenly. Also does anyone know where the stabilizer bar for the 05 prius bolts on to, i have a feeling its vibrating as a brake, because my engine and regen noise gets substianally louder when braking as if theres something connected to the drivetrain that is vibrating.
__________________ 2005 Toyota Prius Hybrid Package 9 2001 Toyota Prius 2005 Honda Accord Hybrid 3.0 V6 |
My Car: 2005 Prius Package: #5 Nominated 5 Times in 3 Posts TOTM Awards: 0 Friends: 21 | an alignment should correct the steering wheel off-center. should also reset the steering angle sensor when the alignment's done. the bar is bolted to the frame by means of of brackets with rubber isolator bushings. the ends are connected to the struts with swaybar links. hope that helps. |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | thanks galaxee, maybe the rubber bushings fell off or the bolts got loose, i must check it, thanks.i never really got a chance to look at the undercarriage, just to make sure everything is ok, id idnt really check the stabilizer bar or anything. |
| What Car Did You Drive Before Your Prius? | Husker4theSpurs | Prius Main Forum | 86 | 10-01-2008 01:14 PM |
| European Prius 2007 Questions, questions | montecarlomonaco | Audio and Electronics | 0 | 10-25-2007 05:18 PM |
| My first Prius drive.... :) | Dee67 | Prius Main Forum | 17 | 07-16-2007 07:17 AM |
| is it possible to drive off the lot with a '07 Prius | track 1 | Prius Main Forum | 11 | 02-08-2007 11:24 PM |
| Prius at the Drive-In | asills | Prius Main Forum | 0 | 01-08-2007 05:56 PM |
