| Prius Technical Discussion This is a discussion on Can-View / Prius PHEV Conversion Question within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; This is a question for anyone who has a converted Prius PHEV or anyone who has CAN-View. I want to ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | This is a question for anyone who has a converted Prius PHEV or anyone who has CAN-View. I want to know if any one else is seeing this. When the Prius is in EV only mode and you go for a while but less then two miles, are you seeing "Engine spin" on the CAN-View? We are seeing that on one conversion and I want to know if anyone else is seeing it too. It has been suggested that the ICE spins to pump the gear oil onto the power split device. If this is the case I am trying to figure out how the Prius knows the PSD needs lubrication? But first I need to figure out is this happening to anyone else. Could you post here if you know anything? Thanks
__________________ * Classic Silver, Prius Plus Plug-in Hybrid Electric Vehicle Conversion *EV Button* Free Reverse Beep Mod, *Mirror Mod, * Aerodynamic hubcaps, * Almost Free Anytime Reverse Video, *Anytime Forward View Video, *Fumoto F103N Oil Drain Valve, *Almost Free Speed Wire Interrupt, *Almost Free Navigation Override switch, *Dual Microphone Mod *In Dash DVD Theater, *V4 CAN-View </span> <span style="color:#FF0000">Mods wanted in the near future - Hydraulic Brake -Pressure Indicator -Hobbits Vacuum “Good vs. Bad” Driving Indicator |
| Senior Member Join Date: Oct 2005 Location: Seattle, Wa
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I recently wrote on this topic here: http://priuschat.com/index.php?showtopic=1...pin&st=258# Basically, "ICE Spin" is the >42mph equivalent of "Stealth" mode. So, if you're seeing "ICE Spin" while above ~40mph it's all normal. |
My Car: 2004 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(Cheap! @ Dec 5 2006, 10:48 AM) [snapback]357714[/snapback]</div> Quote:
My best is 26.35 km without engine spinning. I have my tacho-meter and CAN message display device. Ken@Japan | |
| | #4 | ||
My Car: 2004 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(ken1784 @ Dec 4 2006, 06:14 PM) [snapback]357730[/snapback]</div> Quote:
<div class='quotetop'>QUOTE(Cheap! @ Dec 4 2006, 05:48 PM) [snapback]357714[/snapback]</div> Quote:
My Car: 2004 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(hdrygas @ Dec 5 2006, 12:33 PM) [snapback]357763[/snapback]</div> Quote:
My case was between 0 and 60 km/h, average speed was 29 km/h. Ken@Japan | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | <div class='quotetop'>QUOTE(ken1784 @ Dec 4 2006, 09:56 PM) [snapback]357776[/snapback]</div> Quote:
Thanks. Do you have access to accessories for your cars there we just don't have here? | |
My Car: 2004 Prius Package: G Touring Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 3 | <div class='quotetop'>QUOTE(Cheap! @ Dec 5 2006, 01:05 PM) [snapback]357782[/snapback]</div> Quote:
http://priuschat.com/index.php?showtopic=20117&hl= http://khb00465.atnifty.com/ms-1.html (Japanese only) Prius CAN Monitor http://priuschat.com/index.php?showtopic=25759&hl= SuperMID T-1 : Tacho and temp gauge SuperMID M-1 : Mileage meter SuperMID C-1 : CAN message decoder http://priusdiy.fc2web.com/ (Japanese only) Ken@Japan | |
My Car: 2005 Prius Package: #6 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(Cheap! @ Dec 4 2006, 05:48 PM) [snapback]357714[/snapback]</div> Quote:
I have a 2005 with package #5 (which includes NAV) and wanted to know exactly which items I need to order. I know it's the CAN-View V3 and that I'll need the relay board for the PHEV conversion (which I wouldn't do for several years, but want the CAN-View now). What other cabling, etc. is needed? I know that you can email eflier to order, but what is the ordering process after knowing exactly what I want. Can everything be done via email, or can I make a phone call when I get to the state where I actually order. Thanks for any info. Dave M. | |
| Silver Business Sponsor Join Date: Jul 2005 Location: Fraser Valley BC
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(dmckinstry @ Dec 9 2006, 08:36 AM) [snapback]359723[/snapback]</div> Quote:
Apart from continuing interest in seeing more Prius data displayed, which at present outnumbers requests for relay versions about 3:1, I have seen increasing interest in possible plug-in conversions. I believe that, largely due to the work of www.calcars.org, we are a lot closer now to seeing a complete do-it-yourself kit being offered early next year and I am gratified that CAN-view will be a (small) part of this. I have my own private 'beef' in that while there is a lot of information about prototype plug-in conversions and how, if you drive real, real, careful, you can get XXX mpg, but its hard to find details on what you can expect from such a conversion if you just get in and drive without any thought to keeping the speed under 32mph, or the throttle under 60% or whatever, just get in and enjoy the Prius drive. And I also can't understand people arguing about cost benefits (or lack of any) for such conversions. Who really bought a Prius to save money? Once these kits become available, the biggest hurdle will probably be people saying "i'm just going to wait till next year when Toyota will have a fully warrantied plug-in hybrid without any hassles." I think that while Toyota may now have its own Lithium technology working, it will want to wait several years to compile real-world figures for reliability before it unleashes hundreds of thousands of plug-in Prii on the world, with it being responsible for warranty cost for maybe 8 years. So I may be opening a can of worms here, but in my opinion, don't expect to buy a Toyota plug-in Prius this decade. (Ends posting and waits for howls of outrage) | |
| Prius PHEV Conversion Controller KIS Project (mine) | WizBandit | Prius Technical Discussion | 2 | 11-17-2007 01:13 AM |
| PHEV Conversion | ibcs | Prius Technical Discussion | 31 | 11-02-2007 02:07 PM |
| PHEV Conversion | mrbigh | Prius Modifications | 37 | 10-17-2007 12:22 AM |
| What about a 2003 PHEV conversion? | brandonlchavez | Prius Modifications | 4 | 07-30-2007 12:20 PM |
| Question of EV mode in PHEV conversion | paulccullen | Prius Modifications | 14 | 12-20-2006 11:06 AM |
