| Prius Technical Discussion This is a discussion on ev mode and regen within the Prius Technical Discussion forums, part of the Toyota Prius Forums category; Hi All, I am a newbie and will probably ask all the newbie questions have done some searches but have ... |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | Hi All, I am a newbie and will probably ask all the newbie questions have done some searches but have not yet seen this listed... If I had an EV mod done , would you get regen if you take your foot of the throttle pedal when going down a hill? or even brake regen? also How many green bars should a fully charged traction pack show, I have seen different sites some say 8 some say 7 I know there must be a set number there??? I have a brand spankin new 1 mile well now 25 mile 07 prius HE package dont need the nav. JBL etc... but I have built an electric vw fox car can be seen at this link or web address..http://www.austinev.org/evalbum/896 and with a diode and rehostat installed I can have regen on my fully electric vehicle. Also why is the ev mode limited to 1.5 miles? on the prius ev mod? I have used it more without the kit ( no kit yet) seems like the lighter the touch on throttle the better. it just seems as a waist of more money for a mile and a half. thanks and sorry for the long post will shorten next time.. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | I added an EV switch to my 2006 prius yesterday. That is a great question. I just assumed that the regen would still work the same in EV mode, but I do not know. I will be watching for an answer to that question also. I went to your EV site, that is some interesting stuff. |
My Car: 2006 Prius Package: #7 Nominated 7 Times in 2 Posts TOTM Awards: 0 Friends: 18 | Everything works the same with the EV mode except you can accelerate a little faster and harder on just electric. |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(theforce @ Mar 10 2007, 07:36 PM) [snapback]403599[/snapback]</div> Quote:
| | #5 | |||
My Car: 2004 Prius Package: #9 Nominated 1 Time in 1 Post TOTM Awards: 0 Friends: 24 | <div class='quotetop'>QUOTE(regenme @ Mar 10 2007, 08:55 PM) [snapback]403585[/snapback]</div> Quote:
My Car: 2005 Prius Package: #3 Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 4 | Your watchword with EV mod should be "easy does it". Use it sparingly in situations where running the ICE makes no sense. Moving the park a short distance in a parking lot, from the garage to the street and situations like that. Excessive use will actually hurt your mileage because you'll more than likely have to burn a lot of gas to recharge it. Don't get me wrong, the EV mod is great, it's cool, and it can save you a wee amount of gas here and there, but you have to use it judiciously or you'll actually waste more gas than you're saving.
__________________ Cheers, Tripp 2005 Silver Pkg 3, OEM Block Heater, Coastal Tech EV mod, BT Tech Chassis Stiffener, hell damned infernal reverse beep disabled Boulder Real Estate ![]() Howay the Toon!"Sometimes when you aim for the stars, you hit the moon." -- Ian Holloway |
| Senior Member Join Date: Oct 2005 Location: Seattle, Wa
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(regenme @ Mar 10 2007, 07:55 PM) [snapback]403585[/snapback]</div> Quote:
The stock battery has about 1kWh of total energy of which you can use about half, the 8 bars on the dash represent a real SOC range of 40% to 80%, it's worth about 1 to 3 miles depending on your driving. Generally you can't go past 1 mile unless you start fully charged, use the EV-mode to reach the lower limit of 45% SOC (where EV-Mode exits) and drive very easy on an ideal "course". My Converted Prius does about 10 miles or so in EV-Mode with more or less "normal" driving over "regular" terrain below 34mph. The EV-Mode button is pretty simple, and I would recommend that you install the CAN-View if you're interested in getting more technical feedback from your Prius. whether or not you use the CAN-View for a PHEV conversion as I and others have it's simply a great feedback and diagnostics interface... http://www.eaa-phev.org/wiki/CAN-View Nice VW conversion you have there... L8r Ryan
__________________ Question Combustion (in cars and power plants). First think Near-Term Solar (PV, Wind, Hydro) and secondly "local" nuclear, remember Solar IS Nuclear. Then again so are hydrocarbons, it's all about the timescale. * http://www.eaa-phev.org Plug-In Hybrid Electric Vehicles! | |
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | [Thanks all for the info, glad you liked the vw conversion it has been a lot of fun and still needs a few things, but all in good time. I think I will do the coastal ev mod. and the reverse beeb mod can't stand it. also would like to say I have learned a lot on this site in a very short time.. thanks again. oh about the soc meter,, 8 bars went driving last night put on 110 miles only gets 7 bars of green how or when does it ever go to 8 bars? |
| Senior Member Join Date: Aug 2006 Location: San Diego, CA
My Car: 2006 Prius Package: Base Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(regenme @ Mar 11 2007, 08:17 AM) [snapback]403732[/snapback]</div> Quote:
My Car: Package: Nominated 0 Times in 0 Posts TOTM Awards: 0 Friends: 0 | <div class='quotetop'>QUOTE(tripp @ Mar 10 2007, 08:21 PM) [snapback]403620[/snapback]</div> Quote:
| Regen while coasting -- why? | Sailfish11 | Fuel Economy | 28 | 08-23-2007 02:29 AM |
| Regen adjust? | Pegasus_ | Prius Modifications | 6 | 06-30-2007 09:57 AM |
| 2 stage regen | gazz | Fuel Economy | 10 | 05-23-2007 07:44 AM |
| Regen under 30mph | Path2ground | Prius Technical Discussion | 17 | 07-24-2006 08:09 PM |
| Regen breaking | ScottY | Prius Main Forum | 7 | 06-22-2005 08:09 PM |
