Prius Technical Discussion This is a discussion on Cold weather cut out within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; After driving about 10 miles on the freeway with the temp around zero fahrenheit, I tried to accelerate, but the ...
Old 03-06-2007, 03:45 AM   #1
kkayser
After driving about 10 miles on the freeway with the temp around zero fahrenheit, I tried to accelerate, but the gas engine cut out completely. Only when I let up on the accelerator did the gas engine start running again. I could not go over 45 mph, really quite scary. Anyone know the problem? Prius is a 2004.
kkayser is offline
Old 03-06-2007, 08:23 AM   #2
Nominated 1 Time in 1 Post
Friends: 24
Absolutely not normal. Interesting that both you and your 'friend' are having problems with your Prius.
efusco is online now
Old 03-06-2007, 11:55 AM   #3
brick
brick's Avatar
That's the kind of thing that ought to throw a light show and a code if it's actually a problem with HSD.
The only thing I can think of that might not throw a code is a bad sensor in the accelerator. Could be that there's a dead zone, though I don't know how they work so it's hard to say if it's possible. To the dealer you must go...
brick is online now
Old 03-06-2007, 12:14 PM   #4
JayGoldstein
I've experienced something similar on a couple of occasions under very cold (-20C and below) conditions.
Hard acceleration caused extreme surging (it felt like the ICE died momentarily and then kicked in again). It is a scary feeling! When this happened, gentle application of the throttle prevented further surging.
My experience differed from yours in that I had no problem exceeding 45 mph (72 km/h) when the surging stopped.
JayGoldstein is offline
Old 03-06-2007, 12:28 PM   #5
DaveinOlyWA
Opps !! I Did it Again!!
DaveinOlyWA's Avatar
Friends: 5
at that temp, could be gas line freeze up would be the first thing i look at.
DaveinOlyWA is offline
Old 03-06-2007, 12:36 PM   #6
usbseawolf2000
HSD PhD
usbseawolf2000's Avatar
Friends: 47
What is the condition like in WI? Is it snowing? Are you driving on slippery surface? Do you see the Traction Control light come on?
If No then it doesn't sound normal.
usbseawolf2000 is offline
Old 03-06-2007, 02:28 PM   #7
kkayser
<div class='quotetop'>QUOTE(DaveinOlyWA @ Mar 6 2007, 11:28 AM) [snapback]400942[/snapback]</div>
Can't be that. All gasoline here contains 10% ethanol.
kkayser is offline
Old 03-07-2007, 10:00 PM   #8
DaveinOlyWA
Friends: 5
<div class='quotetop'>QUOTE(wauwis @ Mar 6 2007, 11:28 AM) [snapback]401040[/snapback]</div>
Can't be that. All gasoline here contains 10% ethanol. [/b]
same here and IF everything was always as it should be, i would never think that you got a bad batch of gas that had excessive water in it
Cold Weather Mileage voi9 Fuel Economy 35 12-12-2007 11:18 PM
Cold Weather and CVT Dcnight Prius Main Forum 23 01-22-2005 10:12 AM
EV Defeated in Cold Weather??? daniel Prius Modifications 14 01-04-2005 04:31 PM
Cold weather and the SOC jfschultz Prius Main Forum 1 12-21-2004 09:37 PM
Cold Weather is killing us! priusham Fuel Economy 30 11-23-2004 10:40 PM
