Prius Technical Discussion This is a discussion on post 5000 mile service within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; ok...so i will probably be either ignored or snubbed for asking but i can resist no longer. i got my ...
Old 03-06-2007, 12:07 AM   #1
meshell
meshell's Avatar
Unhappy
ok...so i will probably be either ignored or snubbed for asking but i can resist no longer. i got my 5000 mile service 1 1/2 weeks ago and ever since i think my gas mileage has gone down. is there something that they do or tweak that could make this happen?
meshell is offline
Old 03-06-2007, 01:00 AM   #2
Bill Merchant
absit invidia
Bill Merchant's Avatar
Nominated 6 Times in 1 Post
Nominated TOTM Awards: 1
Friends: 53
Talking
Neither ignored nor snubbed, though, IMHO, your avatar is rather revolting...
A couple of things could have happened.
If they put in too much oil, that can sometimes cause problems. It's easy to check, the level is optimally at to just below the Full mark. If it's 1/8" (3mm) over, that's still OK. If it's 1/4" (6.5mm) over, the engine could be sucking oil. It won't actually damage anything, but it might throw a few Check Engine codes while it reduces your MPG.
If they disconnected the 12V battery for any reason, that can make the computer forget your driving technique. It learns to optimize for your driving, so it may have to re-learn if it was powered off.
If the oil is way high, get them to take some out, maybe they will learn to not overfill. If the oil is OK, see how your MPG is after a couple of tanks of gas. We watch our cars so closely, a little change may seem like a big shift, something you'd never notice on a Hummer.
Also, check your tire pressure. That is an easy screw up that is also easily corrected.
Bill
2007 NL 5 Silver Wraith
2005 BC 6 Silver Cloud
Portland Area HSD Meetup Group: PortlandHSD.info Become carbon neutral: Carbonfund.org or TerraPass.com
Bill Merchant is offline
Old 03-06-2007, 08:36 AM   #3
Nominated 1 Time in 1 Post
Friends: 24
Yup, check the tire pressure especially. I run mine at 42f/40r and have not yet had it set properly at the dealer even when they took it back to get it right after I found it off. But low tire pressure would be #1 likely cause and oil level too high #2. Finally, you didn't say how far you've driven since that service or if the weather has been colder or anything. It's unlikely they've done anything serious to your car and I suspect things will correct on their own once you've assured proper tire pressure and oil level.
efusco is offline
Old 03-06-2007, 08:40 AM   #4
dmckinstry
<div class='quotetop'>QUOTE(efusco @ Mar 6 2007, 05:36 AM) [snapback]400808[/snapback]</div>
You beat me to it Evan. I haven't actually requested the dealer to set my tire pressure higher, but they said it should be down at (37/35 or was it 35/33). In any case if you don't say anything to them, if you have your pressure set higher they will lower it.
Dave M.
dmckinstry is offline
Old 03-06-2007, 12:54 PM   #5
Charles Suitt
Charles Suitt's Avatar
Send a message via Yahoo to Charles Suitt
Quote Bill: "...your avatar is rather revolting..."
I agree with Bill... my solution to such is to utilize the "IGNORE" function available in PriusChat. :P
I suppose some forum members thing it's 'cute,' but to me it is reminscent of a child seeking attention.
As for the query... Previous posts are 'on target.' Sounds like tire pressure has been restored to "Toyota recommended."
Charles Suitt is offline
Old 03-10-2007, 02:23 AM   #6
D1CK1E
His avatar is fine. If that very mild animation bothers you.. how do you make it through every day life?
D1CK1E is offline
Old 03-12-2007, 01:32 PM   #7
Charles Suitt
Hi D1CK1E
Thanks for asking. I make it 'through life' very well. I'm grateful for the "Ignore" feature on PriusChat.
Old 03-12-2007, 02:08 PM   #8
Ichabod
Artist In Residence
Ichabod's Avatar
Send a message via AIM to Ichabod
Friends: 7
The ignore feature doesn't block avatars, as far as I remember... but I think that avatar is fine... a little amusing even. That character is thoroughly enjoying a nice glass of chocolate milk... Or he's drinking the excess oil put into his car by the service technician.
Ichabod is offline
Old 03-15-2007, 12:16 PM   #9
bredekamp
bredekamp's Avatar
<div class='quotetop'>QUOTE(Bill Merchant @ Mar 6 2007, 09:00 AM) [snapback]400755[/snapback]</div>
The avatar you're talking about is called "Cheese" and he likes:"chocolate miiilk". It is a character from the cartoon series Fosters' Home for Imaginary Friends. Please don't ask me how I know that.
bredekamp is offline
5000 mile service - the dealer DIDN'T overfill the oil! Jeannie Care, Maintenance and Troubleshooting 2 10-15-2006 07:25 PM
5000 mile service thaight PriusChat Website Questions 6 05-14-2006 11:37 AM
5000 Mile Service Somechic Prius Main Forum 1 11-11-2005 10:40 AM
Need advice for 5000 mile service tomorrow. prius04 Prius Main Forum 13 12-18-2004 09:43 PM
5000 mile service - pleasantly surprised! niferbee Care, Maintenance and Troubleshooting 21 08-12-2004 04:28 PM
