Prius Technical Discussion This is a discussion on 12 Volt Battery Monitor within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; After reading all the posts regarding the 12 volt battery problems I remembered I had a 12V voltage indicator from ...
Old 11-21-2006, 04:46 PM   #1
bogeybob513
rtc513
bogeybob513's Avatar
After reading all the posts regarding the 12 volt battery problems I remembered I had a 12V voltage indicator from my Bonneville that could be used to monitor that battery. Mine is a Whistler, has a digital readout and three indicator lights (red/yellow/green). It plugs into one of the power outlets and gives a constant reading. When the car is not running it will give you the battery voltage. When running, it gives you the charging voltage. I wouldn't keep it in when not running as it will drain the battery a little.
I went to whistlergroup.com but could not find the voltage indicator there. I'm sure you can pick it up in any auto parts store.
bogeybob513 is offline
Old 11-21-2006, 06:20 PM   #2
hobbit
hobbit's Avatar
I'd rather have a real voltmeter. Well, so I do. It lets me watch
small deltas as things turn on and off, giving me a rough idea of
how much power they draw..
_H*
hobbit is offline
Old 11-22-2006, 09:51 AM   #3
FireEngineer
Your device won't work very well in a Prius. The power outlets are not powered when the car is off. When the car is powered the inverter gives a very nice constant voltage to the 12 volt system. You need something more direct like Hobbit mentioned.
Wayne
FireEngineer is offline
Old 11-22-2006, 10:04 AM   #4
DanMan32
The MFD diagnostic screen provides a digital voltmeter.
DanMan32 is offline
Old 11-22-2006, 10:23 AM   #5
bogeybob513
rtc513
<div class='quotetop'>QUOTE(FireEngineer @ Nov 22 2006, 09:51 AM) [snapback]352976[/snapback]</div>
Wayne
It works very well when the the car is on. I just suggested this device for those who are concerned about the status of their batteries as they grow older. Obviously, any voltage under 12 would be an indication of a battery going bad.
Old 11-22-2006, 11:02 AM   #6
DanMan32
<div class='quotetop'>QUOTE(bb513 @ Nov 22 2006, 10:23 AM) [snapback]352991[/snapback]</div>
Not when off. 10-11V is not uncommon for a battery voltage.
DanMan32 is offline
Old 11-22-2006, 11:37 AM   #7
c4
In the 11V range I'd agree would be non-indicative of any kind of fault, but if the battery voltage drops down to 10V while the vehicle is off, this means that the battery is either bad/going bad or is very low in charge, and you'd better keep an eye on it..
Remember, because the converter puts out a fixed voltage, this means that the charge rate to the 12V battery is effectively current limited and it can take *much* longer for the vehicle systems to recharge a dead/low 12V battery than a conventional vehicle.. If your vehicle required a boost, do *NOT* count on a 20 minute drive being able to recharge the 12V battery to a healthy state- you should connect the battery to a 115V mains-powered charger as soon as possible, otherwise you may walk out to another dead battery the next day..
c4 is offline
Old 11-22-2006, 12:49 PM   #8
DanMan32
The DC-DC converter actually has 2 voltage outputs, very close to each other. 13.8 versus 14 I think, based on the sensed state of charge on the 12V battery.
DanMan32 is offline
Old 11-22-2006, 12:55 PM   #9
bogeybob513
rtc513
<div class='quotetop'>QUOTE(DanMan32 @ Nov 22 2006, 10:04 AM) [snapback]352983[/snapback]</div>
How does one obtain a MFD diagnostic screen?
Old 11-22-2006, 01:11 PM   #10
DanMan32
Excellent question.
One way is to hold down the Info button on the bezel and flash the taillights 3 times.
The other way is to press the 'display' button, then touch the left half of the screen, first under the top banner, then above the lower banner, doing this three times. Much like the speed override.
DanMan32 is offline
12-volt battery jamarimutt Prius Main Forum 2 06-25-2007 08:15 PM
12 volt Battery kkayser Prius Technical Discussion 4 03-15-2007 12:33 PM
What is the 12 volt battery for? toad Prius Technical Discussion 7 01-29-2007 10:02 PM
I need a new 12 volt battery, Which One???? toyotatacoma Prius Technical Discussion 8 10-25-2006 12:29 PM
12 Volt Battery corvo3 Care, Maintenance and Troubleshooting 7 02-10-2006 05:44 PM
