Prius Technical Discussion This is a discussion on please help multiple problems within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi ya all. I have been reading this chat for a while but just today registerd up. I have a ...
Old 12-02-2006, 05:21 PM   #1
cvd383
Hi ya all. I have been reading this chat for a while but just today registerd up. I have a 05 prius with lots of problems. I have no power steering, Every warning light is on and the climate controle is all messed up, I can see the buttons but i can not get them to do anything,they are very light. I am wondering if there is one ECU that controles all of these items, I have 4 other parts cars so I should have what ever that it needs. If any one can help I would appricate it greatley. Thanks Casey
cvd383 is offline
Old 12-02-2006, 10:12 PM   #2
derkraut
derkraut's Avatar
Package: #8
You have 4 other Prius parts cars???? Holy Moley! Regarding your problems, if your car is a 2005 as you say, it is under warranty. Take it to a Toyota dealer. <_<
derkraut is offline
Old 12-02-2006, 10:17 PM   #3
galaxee
running WOT until out of fuel
galaxee's Avatar
Nominated 5 Times in 3 Posts
Friends: 21
no one ecu that controls all that.
audio controls working ok?
does the car go into ready mode? does it drive at all?
warning lights on the mfd?
sounds like what you've got going on is way more than can be picked through on a website, might wanna take this up with your local dealer.
galaxee is offline
Old 12-04-2006, 09:37 AM   #4
eagle33199
Platinum Member
With all those problems and the available parts cars, is this a salvage attempt of some sort?
FWIW, take it to the dealer, there's a hell of a lot going on there, and it's gonna be impossible to troubleshoot it online.
eagle33199 is offline
Old 12-04-2006, 10:17 AM   #5
hobbit
hobbit's Avatar
And if you *do* have a bunch of parts you don't necessarily need
right away, there are probably a bunch of people around Madison
who want to know how to get in touch with you!
_H*
hobbit is offline
Old 12-04-2006, 03:49 PM   #6
cvd383
It is a salvage car, it was hit on the left side but it was all cosmetic damage, only paint. I have the other cars for parts, any one that needs parts can contact me through my email, I had a post under parts but it was removed. As for as taking the car to the dealer I will if nessary, I just dont want to pay the cost if it is something simple.The audio does not work , it says audio off. Thanks for all of the info so far and if I figure out what it is I will post it so every one knows. Thanks again Casey
cvd383@yahoo.com
cvd383 is offline
Old 12-04-2006, 03:57 PM   #7
richard schumacher
nacreous lacquer
As resident expert galaxee has not written, I'll observe that a Prius is very complex. You'll need Toyota's proprietary diagnostic device and the complete shop manual to have any chance of diagnosing and fixing everything that might be wrong. I hope you did not pay very much for this salvage.
richard schumacher is offline
Old 12-04-2006, 04:46 PM   #8
eagle33199
Platinum Member
and like we've said... there's a lot wrong with the car, and it's going to be impossible to tell you how to fix it/what parts to replace online - especially since it was involved in an accident and has a salvage title.
Salvage titles don't go on cars that only had cosmetic damage.
A salvage title is an automobile title with a notation that the vehicle has been damaged in excess of approximately 75% of its previous market value.[/b]
Take the car to a dealer if you want it fixed. It's too complex for someone but a trained Prius tech with the shop manual and the scanning tools to diagnose and repair.
Old 12-07-2006, 04:39 PM   #9
slvr_phoenix
Tinker Gnome
<div class='quotetop'>QUOTE(cvd383 @ Dec 2 2006, 04:21 PM) [snapback]356766[/snapback]</div>
I'd check to see that your 12V battery is connected properly. Might be a loose connection somewhere.
slvr_phoenix is offline
Old 12-05-2007, 07:29 PM   #10
fruzzetti
Customization-Obsessed
fruzzetti's Avatar
Send a message via AIM to fruzzetti
though it's true you may not be able to perfectly debug the car, it's also fairly simple to trace many of the issues to the most common logical breaking point (you may not be able to fix a fried IC but you might be able to logically and physically locate said IC in the car if you're \/\/illing to spend the time).
do you have the cd changer option in the car? if so, check the disc slot indicator lights. if the connectors are loose or even one pin is bent you might get the issue i have seen before: even if the stereo is playing, you only have volume control and steering \/\/heel buttons to control it as secondary po\/\/er to the unit is not connected.
fruzzetti is offline
Inserting Multiple CD's Marvinh Prius Main Forum 14 07-27-2007 12:48 PM
Multiple quotes chimohio PriusChat Website Questions 4 10-17-2006 07:48 PM
Multiple Prii together chimohio Prius Main Forum 7 09-25-2006 08:34 AM
Have You Been on Multiple Lists? New Revelation Prius Main Forum 7 09-24-2006 11:21 PM
Multiple Sightings penpendisarapen Prius Main Forum 0 03-02-2004 04:42 PM
