| Prius Technical Discussion This is a discussion on Traction Control Dangers and Engine Braking Savior within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi Silver Phoenix, Can you tell us what speed this drop out of regen braking occurs at? Maybe the slip ... |
| | #21 |
My Car: 2006 Prius Package: #2 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi Silver Phoenix, Can you tell us what speed this drop out of regen braking occurs at? Maybe the slip causes the wheel to drop down to 7 mph rotation speed. Which of course would cause the Prius to do the normal switch to friction braking. In my previous standard car, I instincively would reduce brake coming to a stop, to feather the onset of static friction. Now I find I instinctively increase brake pedal pressure coming to a stop in aticipation of the change over to the much weaker friction brakes. |
| Traction Control | rlaurent | Prius Technical Discussion | 130 | 06-13-2008 03:28 PM |
| Traction Control | adamwmcanally | Care, Maintenance and Troubleshooting | 8 | 05-14-2007 10:36 AM |
| Traction Control | dhoward | Prius Main Forum | 22 | 04-27-2007 09:22 AM |
| Traction Control | sparkymarvin | Prius Modifications | 42 | 06-07-2005 02:38 PM |
| Traction Control | kevin54 | Prius Main Forum | 9 | 04-08-2005 11:12 AM |
