Prius Technical Discussion This is a discussion on Display shows centigrade not Farenheit and other problems within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; I am now on my second display in one week. I have 2005 Prius. Problems (both times) temp display in ...
Old 11-14-2006, 11:26 PM   #1
RobinJM
I am now on my second display in one week. I have 2005 Prius. Problems (both times) temp display in Centigrade not Farenheit. First time air co did not work. Couldm't press down buttons. They changed display . One week later. Temp display went wacky again. I would press air co button on low and it would jump - by itself - to high. Then none of the buttons worked and it started blowing heat.
DIsplay also had gradated color... lighter blue on one side and darker blue on the other.
I went though posts and did not see any with a problem like this.
RobinJM is offline
Old 11-15-2006, 02:23 AM   #2
Presto
Has his homepage set to PC
Does the dealership know what they are doing? Without knowing more details, it may be a good guess that maybe the dealership isn't quite as knowledgeable as others. They installed the MFD a second time and it still showed temperature in metric? Did they just give it back to you and called it "good as fixed"?
Presto is offline
Old 11-15-2006, 10:30 AM   #3
RobinJM
<div class='quotetop'>QUOTE(RobinJM @ Nov 14 2006, 08:26 PM) [snapback]349311[/snapback]</div>
Good question. However, the problems with the 2nd display took about 5 days to show up. Very weird. If they had started right away I would have thought I'd gotten back the same display. Also 1st time I had no air co and no heat and this time I can't shut off the heat which insists on blowing on high. It's as if there is a ghost in the car... only kidding... but you get my point.
My gut is that it is an electrical or computer problem which is CAUSING both screens to act weird. I think they changed the screen to start with becasue it was much easier than diagnosing a computer/electrical/technical problem.
I was hoping someone here might have a similiar experience so I sould finally get my car back.
Robin
RobinJM is offline
Old 11-15-2006, 11:01 AM   #4
skruse
skruse's Avatar
Centigrade has not been used since the late 1940s. In the SI ("metric") and US system of measurement, temperature is measured in degrees Celsius. The US is a metric nation whether most people realize it or not (money, videos, computers, cars, paper, guns, skis, soft and hard drinks, etc.). Be thankful, that as with your Prius, you are ahead of the curve. To visualize and create a mental map, remember:
30's hot
20's nice
10's cold
Zero's ice
skruse is offline
Old 11-15-2006, 11:06 AM   #5
Nominated 1 Time in 1 Post
Friends: 24
This definately does NOT sound like a problem w/ the MFD itself. I, too, suspect a problem elsewhere...perhaps the computer for the AC and or the sensor for the AC. It is not a common issue...I've never seen anyone w/ a similar complaint in the 3 years this board has been here. It's one for the dealer to fix for sure.
efusco is offline
Old 11-15-2006, 11:50 AM   #6
skruse
skruse's Avatar
30's hot
20's nice
10's cold
Zero's ice
skruse is offline
Old 11-15-2006, 12:06 PM   #7
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 21
well if the new screen didn't fix it, sounds like it's time to try something else.
hubby has been extremely busy lately (sigh) but i can see if i can get some ideas from him tonight.
galaxee is offline
Old 11-22-2006, 01:17 PM   #8
DanMan32
I don't see how it can be anything but the display. Especially with the graduated color, though that could be the background 'wallpaper'. It does sound as if they installed the same display, either intentionally or accidentally.
But perhaps a power reset might be in order. Try disconnecting the 12V battery for a while. A bit drastic, as you lose all your presets (but not any of the NAV settings I believe) but that's a small price to pay.
DanMan32 is offline
Old 11-23-2006, 11:12 AM   #9
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 5
isnt there a way to change from Celsius to Fahrenheit? seems to me that was user settable. might want to check atilla's web site.
DaveinOlyWA is online now
Old 11-23-2006, 11:42 AM   #10
RobinJM
<div class='quotetop'>QUOTE(DaveinOlyWA @ Nov 23 2006, 08:12 AM) [snapback]353482[/snapback]</div>
I am very new to this: What is attilla's website address?
Thanks
RobinJM is offline
MFD shows 49.6, calculation says 52.4 ystasino Fuel Economy 20 06-18-2007 12:34 AM
Display Shows No Gas/Electric Activity bugmenot Prius Main Forum 5 02-22-2007 01:29 PM
Multi Function Display Problems nesboi Prius Technical Discussion 2 02-10-2007 10:18 PM
ICE runs but display shows everything off dachshund Prius Technical Discussion 6 10-01-2006 01:00 PM
Changing from Farenheit to Celcius ? georgekessel Prius Main Forum 16 08-06-2006 03:58 PM
