Prius Technical Discussion This is a discussion on 2004 Prius engine runs when when screen says it's off within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Ever since I took my 2004 Prius in for a recall, the engine has continued to run at times when ...
Old 03-04-2007, 09:53 PM   #1
GaryK
Ever since I took my 2004 Prius in for a recall, the engine has continued to run at times when the screen shows it should be off. I had the service people take a took at it, and they ran tests, but claimed they couldn't find anything wrong with it.
Has anyone else had this experience, and if so, was there a cure?
Thanks,
Gary
GaryK is offline
Old 03-04-2007, 09:59 PM   #2
cwerdna
<div class='quotetop'>QUOTE(GaryK @ Mar 4 2007, 06:53 PM) [snapback]400102[/snapback]</div>
There is NO indication on the MFD showing whether the ICE is on or off. There's no "cure".
cwerdna is offline
Old 03-04-2007, 10:00 PM   #3
Tideland Prius
Super Moderator
Tideland Prius's Avatar
Friends: 11
It's an "Energy Monitor"
so.. if the engine isn't charging the battery, then it won't show the arrows.
Tideland Prius is offline
Old 03-04-2007, 10:07 PM   #4
GaryK
<div class='quotetop'>QUOTE(Tideland Prius @ Mar 4 2007, 10:00 PM) [snapback]400105[/snapback]</div>
So why is the engine running then, and why didn't it do this before the recall? The engine now tends to run while coasting to a stop, and then only stops when I step on the accelerator. That does not seem normal to me.
GaryK is offline
Old 03-04-2007, 10:30 PM   #5
DFWPrius
<div class='quotetop'>QUOTE(GaryK @ Mar 4 2007, 11:07 PM) [snapback]400114[/snapback]</div>
If your recall was updated software, their have been a few cases where Prius shut down on the freeway.
The fix was to program the ICE to run a bit longer or to run at times in the past it would have shut down.
I have not seen a posting on shut down on the freeway since the update to software.
Of course take mechanic for a test ride to confirm would be a good idea.
DFWPrius is offline
Old 03-04-2007, 10:39 PM   #6
GaryK
<div class='quotetop'>QUOTE(DFWPrius @ Mar 4 2007, 10:30 PM) [snapback]400123[/snapback]</div>
Interesting. That was the reason for the recall I took it in for, although I had never had the engine stop on me. The same day I brought it back, it ran for 5 minutes after I put it in park. I was told that the ICE had lost "my" driving habits, so I once it "learned" how I drove, things would be back to normal, but it's been about 15 months now and still does not work like it used to. I used to get 60 plus mpg on nearly every tank, but now it's usually 55 mpg at best.
GaryK is offline
Old 03-05-2007, 01:14 PM   #7
Tideland Prius
Super Moderator
Friends: 11
Hmm... I can't say it hurt my mileage after I did the recall since I was still in the break-in period.
I have heard about the 'learning' bit but again I can't give you my experience since I took the car in for the recall pretty much a year after I bought it and I was learning how to drive the Prius efficiently at that time.
Old 03-09-2007, 12:51 PM   #8
sebapisa
sebapisa's Avatar
<div class='quotetop'>QUOTE(GaryK @ Mar 4 2007, 08:07 PM) [snapback]400114[/snapback]</div>
I've noticed that too with my non-recalled '07. I understand that the MFD is an energy monitor but if the ICE is not charging the battery or moving the car it's not going to show any arrows, which is ok.
However I think you have a point because IF the ICE is not charging or moving the car then WHY is it on? The smart computers in the car should turn it off.
An answer I can think of, and take this from a new onwer, is that the ICE is running to stay warm.
Hope it helps.
sebapisa is offline
Old 03-09-2007, 07:45 PM   #9
Ari
Ari's Avatar
<div class='quotetop'>QUOTE(GaryK @ Mar 4 2007, 10:07 PM) [snapback]400114[/snapback]</div>
Is your battery fully charged when you observe this? I can induce the "engine running" condition on a daily basis by going over a big hill on my way to work. At the bottom of the hill there is a STOP sign and 99% of the time my battery will be full. At that point the computer forces the engine to turn over to drain excess battery power.
It's a "feature" not a bug
Ari is offline
Old 03-09-2007, 08:05 PM   #10
hill
High Fiber Member
hill's Avatar
My 04 does the same thing . . . prior to & after ECU upgrades. I'm guessing it does it sometimes because the smog crap feels the ICE ought to be warmer, as it tends to be happening below 70 degrees (of course if the batterys aren't full charged, that does it too). How I cure it: When you roll up to a stop, just prior to stopping I throw it in 'N'. Then as soon as it stops I throw it in 'P'. ICE stops. Then I just throw it back into 'D'.
Well it's corny, but it works . . . or I just let the dang ICE thing do it's thing, if other folks are in the car . . . so they won't know how OCD I am.
I Heart My Prius Chat
hill is offline
Engine Runs a Lot? mcontrols Fuel Economy 2 06-06-2007 09:47 AM
Engine runs too much and shudders before turning off losangeleschet Care, Maintenance and Troubleshooting 19 07-06-2005 11:54 AM
2004-2005 Prius M.F.D Screen Hood Shades robinredbreast Sponsored Commercial Sales 0 01-19-2005 08:38 PM
2004-2005 Prius Display Screen Hood's FOR SALE robinredbreast Sponsored Commercial Sales 9 10-13-2004 05:53 PM
2004 Prius Awarded International Engine of the Year randalla Prius and Hybrid News 2 07-02-2004 02:02 PM
