| Prius Technical Discussion This is a discussion on 2002 Toyota Prius, Rattles then shuts off within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hello, I am new to this forum, hopefully I can get some help from you guys. I tried to start ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hello, I am new to this forum, hopefully I can get some help from you guys. I tried to start my car today and it was completely dead. I read on the forums that the 12 volt battery needs to be changed. Ran to the dealer and bought the 12 volt battery ($133 plus tax). Installed it and now it wont crank. It cracks but rattles and shuts off. Brake light shows up and so does engine light. I check my code and shows P1300 which is a ignitier circuit malfunction. Does anyone here know what might be the problem? My warranty is up, my car has 78K on it. I am afraid that it might be the hybrid battery? Thanks Ed |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, no, it's most likely an ignitor circuit, not the battery, like the car's trying to tell you. Check the AM2 fuse and IG2 relay, for starters... . _H* |
My Car: 2001 Prius Package: Pioneer #1 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 7 | [attachmentid=5640]They provide 12 volts to your circuits that may be ill. See attached diagram. Hobbit may not have it nailed on the head this time because if all 4 ignitors were down you would not even get this bad startup. I suggested in your other thread on this that one ignitor itself may be disconnected or ? |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Well, skipped work today just for this. Still trying to think what might be the problem. I check bother of the relays you told me, and both were fine. This morning, it started up, stayed on for a couple of seconds, then shut off. Then after that it just won't start again. |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | what does the multi information display show? the car with the exclamation point? or main battery warning? this may happen a lot if the vehicle sustains a engine problem or high voltage battery isnt working correctly. what does the multi information display show? the car with the exclamation point? or main battery warning? this may happen a lot if the vehicle sustains a engine problem or high voltage battery isnt working correctly. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(statultra @ Nov 9 2006, 11:45 AM) [snapback]346285[/snapback]</div> Quote:
It shows both. The exclamation point and the battery warning. It just wont crank up anymore, shows both lights and doesnt show the ready sign. I finally had it towed to SB Toyota. I was told they will have a look at it by Saturday, I can't wait that long but I guess there that busy. So your saying that it might have a engine problem or voltage battery isnt working? Are those covered under warranty? Anybody know what might be the problem, this uncertantity is eating me up! | |
My Car: 2005 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | if the car shows MAIN in red on the screen then it wouldnt start no matter what, its your high voltage battery that has a fault, make sure you consult your toyota dealer if you still have warranty, it might be HV battery premature failure or a failure on toyotas part. if MAIN battery warning icon is on the MFD then theres a major fault with the HV battery, i would first check hte service plug. and check your engine also for any problems, as those can drain the HV battery, i suggest you do not start it until you find hte problem ( only if u have the MAIN batt warning ) i had this problem with my 1st prius, video is on youtube with the icons, and i created a charger and charged the hv battery ( it was a salvage car ) i have a very strong feeling your HV battery has a problem, along with a engine problem, take it to the toyota dealer , it may be covered under the warranty for the hybrid system
__________________ 2005 Toyota Prius Hybrid Package 9 2001 Toyota Prius 2005 Honda Accord Hybrid 3.0 V6 |
| Prius Shuts Down In Snow | Russell | Prius Main Forum | 95 | 02-14-2007 07:01 PM |
| SOLD---2002 Toyota Prius Official Service and Repair Manual | tgregory | Private Sales | 0 | 05-08-2006 01:36 PM |
| 2002 TOyota Prius | gt88sd | Private Sales | 2 | 12-19-2005 12:58 PM |
| Prius shuts down at high speed | yoda | Prius Main Forum | 9 | 05-26-2005 09:36 AM |
| 02 Prius starts then shuts down w/ warning lights right away | Sapphireblue | Care, Maintenance and Troubleshooting | 11 | 02-26-2005 01:29 PM |
