| Prius Technical Discussion This is a discussion on Fuel pump sound after shutdown within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Just learning the nuances of my new 07. After shutdown, it sounds like the fuel pump runs for 5 seconds ... |
| Junior Member Friends: 0 | Just learning the nuances of my new 07. After shutdown, it sounds like the fuel pump runs for 5 seconds then shuts down. Is this what I'm hearing? Why would the system run up pressure after shutdown instead of prior to start up? Found the post on disabling the annoying reverse beep...THANKS. Now we are a 2 Prius family. An 01 and 07... W would be proud! |
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | That's the coolant storage pump. Your Prius has a thermos that stores hot coolant and keeps it warm for up to 48 hours...this is then pumped back into the engine upon start up to warm the heads with reduces emissions that would otherwise result from a cold start. |
| Senior Member Join Date: Jan 2006 Location: Somerville, MA
My Car: 2006 Prius Package: #9 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Yes, I think it's new on the 2004 generation. In summer you can barely hear it, in winter it seem to make quite a bit more noise, at least mine does. It really helps the engine heat up quite a bit faster and yet another reason you don't need to "warm up" your engine in the winter. I simplu push start and then drive (carefully) for the first 5 minutes |
My Car: 2006 Prius Package: #7 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 6 | <div class='quotetop'>QUOTE(walkinghat @ Jan 24 2007, 07:56 AM) [snapback]379980[/snapback]</div> Quote:
Tom | |
| Ever wonder how the ICE shutdown sounds like from outside? | usbseawolf2000 | Prius Main Forum | 13 | 12-21-2007 09:07 AM |
| Fuel Pump | madgeneticist | Care, Maintenance and Troubleshooting | 4 | 06-27-2006 01:10 PM |
| ICE shutdown roughness | mdh | Prius Main Forum | 13 | 05-11-2006 03:47 PM |
| How do you shutdown? | leeskarha | Prius Main Forum | 19 | 07-24-2005 08:10 AM |
| ice shutdown vibration | toolbox | Care, Maintenance and Troubleshooting | 6 | 10-12-2004 04:43 PM |
